Stealth FUTR owners builds and pics
IanM   100 W
Re: Stealth FUTR owners builds and pics
Post by IanM » Apr 02 2018 2:21am
Rix wrote:
Apr 01 2018 5:19pm
Looking very sweet PRW.
+1 here, that bike is going to be something special IMO :D
I took my alpha out for a nice long ride today, managed to cover 53km over 3h 20m with total elevation gain of 984m.
On board was my 20ah 12s multistar pack with 50v at the start and 46v at the end with sag of about 2v at full throttle.
For most of the first half of the ride I was switching from pas 1-3 and using throttle when going up steep bits, for the last 10km I was using pas 3-5 and going a fair bit quicker so using more battery capacity because I knew I was going to get home with range to spare. I think I could get another 10-20km without too much trouble but my butt is sore enough from 3 hours in the saddle. Another hour would be a bit tedious and butt destroying :lol:
The photo is at Black Mountain Tower in Canberra at about 809 metres. The bbshd handled the climb so well I was impressed, it was warm to the touch but not hot at all and there was plenty of climbing after that as well.
So I am happy with the bike for the moment. It climbs extremely well and has excellent handling on downhill sections too. There is one thing that I'm not that happy with, the front wheel is quite hard to pick up over obstacles due to the extra long chain stay length, oh well I think I can live with that for now :roll:
Alpha at Black Mountain
PRW   10 kW
Post by PRW » Apr 02 2018 11:36am
thanks Rix / Ian!
Ian, very clever to fit the BBSHD onto the Alpha - I am always impressed with the BBSHD, there is one on my wife's bike, and it shines when the going gets tough uphill.
Lash   100 W
Post by Lash » Apr 09 2018 12:46am
Hey IanM, when you talk about extra long chainstay length.. did you lengthen it, or are you referring to this just being an affect of the mid drive positioning. I notice your seat frame is angled back a bit. Is this because your a big dude, or because of other adjustments...?
Moving on, I just finished a battery for a stealth bomber for a guy in sydney. I thought id test fit it into an alpha frame I have lying around.
low-n-behold it fits!
Its a 20s10p battery, with a 5 cell wide construction in a staggered arrangement its a fairly easy fit with bare minimum padding.
So good to know this configuration fits both the bomber and alpha.
Next battery I will make a few slight adjustments to make it even more compact and even better protected.
so 30ah (samsung 30qs) and 72v is pretty damn impressive. weighed just over 10kgs.
here's a cpl of pics to get the gist of its size and fitting as its nearing completion.
IanM   100 W
Post by IanM » Apr 09 2018 4:01am
Hi Lash, I am talking about the length between the rear axle and the bottom bracket axle. I am fairly sure that this was done by stealth to provide anti wheelie characteristics when running high power levels. When the mxus was on there at 6kw there was never any problem to lift the front wheel and still easy to prevent flipping by keeping body weight forward. Now with only 1.2kw peak it's a lot harder. Long wheelies are near impossible now with the bbshd on there.
I made a spacer for the seat post tower in an effort to shift my weight rearward, essentially making a slacker seat tube angle, it made it better but it's still hard to lift the front. I'm not too worried because the bike is much more usable now and it's getting ridden a lot more now than before.
I suppose I could just get a mtb frame however when I tried the bbshd on my giant trance X1 there was a lot of flex in the rear suspension under power, the same happened on my old giant A/C and it was worse on that frame. The alpha has zero flex when under full power and also with the urt pivot there is less issues with the drivetrain when accelerating and shifting gears because there's no chain growth as the suspension moves.
Anyhow it was just an experiment really, I was thinking about putting the bbshd on there for a long time then one day I said what the hell and just went for it. I am happy with it for now but I keep thinking man I sure miss having 6kw on tap :)
I am now thinking about trying 27.5+ tires but that's a project for later, for now the 26+ tires are doing very well and I don't think I could go back to skinny 26x2 cross country tires now after getting used to the extra grip and improvement in ride comfort that the 26+ provides. Anyway I will stop babbling now :roll: :D
Oh good work on the battery build I may be in the market for a 14s 8p pack soon.
