Drew12345 Trek Fuel Ex7, BBSHD, Battery in Saddle
drew12345   10 kW
Post by drew12345 » Sep 07 2016 9:39am
Starting a new build. Wanted something that was more of assist mode, quiet, and mid drive. So found a complete bike with BBSHD on Luna Cycles. However, ended up finding a super deal for same bike on ebay. So ended up buying just the bbshd and battery from Luna. I also got the color display. In addition, I got the 52v, 6ah, 30q mini cube battery. Plan is to put in saddle bag under seat.
Dogboy1200   100 W
Re: Drew12345 Giant Stance 2, BBSHD, Battery in Saddle
Post by Dogboy1200 » Sep 07 2016 7:23pm
Looks sweet! I see your in Maryland too. Hit me up if you wanna ride some trials sometime. Got some sweet trials nearby in burtonsville.
2007 Transition Preston FR BBS02 https://endless-sphere.com/forums/viewt ... 28&t=73635 Now HD https://endless-sphere.com/forums/viewt ... &start=225
2006 KTM 250 XC-W
2005 crf50 stunt bike
Oset 12.5 (son's bike)
PW50 (son's bike)
Mongoose Kids Fat Bike BBS02 https://endless-sphere.com/forums/viewt ... =6&t=84133 https://endless-sphere.com/forums/viewt ... e#p1232034
drew12345   10 kW
Post by drew12345 » Sep 08 2016 10:07am
Thanks. Sounds good. When I get this bike up, let's do that.
drew12345   10 kW
Post by drew12345 » Sep 09 2016 6:51am
K, have an issue. I have the wrong length BBSHD. This bike actually needs the fat version which I never expected for reg mountain bike.
So I contacted Luna. He said I can exchange the motor. I just need to pay shipping. But I may do 3rd option and install on my other full suspension bike which I may do. It's trek fuel ex7 and what I installed the cyclone on.
I've been thinking more about how I don't like how low the motor hangs down on this bike. That means I would need to sell this bike which I don't feel like it. I got such a good deal that I may even may make a profit if I do sell.
drew12345   10 kW
Post by drew12345 » Sep 18 2016 1:19pm
To get this press bottom bracket out, I went to Home Depot and made this tool to pop it out. I did same thing for my headset.
drew12345   10 kW
Post by drew12345 » Sep 18 2016 1:21pm
So I mentioned above that this motor was wrong size. So I didn't feel like sending back so putting on my other bike a trek fuel ex7 full suspension.
drew12345   10 kW
Post by drew12345 » Sep 18 2016 1:24pm
Charging up battery using charger from em3ev I had sitting around. Luna said it was fine.
drew12345   10 kW
Post by drew12345 » Sep 18 2016 2:44pm
So it maybe hard to tell but the Luna 42t chain ring is NOT offset enough. The chainring lines up with 2nd smallest. It needs to be over at least 2 more cogs to have decent shifting.
I even have the motor moved all the way over. So will need to put the original chainring back on. Contemplating getting the Luna eclipse which would fix it. It's $100 though.
Why would they make the motor like this?
drew12345   10 kW
Re: Drew12345 Trek Fuel Ex7, BBSHD, Battery in Saddle
Post by drew12345 » Sep 19 2016 1:00pm
I put the original bafang chainring back on. Much better shifting now. I have bike in decent state to take out for a ride and work out any kinks. Since this post, I also added the gear sensor. It's raining now so can't take it for ride on street yet.
Also, won't ride on trail for couple weeks. I busted my back again doing too much regular riding. Which is why I have electric bike in first place.
skeetab5780   10 MW
Post by skeetab5780 » Sep 19 2016 2:02pm
Nice build! I always wanted to try a BBS build but have still yet to take the plunge...
I like the Luna battery it seems like everyone(including myself) this year are trying the Luna batteries since they are the only ones reasonably priced. I have only discharged mine about 2 times so far so I don't have much feedback yet.
How is the mighty batt?
drew12345   10 kW
Post by drew12345 » Sep 19 2016 6:34pm
Thanks Skeetab. I'm going for first ride tomorrow. I will record my maiden voyage. I can't do anything crazy because my back is sore now. But will get an idea how it performs. With this setup, I'm assuming will max around 31 mph. I will mainly use for trail so more than fast enough.
My plan is to buy another mighty battery and eclipse chainring for the trail.
drew12345   10 kW
Post by drew12345 » Sep 19 2016 6:36pm
Here is Weight of bike with battery....45.14 lb/20.48 kg
skeetab5780   10 MW
Post by skeetab5780 » Sep 20 2016 7:31am
Wow that's nice and light! Have you gotten a chance to check the range of the bike with that pack?
drew12345   10 kW
Post by drew12345 » Sep 20 2016 9:02pm
I went for first ride today. I got a little less than 7 miles on 6ah battery. However, I only charged to 80% because I wanted to get more cycles out of it. But now I changed my mind. From now on, I will charge it all the way and see how it does. I'll let you know.
