Mongoose Dolomite and Cyclone 3000W
Hello, I'm starting a new build from a fat Dolomite with a Cyclone mid-drive 3000W.
Re: Mongoose Dolomite and Cyclone 3000W
The mounting bracket system is a nonsense, a misfit for a 3000W and 100Nm motor.
First try with to stabilize the motor, the plate is not enough thick
4 stem screwed to the motor and welded to the frame
Really interesting
Inside the motor
Starting to setup a PAS sensor to throttle adaptator with Arduino mini and MCP4725 12bit digital to analog converter
Big Amp meter
Rear light mount
May someone find this clue:
Paint it in black
Change amp meter for a volt meter
Battery
25R, 50V 14.7Ah
25R, 50V 14.7Ah
Inside the gearbox
Transmission chain redone
thinking of getting this motor can you help
1. how is the controller and throttle I was thinking of using my own lyen?
2.do you think you could run it on low power with the bb sheaths that come with until I can get something better?
3.how is the noise?
4.How do the chains hold up?
5.how are the gears holding up?
3.how is the noise?
kona stinky - adaptto - HT3525 - https://endless-sphere.com/forums/viewt ... 4#p1005754
bikes owned:
new build LR kit dirt bag frame adaptto - rohloff
kona stinky adaptto ht3525
optibike
gaint ac1 bmc motor
prodeco ex 2014 48v
prodeco pooper 24v
hill toper kit (first kit)
2 Sanyo ebikes from japan
2 cheap folding bikes with 36v settups
bikes owned:
optibike
gaint ac1 bmc motor
prodeco ex 2014 48v
prodeco pooper 24v
- spinningmagnets 100 GW
When you had the motor apart, did you measure the width and diameter of the stator?
Hello broke, I don't think Cyclone ships twice the same components, anyway the included half-twist throttle was fine.broke wrote:thinking of getting this motor can you help
I hadn't try another controller, I think any controller with enough ERPM will do the job ?
Unfortunately no, the torque is too high and if you look carefully the motor is bolted with only 2 screws !!!broke wrote: 2.do you think you could run it on low power with the bb sheaths that come with until I can get something better?
Amazing, a long cry of pain in a dark forest !broke wrote: 3.how is the noise?
Not so bad, anyway I had redone the chairingbroke wrote: 4.How do the chains hold up?
Seems fine, you can find a lot of usefull informations from Karl website:broke wrote: 5.how are the gears holding up?
http://electric-fatbike.com/2015/08/24/ ... the-bbs02/
Hello spinningmagnets, I will do that as soon !spinningmagnets wrote:When you had the motor apart, did you measure the width and diameter of the stator?
I have given up trying to setup the Arduino and Pas sensor, too jerky even with a good feed back loop.
Then, a quick made battery and controller box :