Rix   100 GW
Post by Rix » Apr 10 2018 9:42pm
Tacticool Alpha
Cowardlyduck   10 MW
Post by Cowardlyduck » Apr 10 2018 11:23pm
Sweet moves there Rick! Now you just need to mount 2 sub machine guns either side of the frame and you can gun em down Mad Max style. :)
I took my dad out for a spin on my Alpha and Fighter today to a local solar farm. Was a blast and the full 13KW+ on tap on the Alpha scared the crap out of my dad. :lol:
The allen bolt on the left hand side crank seems to keep coming loose on my Alpha. It's probably not an Alpha specific thing, but we had to tighten it about 6 times on the ride as the crank kept getting so loose it felt like it was about to fall off.
Should I just tighten the crap out of it with some thread locker on there or is there a technique to getting square taper cranks to stay put?
Cheers
High Power LiPo wiring harnesses - 4P - XT90, HXT4mm, 5.5mm. 200Amp+ capable. Global shipping.
Modified Stealth Fighter - Force air cooled motor @ 6KW, Heat-sinked Adaptto Mini-E. 49AH, 52V 18650 - 2.5Kwhr
Cowardlyducks - Stealth Fighter Videos
BikeE recumbent commuter - 9C, 6Fet Grinfineon, internal 17AH, 52V, + on-board solar.
The stuff I make and modify.
efMX Trials Electric Freeride   100 kW
Post by efMX Trials Electric Freeride » Apr 10 2018 11:37pm
what brand crank arms, check the manufacturers recommended torque spec, usually around 25-30 ft pounds for square taper cranks.. remove the crank arm and check for deformation of the aluminum crank arm at the spindle interface.. its very easy to under or over tighten crank arms resulting in damage to the crank at the spindle interface, then it will never stay properly secured and should be replaced..
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
Hyena   100 GW
Post by Hyena » Apr 11 2018 1:37am
Rix wrote:
Apr 10 2018 9:42pm
Tacticool Alpha
Cool! Is this part of a bigger video to follow ? I see you had a camera man, with a gimbal, so I'm guessing there could be a bigger vid to follow.
Reminds of this clip I made back in the day on my old fighter, only you're the real deal and I'm a big kid playing with water pistols :lol:
https://www.youtube.com/watch?v=87o4brfSDEI
Ducky, your chrome alpha is looking sweet. For sure get some blue loctite on those crank bolts. Also check for wear on the threads both male and female and check the physical fit of the cranks. Alot of people tend to spend the bare minimum on a BB and crankset, especially when the pedals are largely ornamental on many bikes! And while spending $500 on a crank set seems a hideous waste of money I've also seen some nasty cast pieces at the bottom of the spectrum that have a not so square taper or have rounded out in short order.
www.HyenaElectricBikes.com
Rix   100 GW
Post by Rix » Apr 11 2018 9:31pm
I remember that clip, I was looking forward to your potential home movie. If I remember correctly, you had a couple of volunteers and one crashed during filming. As for my video, It was a part of a bigger vid, but the bottom line was, I used some gear from my former agency and need to get permission to broadcast anything that could potentially identify the agency. Long story short, not going to go through the process to do that as I no longer work there. Still, I thought it would be great to do something in full battle rattle gear with an ebike. I did have a camera man for this work, which is not related to the other work that may, or may not be used for a potential product promotion video :wink:
Yah, I thought about doing some shooting while actually riding, but I was using real weapons with real ammo. When I evaluated the safety aspect of shooting while riding, not so much the hand gun but the SBR, with one hand, safety disengaged, shooting, safety re-engaged, letting go of the weapon, while the other hand controlled the throttle and front brake, and trying not to crash, with that much divided attention, the possible risk out weighed the coolness factor. There was a lot going on here. With my SBR on a single point TAC sling, the risk of it swinging around and getting caught on my gear, even with the safety engaged, was more risks than I was willing to accept. I could have rigged it better for a real world ride and shoot, but this was kind of a On the Spur moment of opportunity. Anyway how the vid was shot still made out for an entertaining vid I think. BTW, awesome pic of your machines. Next time you get your Dad to go riding with you, snap a selfie with your dad and the bikes. That would make for a real sweet picture.
