Vector bike and frame owners.
Artur   100 kW
Re: Vector bike and frame owners.
Post by Artur » Aug 28 2018 12:49pm
without thread on a contact point you have more contact surface and less preasure on material of shock and shock support.
Ghost Rider   10 mW
Post by Ghost Rider » Aug 28 2018 1:02pm
Artur wrote:
Aug 28 2018 12:49pm
I did actually mention in one email that I thought it would be better without threads :) could you tell me the exact specification of those bolts so I can find them or are they custom made? Another question; I have taken the threaded bolts in and out quite a few times, could that have made the bolt holes bigger?
- 2018 Vector Typhoon
- Rocky Mountain RMX special edition (sold)
Artur   100 kW
Post by Artur » Aug 29 2018 3:28am
Ghost Rider wrote:
Aug 28 2018 1:02pm
Artur wrote:
Aug 28 2018 12:49pm
i dont think you would chip off the metal, maybe just paint a bit. If you need this bolts, just pay for shipping, I will send you this 2 bolts with nuts andwashers , as you bought our frame. thank you for your support!!
pucksterpete   1 kW
Post by pucksterpete » Sep 02 2018 5:33am
Okay cool, received the battery I ordered from Artur, 24s15p w/bms. Panasonic 18650PF cells
The outside box was pretty warped, I'm surprise it didn't come a part, but the other box and packaging with the battery inside was well protected.
Here are some video's with the delivery driver and the package.
he's waiting for me to show up
I have a few questions. Its been since I have dealt with a bms.
I assume the large green wire coming from the bms is the negative and that the large red coming from battery is positive.
What is the blue wire coming from the bms and the yellow wire coming from the battery?
Also, do I need a pre-charge wire with a resistor for this battery, so I don't get a pop/flash when connecting to the controller? Currently on my lipo battery pack for another bike I do, but then again I don't have a bms.
I'm tight space in the Vector Typhoon frame, would it be alright to a fix this bms to the side of that battery pack or would that be a bad idea because of heat?
If anyone could help that would be much appreciated.
Optim Alp Hardtail with MXUS Motor
20S 2P Turnigy 5.0 Hard Case
Top speed 38mph tops :)
Hyena Special
http://endless-sphere.com/forums/viewto ... 97#p585997
Excelsior/Strong GTS with Cromotor
24S 3P Turnigy 5.0 Hard Case
Top speed so far 53mph
http://endless-sphere.com/forums/viewto ... =6&t=46993
Artur   100 kW
Post by Artur » Sep 03 2018 5:38am
you can mount it on a side. about wire colors i wrote yo email already. I recommend to use short cirquit switch to turn on off power to avoid a spark. glad that 3 layers of protecktion did a job!
pucksterpete   1 kW
Post by pucksterpete » Sep 03 2018 7:44am
Artur wrote:
Sep 03 2018 5:38am
So, its okay to mount the bms on the side of the battery, good to know. There just isn't enough room in that frame for that battery. Thank god for the wide side covers.
Any information on the RCP2 850 lbs 220mm rear shock I ordered from you? That is the only piece i'm missing for this build.
Yes, very good idea to triple up on the layers for packaging these batteries.
Thanks for the email earlier.
Hyena Special
elmannen   10 mW
Post by elmannen » Sep 03 2018 12:58pm
Missing part and a new cup arrived today quick and safe, thank you :D
/Lars Persson
Ghost Rider   10 mW
Post by Ghost Rider » Sep 04 2018 11:32am
I still think it's weird that it's presumably okay that the bolts can move vertically(makes a loud knocking sound when lifting bike) in the holes if they're not super tight.
On my previous bike(a full suspension XC bike), I couldn't move the shock bolts vertically even when they were completely loose.
Artur   100 kW
Post by Artur » Sep 04 2018 11:36am
Ghost Rider wrote:
Sep 04 2018 11:32am
I still think it's weird that it's presumably okay that the bolts can move in the holes if they're not super tight.
new bolts comes in a size that fit perfect.
Artur   100 kW
Post by Artur » Sep 04 2018 11:37am
only 10 frames available.
Ghost Rider   10 mW
Post by Ghost Rider » Sep 04 2018 11:45am
Artur wrote:
Sep 04 2018 11:36am
Ghost Rider wrote:
Sep 04 2018 11:32am
What is the size of the new bolts ? Are they 8mm? Because my shock mounts have two different sizes(as I have explained in emails to Vector) so, I'm sure that getting new bolts won't get rid of the play in the upper shock mount. (I have tried unthreaded bolts, and still have play.) Upper shock mount is 8.2 mm.
I just checked my XC frame and even with the bolts completely loose there is no play in any of the shock mounts.
And that is a cheap "no-brand" frame, however it's made in Taiwan, not in red China.
Is it impossible to make a upper shock mount that is exactly 8mm?
