LR Big Block and Luna Cargo Frame
jpgey   1 kW
Post by jpgey » Aug 17 2016 8:01am
Hello, what does TNT ship to me ?:
jpgey   1 kW
Re: LR Big Block and Luna Cargo Frame
Post by jpgey » Aug 17 2016 8:02am
Something with an IS brake mount ! :lol:
jpgey   1 kW
Post by jpgey » Aug 17 2016 8:04am
Time to lace a 135mm rear hub :
jpgey   1 kW
Post by jpgey » Aug 17 2016 8:05am
203mm disk
jpgey   1 kW
Post by jpgey » Aug 17 2016 8:24am
Wolfeman   100 W
Post by Wolfeman » Aug 17 2016 8:37am
Keep the pics and updates coming, been contemplating something similar. Can't wait to see your progress. Thanks for posting.
Trek 4300 w/ H3580 Crystalyte at 3600W
https://endless-sphere.com/forums/viewt ... =3&t=82738
Worksman Mover M2020-3CB w/DD 750W front hub
https://endless-sphere.com/forums/viewt ... =3&t=96873
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:00pm
This is a frame, a real frame:
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:01pm
Amazing soldering job:
Edit: aluminium for the frame
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:02pm
This is hand made steel solder:
Edit: Al, tube full filled Al
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:05pm
You can take the battery box apart:
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:06pm
Will this battery fit this box ?
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:08pm
unfortunately no, but this is not an issue
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:14pm
Battery is 30Q 20s6p from the only trustable french battery dealer, i congratulate http://www.b-volt.com
All others dealers ( http://www.batterie-express.eu/fuckyou ) or http://li-tech.fr/fuckyou ) are shit and don't even know what there own job mean.
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:20pm
LunaCycle send some "ikea style" explanation to get the frame up:
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:25pm
Time to get a seat post
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:44pm
Get some light
Cheap and too much blue white led
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:45pm
New heatsink:
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:46pm
New warm white led:
jpgey   1 kW
Post by jpgey » Aug 17 2016 2:47pm
neptronix   100 GW
Post by neptronix » Aug 18 2016 3:07am
What are your plans on compressing the dropout enough to keep the wheel in it?
I recently received one of these frames and noticed that the dropout is more like 140mm.
That's a problem with a quick release wheel.
Nice frame otherwise. It just needs a special axle.
My first major build: 8T MAC motor on a Trek 4500.
The new all-arounder: Leafmotor 1500w on a Turner O2 full suspension.
jpgey   1 kW
Post by jpgey » Aug 18 2016 3:55am
neptronix wrote:What are your plans on compressing the dropout enough to keep the wheel in it?
Hello Neptronix, you are right, my rear dropout is also 140mm, perhaps i will add washers, i will see tonight
bowhunter29   1 W
1 W
Post by bowhunter29 » Aug 18 2016 7:35am
jpgey wrote:unfortunately no, but this is not an issue
I found that trimming off the two middle mounting tabs allowed my battery to drop right in. There's no need for six bolts to hold the side panel on.
What rear hub / gear system are you planning on? So far I've run an N360 (broke it on my first hard ride by accidentally punching the throttle) and the Nexus 3. The Nexus 3 has only seen very light duty after I modified it to fit the frame and increased its durability by JB Welding the sprocket onto the freewheel. I'll update the details in my build thread soon.
The only real options for gearing are single speed, the new LR gears that Mike is developing, or the Rohloff.
Thanks,
Jeremy
jpgey   1 kW
Post by jpgey » Aug 18 2016 2:17pm
Then, unfortunately I received 2 front fender and no rear fender, :(
jpgey   1 kW