PRW   10 kW
Post by PRW » Apr 12 2018 12:16am
Haha - such a cool video, Rix! :D
Rix   100 GW
Post by Rix » Apr 12 2018 11:49am
PRW wrote:
Apr 12 2018 12:16am
Thanks Amigo.
Lash   100 W
Post by Lash » Apr 14 2018 12:40am
Great videos, cant go wrong with ebikes n guns! heheh.
Finally got around to fitting some parts today. More incompatibility issues Grr!
For Mxus v3. I have 12t single speed freewheel that uses the 1/8 x 1/2 chain "single speed chain". No worries.
The cranksets I am hoping to use are the 2 piece shimano hollotechII type as opposed to the square taper ones.
These come in at least a couple of axle/ spindle lengths. (that arent published in most listsings! lol)
so heres the problem
Ideally a 48t chainring for 1/8 x 1/2 chain up front is what I'd like. These only come in 130bcd layout it seems!
But are there any 130bcd cranks that fit the alpha - with the long 120+mm spindle length!???
The alternative is to use a 104bcd crankset. but they dont have 48t chainrings to suit single speed! GAWD!
The only other option is to switch to the other "normal" chain profile of a 7-8-9 speed chain, and use a 48t narrorw wide chain ring for on a 104bcd layout. This means I have to find a new option for the rear freewheel. It seems a 12t "7 speed" freewheel doesnt exist. The closest maybe a 14t or 16t freewheel. But this is not ideal config for top end speed. Any other options?
Third option is to go back to old school square taper BB and be friggin DONE WITH IT (I hope)!
What' ya''ll reckon.?
Cricket_Swe   100 W
Post by Cricket_Swe » Apr 14 2018 6:00am
Crap. Finally managed to put my bike together after all this time. And I get this message. I had some damaged hall cables that I "fixed" but maybe it wasn't enough? Will probably have to tear the motor apart and see. Is it enough to measure connectivity from one end to the other of the hall cables or do I have to measure voltages?
I tried the health screen and spun the wheel but no numbers changed
Cricket_Swe   100 W
Post by Cricket_Swe » Apr 14 2018 6:28am
This might be something, gonna have to measure
https://endless-sphere.com/forums/viewt ... &start=325
Cricket_Swe   100 W
Post by Cricket_Swe » Apr 14 2018 6:43am
Alright, I measured the volt on the halls connector that comes from the controller with the bike on. Got 2V. Any ideas?
\ (•◡•) /   100 mW
Post by \ (•◡•) / » Apr 14 2018 10:16am
Lash wrote:
Apr 14 2018 12:40am
not sure if this is at all relevant or applicable but incase you think it may work... https://www.ticycles.com/store/104mm-to ... cd-adapter . Also i'm getting some torque arm's made for my Alpha soon, which is being cut on a water-jet cutter, so since the adaptor is out of stock I may be able to also get something similar made for you to suite your exact purpose, But guessing it wouldn't be a lot cheaper than the one for sale on that store. just a option for you.
oh also... https://www.ebay.com.au/itm/Chainring-S ... 699275921? if willing to go 42t
and... https://www.ebay.com.au/itm/104BCD-52T- ... 700156988? from what I know you can run wider chains on narrower chain rings as long as the length between the chain pins lines up. But defiantly don't take my word for it.
Also good news I got my motor wire issue sorted!
infact it actually has room to spare, so really happy with that (Thank-you to all the people who gave me help and passed me forward to the other thread)
don't have any pics of the actual motor wire clearance on the frame yet but I promise to post some once I take them (probably when the bike is done in a week or two)
for now here's a teaser:
the plate you can see is a 4mm water-jet cut aluminium spacer with a milled slot. this spaces the dropout out a bit more giving the motor wire a great little home. it's funny actually because my dropout would originally sit maby 3 or 4mm out from my motor naturally and would then compress onto the motor when I tightened the nuts, but now it fits perfectly. I think whoever made my frame knew I was going to put in a QS 205 and was rooting for me. Anyway cyas later (for now)
Oh yea, and, I also have some really neat torque arms being made out of either D2 tooling steel or standard has strength steel ATM. will share photo's of that in a few days
Rix   100 GW
Post by Rix » Apr 14 2018 10:28am
Excellent solution \ (•◡•) /. When will you be up and running?
