Giant Reign 2 Full Suspension + BBS02
Phife   10 W
Post by Phife » Sep 25 2015 10:21pm
Hey All,
Long time lurker and recently joined. I learned a lot from this group and decided to share my build.
Its a 2008 Giant Reign 2 Full Suspension bike, Ive got a Bafang BBS02 48V 750w, and a bottle battery pack from BMSBattery. At the time I bought the kit in June they had the best price and while it was a risk buying from them, I actually had got my kit quickly and without issue.
The kit fits perfectly in the frame, just enough room to clear the rear shock and still be able to remove it by sliding up. I had to drill new mounting holes in the bracket as they were too high up, but that was no problem. Im not using the brake cutoffs as I have hydraulic brakes and they are not easy to add the magnet sensor to. Im mostly riding trails, xc and single track with throttle only. I Bought the programming cable so I was able to have throttle on PAS0. I also have the Lekkie 42t chainring, Its much improved over the stock, I highly recommend it if you can afford it.
I have all summer of riding it and its been great! Ive ridden it on roads around town and easily do 40kph on the flats and 50pkh downhills and im still able to pedal, going up hills is no problem either, on or off road. I havent found a trail or hill yet that I couldnt climb. Plenty of power for the type of riding im doing and having the weight balanced and low I think is key to having a great riding trail Ebike. Ive not had any reliablility issues or any issues with my chain line, everything seems perfect, and since I mostly use throttle to help on the trails I can control when I shift as not to mash up my gears, although even in PAS I dont have much issue shifting under power, just gotta be smart about it.
I recently added a small DC-DC converter to regulate the voltage from the 48v battery to the 8.4v my Headlamp uses, now I can power the lights from the same battery as the motor.
Bike weights 48lbs as you see it here, Rider is 210lbs with gear. Battery always has plenty of juice even after several hours of riding, I only use the motor occasionally or to help climb, I pedal all of the time. I was able to go around 50km on the roads on a full charge and still had a bit of battery left.
If you guys have any questions of comments feel free to leave them!
Thanks everyone!
2008 Full Suspension Giant Reign 2 with 48v 750W BBS02. Click Here
2014 Specialized Stumpjumper FSR with Cyclone 3000w Mid Drive, 52V 20ah Backpack Battery. Click Here
2019 Hybrid SUV 27.5 with Bafang Ultra Motor, 48v 14ah Battery. Click Here
liv2ryde   1 mW
Re: Giant Reign 2 Full Suspension + BBS02
Post by liv2ryde » Sep 26 2015 8:14pm
I like it, clean install!
*Framed Minnesota 2.0 Fat Bike w/ Luna Cycle BBSHD 52v 1000w mid-drive, red LUNA 42T bling ring, Surly Bud/Nate, Scram X5 9 speed
*Marin Mount Vision 7 full suspension mountain bike w/ BBS02 48v 500w mid-drive, black Lekkie 42T bling ring, XT 10 speed
*Sonders eBike fat bike 36v 350w rear direct drive hub
Kepler   1 GW
1 GW
Post by Kepler » Sep 26 2015 8:28pm
Very nice. How are you finding the bottom bracket clearance with the low hanging drive? My drive sits in a similar position but is on a 29er. I rarely bottom out but if I do, the bike tends to just skip over the obstical anyway.
Current Rides
Lightest true ebike on the planet: ON ROAD viewtopic.php?f=6&t=74269
eBoost on facebook: http://www.facebook.com/pages/Eboost/200306283342024/
Phife   10 W
Post by Phife » Sep 26 2015 9:02pm
Thanks Guys,
Kepler you've been a great help in getting my bbs02 programmed. Thank you for your efforts!
As for my BB clearance, I was worried about the low hanging motor, but after putting over 500kms on it this summer mostly on trails I can say it hasnt been an issue. Any logs or rocks I usually jump over pretty easily, Larger ones I walk the bike over. Havent had a single hit yet. I hit my pedals all the time though. lol
Ive been reading some complaints about the BBS02 and the chain falling off. I havent had any issues with the stock or the Lekkie chain ring.
Marin   1 kW
Post by Marin » Sep 26 2015 9:49pm
Nice job, I almost bought one of those to mod, it looks so good.
Marin ex-rental hybrid with 48v bionx...sold
Specialized hardrock with magic pie 4-5
Lunacycle with l/r mid drive coming soon
Kona Caldera with QS 30H (maybe), and phase runner
Giant Yukon bbs02
Kona Abra Cadabra bbshd
Wildfire fat bike bbshd
mmosqueda   1 mW
Post by mmosqueda » Oct 02 2015 1:10pm
Nice Bike! That is a clean build.
liv2ryde   1 mW
Post by liv2ryde » Oct 30 2015 8:40am
Excellent build choices! That has to be a fun ride!
Tyler durden   1 W
1 W
Post by Tyler durden » Jan 25 2016 4:37pm
Exactly what battery are you using?
What kind of range are you getting?
Thanks
Phife   10 W
Post by Phife » Feb 05 2016 10:56am
Tyler durden wrote:Exactly what battery are you using?
Thanks
Im using the cheap BMSBattery.com dolphin battery. Panasonic cells, it was rated at 11.4Ah 4P13S
Im getting about 45km/28miles in a full charge on city paved trails, cruising around PAS 3-4. Power really drops off towards the end. Its hard to measure the range when im riding single track as im using throttle only and I do a lot of pedaling and use the motor to help with hills. I can get in 2-3 hours of riding and still have 40-50% charge.
LyonNightroad   100 W
Post by LyonNightroad » Feb 08 2016 1:22am
On the one hand I would like to see more watt hours than that, BUT on the other hand, what a clean looking bike! nice.
Phife   10 W
Post by Phife » Feb 08 2016 9:57am
LyonNightroad wrote:On the one hand I would like to see more watt hours than that, BUT on the other hand, what a clean looking bike! nice.
Me too, Im going to pick up a 52v pack from Luna, that will increase the range with an easily swapable, much more capable battery.
Im probably going to end up putting a cyclone 3000w Kit on this bike though, the BBS02 will go on the GF's bike.
beast775   100 kW
Post by beast775 » Feb 08 2016 11:56pm
Always liked the Giant Reign your build looks excellent,i lived on klo road in kelowna and i know for fact theres a gazzillion trails there you can ride. i did it all by pedal power in the mid nineties :D .
2 FINGER SALUTE TO ESSO.no buying gasoline for 14 years now.
I spent all my money on bicycles women and beer the rest i just wasted.
WizeArtz   1 µW
Post by WizeArtz » Jan 28 2020 8:41pm
Hi there, love the Reign! What front chain ring arey you using? 47T?
Thanks, Owen
torker   1 MW
Post by torker » Jan 28 2020 9:02pm
WizeArtz wrote:
Jan 28 2020 8:41pm
Thanks, Owen
Lekkie 42
Dave When I die I want to slide in sideways yelling WooHoo what a ride !
Giant Rincon w rear 9C 6*10 36 v x 20 amps
Specialized FSR Comp 9C 6*10 48v x 30 amps
