Post Pics of your electrified 26'r !
Ottodog   100 W
Post by Ottodog » May 15 2015 6:27pm
We've some really imaginative and cool looking 26 inch e-bikes around here and I thought it would be nice to have a photo collection of them all in one place. If you got 'em, please post 'em. A few lines about what went into your project would be cool too. :)
r3volved   100 kW
Re: Post Pics of your electrified 26'r. The badder the bette
Post by r3volved » May 15 2015 7:34pm
OCD   100 W
Post by OCD » May 15 2015 7:35pm
Nearly finished! Bad enough (on a budget) for my daily commute. 3000 watt 80 amp Greetime controller, Golden Motor 901 hub motor, 2x 48 volt 10 amp/hr GM batteries, CA v3, home brewed frame. Built from parts I already had laying around my workshop except the frame tubing.
Ottodog   100 W
Re: Post Pics of your electrified 26'r !
Post by Ottodog » May 17 2015 6:35pm
That's it??? TWO??? I've seen plenty of badd ass 26'rs around here. Come on guys... Let's get this thread going. :D
nutnspecial   1.21 GW
1.21 GW
Post by nutnspecial » May 17 2015 8:23pm
Both are way cool. The second one reminds me of a bike for the Tron Legacy Movie for some reason. Or a speeding bullet train.
Gonna have to get some better pictures for ya, but here ya go as is:
My xc -turned evil
PICT0012 - Copy.jpg (99.95 KiB) Viewed 3604 times
Currently 65lbs and 6kw middirectdrive Klein Mantra comp xc
charleyhaze   1 W
1 W
Post by charleyhaze » May 18 2015 1:20am
Samd   1.21 GW
1.21 GW
Post by Samd » May 18 2015 1:40am
I'm about to mod and build another of these :)
Norco, 200mm travel, proper Horst rear end.
It'll ride over a fridge :)
http://ballaratebikes.com/
amberwolf   100 GW
Post by amberwolf » May 18 2015 1:45am
Fusin Test Bike:
http://www.endless-sphere.com/forums/vi ... =4&t=39877
This one doesnt' exist anymore, but it's one of only 3 *all-26"* ebikes I've made so far. (CrazyBike2 counted at one point, but presently it's a 26"/20", and is the most "badass" bike i've got so far, as far as any of mine might be generously called that :lol:) I still have the frame and stuff, but it's all redistributed over other projects now.
Like all my stuff, it has to be able to haul heavy loads, and this one did ok with trailers full of dogfood:
Samd   1.21 GW
1.21 GW
Post by Samd » May 18 2015 1:51am
Here's my weight weenie full carbon Commencal - a Meta 55. Carbon seat, seatpost, bars and frame.
Given the heritage of these frames I was afraid to get it dirty at first :mrgreen:
mmm, mud.
amberwolf   100 GW
Post by amberwolf » May 18 2015 2:32am
DayGlo Avenger, MkII
http://www.endless-sphere.com/forums/vi ... =2&t=15570
This one, much older than the above, also doesn't exist as such anymore; the frame has cracks in the rear seatstay area and other issues, so I can't trust it with heavy laods and whatnot. Half of it is still together, but most of it's lighting and other stuff has been moved to other projects.
It had several different motorificatorizations over the years:
A friction drive, from radiator fan motors
which didn't work all that well so I made this other version that did pretty ok
A long time later, with muchfaded paint and a fusin geared hub
and ti's of course made for cargo hauling too, both dogfood *and* dogs:
then after I got a 9c DD hub, a junked honda scooter, some more paint, and time:
nutnspecial   1.21 GW
1.21 GW
Post by nutnspecial » May 18 2015 3:08am
AW, you are truly an artist!
Sam and Charley, what do those bikes weigh and what'r they able to draw in power?
I've never tried a hub or middrive. . .
Brettster   10 mW
Post by Brettster » May 18 2015 3:31am
Beach Cruiser
meelis11   100 W
Post by meelis11 » May 18 2015 5:36am
soaresdacosta   1 kW
Post by soaresdacosta » May 18 2015 7:38am
My 26 Cube.
OCD   100 W
Post by OCD » May 18 2015 9:38am
Here's last years commuter bike.
ferret   1 kW
Post by ferret » May 18 2015 12:00pm
Don't believe everything you think.
Cove GNG-Spot build thread
Astral Rune build thread
Paladin   100 W
Post by Paladin » May 18 2015 4:44pm
12s lipo in backpack, 10t Mac, CA3, upgrades.
unclejam   10 W
Post by unclejam » May 22 2015 10:27am
. My MXUS 3000w commuter / tame off roader with 80v / 50A currently until new 18fet modded controller fitted. Beefy components, Saint brakes, 888's and custom batt box. Double Cree headlights to complete the "Totally non- stealth" approach :D
(Ok Ok, only the front wheel is a 26'r !)
“Begin doing what you want to do now. We are not living in eternity. We have only this moment, sparkling like a star in our hand and melting like a snowflake...” Francis Bacon
k1kk0_1t4   1 W
1 W
Post by k1kk0_1t4 » May 26 2015 2:20pm
Here is mine...
Gng motor
Unusual "aggressive" fronte suspension frame
48v battery (making a new 60v one)
26*2.4 maxxis tires
Climbs like a drunk goat
And..... PINK mudguards!
taiga   1 µW
Post by taiga » May 26 2015 5:42pm
fellow   1 kW
Post by fellow » May 27 2015 8:29pm
This is the complete ebike, batteries are hidden inside the frame tubes, 2 x 75.6V packs, currently at 75.6V. ATF oil cooled Q100H hub. 19.9kg, 1kW.
My older project, batteries also hidden inside the frame tubes, 54.6V, ATF oil cooled Q100H hub. 17kg, 0.9kW. 32km/h
My 18S Q100H Frankenstein S06S project is here: http://endless-sphere.com/forums/viewto ... =6&t=68305
Ottodog   100 W
Post by Ottodog » May 27 2015 11:06pm
Nice job fellow! That's the stealthiest placement of batteries I've ever seen. How many Amp Hours were you able to stuff in there?
meelis11   100 W
Post by meelis11 » May 28 2015 3:22am
Did you cut the frame to make hole? Or how did you put battery inside frame?
SlowCo   100 kW
Post by SlowCo » May 28 2015 6:56am
Very Stealthy!
Where is your 1kW controller and where exactly are the batteries...? :shock:
fellow   1 kW
Post by fellow » May 28 2015 8:40am
Ottodog » Thu May 28, 2015 5:06 am
Thank you:). The white one has 36 pcs of Panasonic NCR18650PF batteries inside, 2 packs with 18s each. Range 25km. 5.8Ah at 18s (67V nominal, 75.6V HOTC), probably a bit less than 400Wh IRL. I'm still fine tuning its LVC to get most of it. The yellow one has 26 pcs of Panasonic NCR18650PF inside, 2 packs with 13s each. Range 18km. It is 5.8Ah at 13s (48V nominal, 54.6V HOTC).
Post by meelis11 » Thu May 28, 2015 9:22 am
White one:
I removed the front badge and drilled the 21mm hole (18mm drill). That hole is later hidden by replaced badge. Second hole is hidden by 21mm on/off switch. Third small hole is where the cables are leaving the frame, close to the on/off switch. Controller is above the shock absorber, in between the plates. I can take out and replace all the batteries in about 15 minutes, if needed.
Yellow one: One hole behind the front badge, second hole where all cables are leaving the frame. Controller in the first aid kit. It takes few hours to remove/replace the batteries on this one.
Very Stealthy!
The controller is custom made "Frankenstein" S06S hack. You can click on the "triebfluegel" link on my signature, and you can see where the controller is hidden :D . Picture is here: http://endless-sphere.com/forums/downlo ... ?id=166710
I used high voltage so I can keep switches, wire thickness, motor and controller size down (volt up, gear down thinking). Motor has 12.6:1 internal gearing, it is like having much bigger diameter DD. You just have to cool it and rev it high enough:). It follows the laws of physics and is not burnout capable, but it pulls really good at high revs.
