The wiring is rough as I just put the gear on yesterday and I want some experience with it before I do more work on it.
It is 55 lbs and will do about 26 MPH on level ground. I am 151 lbs dressed with helmet. So 206 lbs or 93.5kg.
Battery is supposedly some kind of Samsung 18650 and 48v, 20 Ah from AliExpress - I assume 13S. It is on a $23 Schwinn rack that is sold at Target or Amazon. There is some rattle between the battery and rack when I go over bumps, which is why there are bungee straps on it. They help but don't eliminate the problem.
My plan for the wires and controller was to put them in a triangle bag, but I decided that I want more airflow for the controller, so I may end up just using Velcro fabric wraps. I may print a mount for the controller.
I designed and printed the 8-pole PAS wheel because the 12-pole King CA one was too large a diameter for my frame.
I would really like a torque-sensor, but my bottom bracket is 107mm, so none will fit. I know there is the chain-sensing kind, but I hear they are not so good.
So far my impressions are that it is too heavy, and a smaller triangle or dolphin battery would have been better. But maybe I will enjoy the range, I am not sure yet.
I charged it up last night and will ride it today until the battery is depleted and then report the CA data.
And with Ibera bag:
And with Ibera bag:
