Nyx frame, 273mm*40m V3 hub, and 650A
liveforphysics   100 GW
Re: Nyx frame, 273mm*40m V3 hub, and 650A
Post by liveforphysics » Sep 26 2017 4:23pm
atarijedi wrote:I wonder if its the new APT controller, the APT96800.
Not APT, though I wish them and every other controller mfg well.
I wasn't expecting this, but it looks like a new ASI may be the first controller for the bike. 8)
st35326   100 W
Post by st35326 » Jan 04 2018 3:54am
Luke, any updates on this build? Ive been looking forward to this for some time.
Rix   100 GW
Post by Rix » Jan 04 2018 1:51pm
st35326 wrote:
Jan 04 2018 3:54am
I figured Luke may be using the completion of this build as a part of his 2018 resolution :wink:
Post by liveforphysics » Jun 12 2018 8:37am
The ASI BAC8000 controller is amazing and will do 730amps phase current RMS, however it wouldn't quite package flat inside the NYX frame by a bit overly wide. :(
Stock ASI BAC8000 dimensions:
Stock thickness:
So I put it on the milling machine and experimentally cut into it until I found the threshold of cutting into the components inside, but managed not to damage it functionally. Woot!!
I was able to machine it so narrow it fits inside frame with plenty of margin for fitting cabling along side it even!
New with of modified controller:
macribs   1 GW
1 GW
Post by macribs » Jun 12 2018 11:02am
Maybe you can do an external heatsink thing if needed? 700 + amp I guess that will turn into some heat at the controller as well.
If you check one of the builds done by madin88 he had a clever solution where his adaptto was mounted inside the frame box and was connected to an alu heat sink sitting outside on the downtube section providing ample cooling.
That is one sick controller. Look forward to see what you can do with that thing. Should be some sick numbers. Planning any more trips to the drag strip now that you got a manly new controller?
litespeed   100 kW
Post by litespeed » Jun 12 2018 4:01pm
Wow.....730 amps.....wow!
Tom
Rix   100 GW
Post by Rix » Jun 12 2018 5:03pm
litespeed wrote:
Jun 12 2018 4:01pm
Tom
You said it. Glad Luke is getting around to getting this kick a$$ build going. Been waiting for the end result for a while.
Post by liveforphysics » Jun 12 2018 5:22pm
You and me both!!
Ohbse   10 kW
Post by Ohbse » Jun 12 2018 5:34pm
Nice work! Any chance we can see the internals on the BAC? You're most of the way there already ;)
Post by liveforphysics » Jun 12 2018 9:52pm
I want to see the guts as much as anyone. That orange cover is held on super well somehow. I will see if i can pry it up.
John in CR   100 GW
Post by John in CR » Jun 16 2018 8:15am
How does RMS for phase amps compare to the phase amps commonly quoted, like by Kelly? Since the energy can't just disappear, wouldn't RMS phase equal battery amps (excluding some losses obviously). I've done 500 battery side going into a 273x50 on 130lb ebike, but I weighed 80lbs more than now, so I know I couldn't handle 700+ with your trimmed weight and a light bike.
You gotta get back down. I'll build a bike for my 273 a bit lower and longer than your NYX, so you can put more power to the road with it. It's a whole new world down here since those underpowered ebikes we rode when you were here 8 years ago. You need a vacation anyway.
Stealing a movie quote, nothin but love my friend.
Post by liveforphysics » Jun 17 2018 4:40am
You rock John! It will be a pleasure to ride your recent ebikes exploring CR together.
Im so grateful for your bikes showing me hubmotors can be powerful beasts, a big inspiration behind doing this build. Thank you!
tahitiboob   1 W
1 W
Post by tahitiboob » Nov 03 2018 6:05pm
hello
do you have news because i have the same project
what kind of battery do you use for this project
thanks
Rix   100 GW
Post by Rix » Jan 01 2019 12:10pm
Any updates Luke?