Lash   100 W
Post by Lash » Apr 15 2018 12:55am
Hey \ (•◡•) / , thanks for the links, good to know there is an adaptor out there. But aiming for a clean and simple solution going forward I decided to go back to square tapers for the alphas. This way I get 48t or whatever I want single speed chain ring on 130bcd (5 point chainring) and still keep the 12t sprockets on the back. Chainstay Ccearance is always a consideration too, so this should be a better base to work from with the existing products out there. The other "best" solution would of been to go for 14t freewheel using the "7 speed" chains, but meh, I love my 48 and 12 combo, and didnt want to make it any "faster pedal rpm" - especially on these bikes, as they will have even more top end speed than what I'm running on my personal alpha.
Having said all that ive managed to get a nice 104bcd 48t narrow wide chainring and crank setup on the beta using the "VXM" crankset.
Plenty of clearance and a nice looking setup. I'll wait till I get wheels on to show a picture. This one will be paired with a 7speed cassette and mac10 so all is good with chain compatibility there.
I'm getting over aliexpress's shipping times though, its always the dependent parts that get held up, and the not so important ones that get here the fastest.
Glad you got your motor mounting all sorted, I'm about to tackle that next, how come you need toque arms for the alpha? Cant just use the existing clamp bolts?
Cowardlyduck   10 MW
Post by Cowardlyduck » Apr 15 2018 6:51am
Hey Lash,
Not sure if you saw it previously but I'm running a 60T BCD110 front chainring. I've just got a 14t 5 speed rear freewheel that I will be installing some time soon, so that should give me some decent pedalling speed.
There are also some 13t 5 speed freewheels out there, but they are hard to find and a bit pricey.
Just another option to mix things up for ya. :)
Cheers
Rix   100 GW
Post by Rix » Apr 15 2018 9:56am
Cricket_Swe wrote:
Apr 14 2018 6:43am
I think its supposed to be 4.95-5 volts for the throttle sensor. I am not sure though.
\ (•◡•) /   100 mW
Post by \ (•◡•) / » Apr 16 2018 1:20am
Here's a sneak peak of my torque arms, these are a prototype set being made from 40mm and 15mm thick steel. There are obviously in the very early stages of machining and still have a long way to come. I'll post the finished photos when there all done and I get a chance to test then. Also I don't know if many People have the vertical dropout version of the frame yet but I may consider selling a limited batch run of them, if anyone is interested. (would make both 14mm and 16mm versions for smaller and larger axles)
Oh also I believe that orange stuff is the abrasive from the water jet not rust, and the bottom tension plates have been sandblasted (they're not finished either)
Swe   100 W
Post by Swe » Apr 16 2018 3:10pm
Anyone here that have a kickstand on your Beta? Or any advice what could fit?
I only found this in the Stealth topic, and the price is too high, and with shipping extreme high (more than then the kickstand itself).
https://m.ebay.com/itm/Ricochet-Off-Roa ... mwBanner=1
PRW   10 kW
Post by PRW » Apr 16 2018 4:00pm
Swe wrote:
Apr 16 2018 3:10pm
I bought 2 of these, haven't actually checked if they fit yet (I am sure I can make a plan with a wood block if needs be). Will check tonight. https://www.ebay.com.au/itm/Universal-M ... SwyXNaHufh
Swe   100 W
Post by Swe » Apr 18 2018 5:17am
PRW wrote:
Apr 16 2018 4:00pm
That was a better price. Shipping cost more than the kickstand itself, but a total cost at 85USD is still cheaper than what I found.
I see here on the forum that Vector e-bike sells a kickstand for 55USD (and i think +10USD shipping), maybe it works for Beta too. The pictures does not work so don't know how it looks.
https://endless-sphere.com/forums/viewt ... 31&t=61259
Rix   100 GW
Post by Rix » Apr 20 2018 9:45pm
http://www.futrelectricbike.com/shop/
Beta frames are going for $856.73.