Overall, I really like the BBSHD kit. Even though this mid drive is not as powerful as my aft mid drive, it's compact, quiet, reliable, and seems has enough power for the trails. It was simple installation. I rode it pretty hard for less than hour. It was warm but not hot. Again, will see after I ride on the trails.
I'm not sure about the battery yet. It's nice and compact, but heats up fast. It was so hot after my ride today it wouldn't charge. My display cut off also at end of my ride. Most likely ran out of juice and not from heat. I'll keep testing it and see how it does on the trails. I may have to put some holes in the saddle to get some air flow. I may need to get bigger battery if continues this way.
drew12345   10 kW
Post by drew12345 » Sep 22 2016 11:56am
Went for another ride. Almost same route. I got 10.33 miles on full charge. Mostly flat with some rolling hills in there. I was mainly using pas 3 and 4 out of 5. I vented the saddle and battery was slightly cooler but still hot.
Alex07   100 W
Post by Alex07 » Sep 23 2016 5:21pm
From the video where have you mounted the camera as its the first time i have heard the BBSHD gear wine ? its not loud but it's not silent either ? i.e most people say its quiet like a hub is that true or not its hard to tell maybe its the mike placing that extenuates this ?
drew12345   10 kW
Post by drew12345 » Sep 24 2016 7:28am
The bbs is very quiet. I don't even notice it. I had the aft mid drive and that was loud even with all the sound damping stuff on it.
It's one of the main reasons I like the BBSHD. I'm really waiting one day for a powerful mid drive that is just as quiet. Not sure when that day will come but it's getting closer.
I know people are putting external controllers with BBSHD and even Luna came out with more powerful controller for this as one step. I'm not sure how quiet the direct mid drives are out there?
drew12345   10 kW
Post by drew12345 » Oct 06 2016 3:47pm
My motor came loose first offroad ride so I bought the socket from empowered to tighten the inner lock ring. I couldn't tighten enough with Luna tool. Now I can use my torque wrench!
Got here in 2 days. I love getting bike tools. Note: it does look slightly used though. But this tool will last forever so I'm fine with it.
drew12345   10 kW
Post by drew12345 » Oct 07 2016 6:27am
So the other day I did first offroad ride on this bike. It was really fun. This bike is so light and the bbshd is an awesome kit. Really like it. It's plenty fast for trails around here. I tightened the motor down with socket above so look forward to next ride.
I also got a pinch flat towards end of ride. I think pressure was low and didn't bother to check. But having mid drive makes it easy to change flats! Working on vid.
drew12345   10 kW
Post by drew12345 » Oct 11 2016 7:00pm
So tightened motor down and next ride, it still came loose!?
So, something is not right. I didn't add any spacers because it lined up just right. But it might be a small gap that I couldn't see. So I decided to add a thin bb spacer (which kit came with several). But in my effort to put everything back together, I accidentally snapped a m6 bolt. I was using my larger torque wrench and was using lowest setting but I don't think it worked in this setting and over tightened.
Anyway, I had to go hardware store and get screw extractor and harder drill bit. I then drilled out center, cut the left over bolt on other side, and then used the extractor. Thank God it came out. I then used my smaller torque wrench to finish install.
Went for ride and seems to be holding now. Will see next few rides.
drew12345   10 kW
Post by drew12345 » Oct 11 2016 7:05pm
I think this motor is really good for tight single track. It has just enough power, stealthy, light and quiet. Add the mid drive advantages and makes it really fun for the trail. I've been having a blast.
Alex07   100 W
Post by Alex07 » Oct 12 2016 12:47am
i have seen a few people notice this movement its not very secured on an aluminum BB face and just that tab, be careful that it can also damage the BB face as it moves up and down its one of the main downsides of this kit compared to the ISIS BB midrive kits.
drew12345   10 kW
Post by drew12345 » Oct 12 2016 8:29am
K, thanks for the tip Alex.
skeetab5780   10 MW
Post by skeetab5780 » Oct 12 2016 9:08am
Looks like you are having fun! Glad to see you are getting full capacity from your pack too! Weird that the BB keep loosening...I've never owned one so don't ask me :)
drew12345   10 kW
Post by drew12345 » Oct 13 2016 3:48pm
Thanks Skeetab. How's the beta going?
Got a infrared thermometer. Will be checking temp of motor and batteries for fun. Only $15 from Amazon.