Ghost Rider   10 mW
Post by Ghost Rider » Sep 07 2018 2:49pm
Artur wrote:
Sep 04 2018 11:36am
Ghost Rider wrote:
Sep 04 2018 11:32am
how much would I have to pay for a new upper shock mount that is exactly 8? Plus threadless bolts?
Artur   100 kW
Post by Artur » Sep 08 2018 5:09pm
Ghost Rider wrote:
Sep 07 2018 2:49pm
Artur wrote:
Sep 04 2018 11:36am
Ghost Rider wrote:
Sep 04 2018 11:32am
just a shipping, and a feedback on webpage ;)
Ghost Rider   10 mW
Post by Ghost Rider » Sep 09 2018 8:45am
Okay :)
Artur   100 kW
Post by Artur » Sep 11 2018 2:07pm
MatLSG   1 µW
Post by MatLSG » Sep 19 2018 7:46am
Thanks you Vector Ebike ! I'm really happy of the quality of the product. Nice look and good services. Excellent purchase. After assembly, i will post pictures of my awesome Ebike :D :D
pucksterpete   1 kW
Post by pucksterpete » Sep 27 2018 10:20am
Does anyone have a source for the sidecover screws? I'm looking for screws with knobs on them to turn by hand.
Hyena Special
brumbrum   100 kW
Post by brumbrum » Sep 27 2018 12:19pm
pucksterpete wrote:
Sep 27 2018 10:20am
Go on ebay and look up thumb screws
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
pucksterpete   1 kW
Post by pucksterpete » Sep 29 2018 10:28am
Thanks, I'm coming up with 5.8mm diameter, so is this a M5 or M6 screw?
Hyena Special
Ghost Rider   10 mW
Post by Ghost Rider » Oct 22 2018 7:29am
pucksterpete wrote:
Sep 29 2018 10:28am
It's M6.
I got the new shock mount and the unthreaded bolts from Vector,
and this time the bolt hole was small enough, so there's no play anymore.
First ride with new shock mount:
The Vector moto seat is very comfortable, but I wish there was a taller version of it. (relative to the bottom bracket)
Don't want to use longer shock or flipping the mount because I want the slack head angle I have now.
Gonna try to find somthing to make a taller subframe for the seat.
Artur   100 kW
Post by Artur » Oct 22 2018 1:17pm
Ghost Rider wrote:
Oct 22 2018 7:29am
pucksterpete wrote:
Sep 29 2018 10:28am
It's M6.
Very clean built :D Maybe one of the lightest on the forum ) Glad the new bolts and mount is what you need, thank you for helping us :wink:
Also if you have ideas of what would you want to change on frame, feel free to post it here, I will definetly keep it in mind for our future frame designs.
Artur   100 kW
Post by Artur » Oct 22 2018 3:27pm
Ghost Rider   10 mW
Post by Ghost Rider » Oct 23 2018 8:00am
Artur wrote:
Oct 22 2018 3:27pm
impressive, glad the guy was okay.
Artur wrote:
Oct 22 2018 1:17pm
Thanks :) basically just a bicycle for now :)
There are some things I wish were a little different on the frame. One thing is the head angle. Maybe it's just me but it seems to be steeper than on a downhill bike(when you have 240 mm in the back and).
This doesnt really bother me because I have a shorter shock, but if I wanted a DH shock I feel like the angle would be a little steep.
The second thing is the lenght of the head tube. It seems pretty long compared to downhill bikes.
My 2011 Boxxer Race has just a little more than 190mm not fully 200mm, even with the tall crown to accomodate the taller head tube.
But I guess it would make the frame weaker with a shorter headtube?
AccountMember   10 mW
Post by AccountMember » Oct 28 2018 7:53am
Recently switched from EEB to Vector as I am building high end bikes I needed a frame to match the EEB was causing them to be confused for Chinese import bikes
What a difference in quality anyone on the fence about buying one don't be, I have used Qulbix too but the cost and the need for a proper derailleur was not popular
Here is my last unsold Qulbix I haven't even bothered to build it up
madin88   100 MW
Post by madin88 » Oct 29 2018 8:21am
AccountMember wrote:
Oct 28 2018 7:53am
What did you mean with "proper derailleur"?
You can use a single speed freewheel and single speed chain tensioner so there is no need for a derailleur.
I have built ebikes with both frames. IMO the overall build quality of Qulbix frames is much better and i think it is a stupid idea to put the Q140 to the side and using a Vector instead :o
Qulbix is using high strength steel with >1000N/mm² while Vector frames are built with S235 or S350.
It you compare it with a Q140 the latter has more space for battery, less weight and better geometry (at least i did like the geometry of the Qulbix more). Also the welds were much nicer done and alignment of all parts was perfect (which was not so the case on my Vector frames).
