Hyper Motobike E Bike 20''
beatsdddx   1 µW
Post by beatsdddx » Aug 10 2016 12:34am
500 max peak Rear-wheel hub motor
One 36-volt battery SLA
Batter charge time: 12 hours; 4-hour run time
Number of speeds: 1
36-volt twist-throttle power assist
Front and rear suspension steel frame
Front and rear disc brakes
20" x 2.75" knobby wheels
Deluxe padded seat
Resin pedals
Maximum weight capacity: 225 lbs
Dimensions: 57"L x 23"W x 37"H; weighs 70 lbs
Stripped off all of the crazy decals, needs a stronger
shock way to bouncy. Plan to upgrade power top
speed is limited to 11 mph. You must peddle
first to engage electric motor. Seems very
solid and mostly made of steel. The seat is rock hard
but it's fun and the very compact size is cool.
Much lighter and easier to handle then my
full size Fusion Prototype 1000w 48 volt.
Would like a controller and upgraded batteries.
I would be happier with 25 mph + top speed
and 20 mile + range. You never know what
you can find on C.L. I have had it less then
a month and a half. Only thing the bike needed
was a crank arm for the left side found one
for 15 bucks installed at my local bike shop used.
Ride with the wind and flow with the current.
ebikemark3   1 µW
Re: Hyper Motobike E Bike 20''
Post by ebikemark3 » Mar 12 2018 3:56pm
Hello,
I just picked one up on CL but cannot get it running. Do you have the manual or wiring diagram for the controller ?
Thanks
Mark
Dauntless   100 GW
Post by Dauntless » Mar 13 2018 12:05am
Where is the controller? I experimented with the XGames bikes that's based on, didn't work out well. Very hard to work on and attach things.
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
skeetab5780   10 MW
Post by skeetab5780 » Mar 13 2018 7:41am
That thing is sweet! I remember about 8 years ago before ebikes were cool I was eye balling these bikes big time to try and make something for an adult but never got around to it...
Id order a cheap 750lb spring get a lyen 12fet and some lithium and be riding at 30mph in no time! Upgrade the front end when you got the cash $$
Dauntless   100 GW
Post by Dauntless » Mar 14 2018 12:42am
I don't know there's a problem with that rear spring. But the forks are terrible.
- Arthur C. Clarke
Infinite Range   1 µW
Post by Infinite Range » May 05 2018 12:29am
Nice work! :wink:
Do you have a link to the handlebars that you are jusing? Looks like a bmx handlebar :?:
Thank you very much!
