Lightweight build Q100 cst 201 at 14s
motomech   1 GW
1 GW
Re: Lightweight build Q100 cst 201 at 14s
Post by motomech » Jun 14 2016 6:44pm
It's from the motor speed sensor. You can leave it unused.
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/20Ah Multistar Lipo rear 5Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
viewtopic.php?f=3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
viewtopic.php?f=3&t=49691&p=1378484#p1378484
leo99   100 W
Post by leo99 » Jun 14 2016 11:11pm
Like motomech just said I left it unplugged since it is the speed sensor.
What controller are you using? You have a link?
Leo
2011 hardtail scott BBS02 750w with em3ev 14ah 29e pack - sold
Stealthy q100cst 201 with 14s 6ah battery at 15 amps
https://endless-sphere.com/forums/viewt ... 4#p1170421
ScooterMan101   1 MW
Post by ScooterMan101 » Jun 15 2016 1:16am
I bought the controller on AliExpress almost a year ago.( Kunteng ? ) So I do not have a link saved. ( I am not finding it on Aliexperess now when I look for it )
But it is only rated at up to 14 amps, and it says 7 amps continuous ? / 7 amps rated what ever that means , 7 amps is low ,
I would like to run the Q100 cst at up to 17 amps , since I am used to much more power.
so
I am now thinking about ordering a 6 fet Infineon like what you got. And having it limited to 17 amps, or using it with a cycle analyst that way I can adjust the max amp draw one amp at a time. to see how it works,
since I am used to how a infineon and cycle analyst works together.
But then I would have to wait over a week to get one ( 6 fet ) from Em3ev in China , so I might ...
I might hook up the parts that came from BMS ( along with this Kunteng 48 volt controller,S-LCD3 Display, and thumb throttle, etc. ) to see how they work, or if I will like the way they work ,
and / or use an infineon controller, and cycle analyst, some time in the future, if I do not like the way the BMS/Kunteng parts work.
Here is a picture of the small 48 volt controller.
It looks like there is now a much better version, one with only three wires coming out of the controller, with waterproof connectors,
However not sure if it is made to work with the Q100c cst ?
Here is a like to the home company Kunteng
http://www.szktdz.com/en/news_show.php?article_id=353
or what looks like an older version, what I have ...
http://www.szktdz.com/en/news_show.php?article_id=350
However not sure if they sell to the general public, since both controllers say they can use from 24 to 72 volts and they say ... " 6. It can be customized for all types of controllers for users. "
leo99 wrote:Like motomech just said I left it unplugged since it is the speed sensor.
Leo
48 volt controller
48 volt controller
My first conversion ...
https://endless-sphere.com/forums/viewt ... 1#p1077497
It's 2018 already, lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
ScooterMan101   1 MW
Post by ScooterMan101 » Jun 15 2016 1:54am
Leo,
I await your review on how well your Q100 c CST, and the 6 fet Infineon controller works together, since this is the first time I am seeing/hearing about that motor/controller combination .
and how it wires together .
leo99   100 W
Post by leo99 » Jun 15 2016 2:05am
I'll do a quick ride tonight and a few pics if it isn't raining.
I am in the exam session for the next weeks so I won't have much time to finish the build properly. The quick ride I did the other day went perfectly well. I still have to solder everything definitively but it seems to work perfectly.
leo99   100 W
Post by leo99 » Jun 15 2016 3:11pm
Hi guys,
This is what the bike looks like at the moment. I just strapped the battery and the controller in the bag. I am loving it :D
I am getting 36km/h without pedalling when the 14s battery is fully charged and I get 40km/h when pedalling. It climbs well it I come up the Hill with some speed.
The motor growls a bit under 15 km/h but since I don't use the motor at those speed there is no problems.
The controller goes well with that motor it seems but since it is my first hub motor I can't really compare.
I'll solder all the wires when I have some time. :)
leo
motomech   1 GW
1 GW
Post by motomech » Jun 15 2016 4:47pm
ScooterMan101 wrote:Leo,
It's really not a combo that makes a lot of sense.
The thing that makes an Infineon 6-FET special is it can produce a lot of power in a tiny package, more than a Q100C can handle on a regular basis. So, if one has to "de-tune" it, and don't run high Volts(of which the Q100 is limited as well), why spend the extra money for one?
To connect to a Cycle Analyst?
Well, I like CA's and started out with one. But, again, the CA really comes into it's own with more powerful systems where the limiting features are useful. The Q100 doesn't need throttle modulation.
For me, as the years go by, I care less and less about info. These day, I'm happy with just my Luna Cycle "pancake" Voltmeters.
For those who want lot's of info and the best low-cost PAS, a sine wave and the LCD-3 is the best running mate for the Q100.
