Kona Stinky / mxus 3000w TURBO / Adaptto / 888
atomek1000   100 W
Post by atomek1000 » Mar 11 2016 12:50pm
Hello guys, For long i've been lurking and gathering info for my build. This forum is extremely helpful and shout-out to anybody who shares interesting info!
And it is time to finally introduce my (kind of second) build.
Starting base is old dh frame fitted with polycarbonate side covers wrapped in carbon tape.
Estimate power of this build should be 72V nominal * 80Amps = 5800W
I am wondering whether standard mxus wires (awg13 ??) will handle that much. Max phase current is 200A on this controller.
List of parts:
Frame: Kona Stinky 2004
Controller: Sabvoton svmc 72080
Motor: MXUS 3000 V1
Battery: 72V 28AH Sanyo 3500mah GA Cells rated @ 80A
Charger: 10amp chinese "weizekang"
Breaks: Shimano SLX BR-M675
Tire: Kenda shorttracker on front and Hookworm on rear
Wheel Size: 26"
Rims: mavic on front and Hub is laced in PowerCircle (bought laced from mxus)
Forks: Marzochhi 888 vf2 2006
Rear Suspension: fox vanilla r
Handlebars: Spank Spike 777 cut to ~660
Photos:
Sabvoton size comparison to battery compartement
Battery is not finished yet because i need come up with idea how to mount it inside frame and then i will know how much space is left. 160Cells must fit 8)
First tests with Sabvoton and Mxus..Flux weakening enabled :twisted: Around 120kph
emcee   100 mW
Re: Kona Stinky / mxus 3000w / sabvoton / 888
Post by emcee » Mar 19 2016 12:20am
hows this build going? I'm particularly interested in the fit of the battery.
PiotrW   1 µW
Post by PiotrW » Mar 26 2016 4:04pm
Good job Atomek1000, can't wait to see your bike on life :)
macribs   1.21 GW
1.21 GW
Post by macribs » Mar 26 2016 6:56pm
I'll think you are fine with standard wires. If you push past 9-10 kw you might need to upgrade wires. It comes down to how hard you will push your ride like climbing, accelerating etc.
When you ride you can feel the wires after you push a lot of amps. If they are getting too hot to touch beefier wires will be the solution. If not you are fine.
atomek1000   100 W
Post by atomek1000 » Apr 18 2016 5:00am
Anyway guys, i went with adaptto. Sold Sabvoton. Battery will be 20s9p Sanyo's GA. And got MXUS v3 TURBO
More pics soon
atomek1000   100 W
Post by atomek1000 » Apr 18 2016 5:12am
emcee wrote:hows this build going? I'm particularly interested in the fit of the battery.
180 cells :D
soaresdacosta   1 kW
Re: Kona Stinky / mxus 3000w TURBO / Adaptto / 888
Post by soaresdacosta » Apr 18 2016 9:14am
Nice...very nice.
Very interesting project and good parts selection.
Luís.
try_all   100 W
Post by try_all » Apr 28 2016 6:09am
why you sold the sabvoton?
atomek1000   100 W
Post by atomek1000 » May 02 2016 4:57pm
I got good offer on Adaptto and sabvoton was too big in my opinion. It wouldn't fit as nicely as adaptto.
I went today for the first ride. It is really awesome!
90A batt, 200A phase and this bike flies!
OVS speed 123Km/h
Max power on screen 6.9kW It is the same feeling like you would have in 250Hp+ car.
On the other side mxus motor is powerful but heating is an issue with such power. Quickly rises above 100C and stays there with limited current.
I took some photos.
Nice rear light :wink:
atomek1000   100 W
Post by atomek1000 » May 30 2016 5:35am
Fixed heating problems by tweaking adaptto advanced settings and changing phase combo. Now i have Phase Angle near 0degrees and increased PWR timing to ~1.5 from 0.5 and it drastically improved performance and reduced heating issue. Now i can ride my 10km commute without any limiting. In the end the temp is still above 100Celcius but it does not rise so quick as before.
atomek1000   100 W
Post by atomek1000 » Jun 20 2016 5:06pm
New video from ride
Sean9002   1 kW
Post by Sean9002 » Jun 20 2016 9:44pm
atomek1000 wrote:New video from ride
video not available in my country :roll:
OSET 20+ - Custom frame and swingarm, Motorims - 66V
Ruff Cycles Porucho - MXUS 3000w - whitewalls - Gloss black/Pearl blue/copper leaf - custom tanks - bobber saddle
Giant Glory 00 - Clyte X5404 - Hubsinks - 18FET Sinewave
Fuji Nevada S - MXUS 35mm- Hubsinks - 12FET Sinewave
39inch longboard Dual 50mm, 12s lipo
atomek1000   100 W
Post by atomek1000 » Jun 22 2016 8:30am
Sorry! It appears that this song is blocked in some countries.
I uploaded to vimeo! :D
Have a look - > https://vimeo.com/171754519
I don't know whether i can embed vimeo as youtube :x
Sean9002   1 kW
Post by Sean9002 » Jun 22 2016 10:13pm
atomek1000 wrote:Sorry! It appears that this song is blocked in some countries.
Works perfectly! way better quality than Youtube!
999zip999   100 GW
Post by 999zip999 » Oct 04 2016 3:22pm
What muxus motor are you running ? Are you using a bike rim or ?
atomek1000   100 W
Post by atomek1000 » Oct 13 2016 9:46am
It is mxus v3 16x4T winding. But model without bended magnets. It is laced from mxua factory in 35mm width rim.
Spokes are 12g from what i remember.
It is running at 6kw and max 8kw without problems.
Already 2700km done