Spend the money you save on batteries :lol:
P.S. The Grin/Infineon is better suited to larger mini's like the MXUS, the Outrider, or some of the larger Bafangs. I have run the 20 A Grin and a 22A Lyen Mini-Monster on a MXUS and it was a hoot. I could pretty much spin the frt. wheel at will. The Lyen especially was a "hot rod" controller.
Motomech
leo99   100 W
Post by leo99 » Jun 16 2016 12:29am
I think it makes sense if you don't want any screen and since I run it at lower values I can hid it in a bag without any fear of overheating.
Leo
motomech   1 GW
1 GW
Post by motomech » Jun 16 2016 2:32am
There are lot's of plain $15 controllers.
Elifebike has a new 6-FET, 48V, 500W unit, $14.
Available on Ebay too.
http://www.elifebike.com/peng/iview.asp ... QE34.0KCJE
Motomech
leo99   100 W
Post by leo99 » Jun 16 2016 4:21am
You have a good point there :D
Well I am happy with my purchase and the garantie of em3ev if anything goes wrong but maybe next time I will go a different way. :wink:
ScooterMan101   1 MW
Post by ScooterMan101 » Jun 19 2016 4:08pm
motomech,
That price is incredible low ! Did not figure out shipping cost though.
I paid between $ 45-$50 with shipping cost for the kT that I got.
I do see the advantage of such a cheep and smaller controller, .... if it works as well as a $ 60 ( before shipping ) one,
However
I see that it, just like mine is limited to only 14 amps, ( mine says 14 amps +/- 1 amp )
I have the 201 rpm speed Q100c CST as well, and the controller is 48 volt.
I want to get the best hill climbing performance out of that Q100c CST motor that I can, since I live in an area with Mountains all around me.
you are running your Q100 H motor at 17 amps, is that at 48 volts ? Have you Run a Regular Q100 ( non H ) at Higher Amps Continuously at 48 volts ?
Have you taken a KT Controller that is 14 amp max
And
Done a Shunt Modification ?
I see the Shunt at the end of the controller, and from a past post from John in CR, from 2011, he shows how to do it better,
https://endless-sphere.com/forums/viewt ... =2&t=31643
by wrapping some small guage copper around it .
How many wraps ( number of wires ) , and of what guage would bring it up to around 17 amps ? ( if you have done this to a small 14 amp controller )
Is there a way to then measure current with a simple volt meter ? to see the before and during and after modification , in order to get it right, meaning not too many amps.
or
Link to a small meter , that would measure it ? ( I would hook the meter up to the shunt with alligator clips ?, or is there / place to connect a display/meter to measure it? Anyone done a shunt mod of just a couple of amps ?
Bigmoose has a different way of doing it, but it seems much more likely to mess something up.
the simple method of wrapping some thin copper wire around the shunt , for simplicity sake is the way I would do it.
motomech wrote:There are lot's of plain $15 controllers.
pascal.desmet@telenet.be   10 µW
10 µW
Post by pascal.desmet@telenet.be » Sep 12 2016 3:20pm
Hello Leo99,
I'm working on almost the same config as yours. stealth 26" commuter bike, high cruising speed (35-40km/h)with only minor assistance needed. battery range for 15 km. I read most of this post but I did not find which type of battery you finally chose. Could you give me some more information about that?
I plan to use the Q100 rear version 326 rpm at 36V. Anyone using the typical hooverboard batteries?
https://www.google.be/search?q=hoverboa ... B&dpr=1.65
bad idea?
ScooterMan101   1 MW
Post by ScooterMan101 » Sep 18 2016 12:53am
Hoverboard Batteries a ... Bad Idea,
From the link you provided they are expensive at $ 249 per 36 volt / 4.4 amp hour pack.
the amp hour is low, the 22 is printed on each cell , which I think means only 2.2 amps per cell ( 2200 Milli Amp Hours ),
that is low by today's standards, most today are 2900, 3200, even 3500 for the Newest Panasonic GA Cells
and
They do not say what the continuous amp draw is .
Best to use one of the trusted vendors that get good reviews here on E.S. in
regards to the battery's they sell.
pascal.desmet@telenet.be wrote:Hello Leo99,
bad idea?
leo99   100 W
Post by leo99 » May 12 2018 12:00pm
Hi guys,
I know it has been a while.
I haven't been riding much but here is what it looks like now.
I have been hitting 40kmh when pedaling with a fresh battery :D
I have changed the front chainring since that picture and replaced it by a 48 tooth since I was going faster then expected :wink:
leo99   100 W
Post by leo99 » Aug 15 2018 2:06am
Hi,
I ended up selling the bike even if it was a lot of fun. I will be building a new single speed road bike that is legal in my country so that means 25kmh limit and PAS only
