Nyx frame, 273mm*40m V3 hub, and 650A
Doctorbass   100 GW
Re: Nyx frame, 273mm*40m V3 hub, and 650A
Post by Doctorbass » Oct 20 2016 8:38am
Luke i m using the ZERO rear shock (Fastace) and it work very well ! This is coming from a DS. Model is BDA53AR.. the front fork i use is the White Brother from the ZERO mx 2009. Both are very tough. Btw the white brother fork is extremely strong!! It was also capable taking 250A phase on the front12kv mxus motor i installed on when the ebike was 2wd for couple runs.
Doc
CURRENT PROJECT: 2WD duo MXUS/Max-E ebike 32kW
http://endless-sphere.com/forums/viewto ... =3&t=65764
-Fastest speed record 117 km/h on flat
-Fastest 1/4 mile@ 114km/h on flat and 16.316 sec
113kmh Gianthttp://www.evalbum.com/3406
Mongoosehttp://www.evalbum.com/1947
YOUTUBE---https://m.youtube.com/user/Doctorbasss
I speak FRENCH and english
steveo   1 MW
Post by steveo » Oct 20 2016 9:06am
650A.. thats it :lol:
Very nice Luke, I gotta ask, what controller are you running?
I can tell you, on my experience.. with my 18ishkv six phase Hubmonster motor advertised at 97% efficiency rating.. .. with dual Adaptto Max e at full power.. 400 battery --- 500-600ish phase amps.. i can get a couple pulls at full power before she hits 100 degrees.. i'm running a moped tire.. that has a diameter of around 21". The motor is still factory sealed.
I'd like to try some ferro Fluid, but i have not gotten there yet, the next piece my bike needs is a new strong front fork & tire/rim.
Good luck with your build
Doctorbass wrote:Luke i m using the ZERO rear shock (Fastace) and it work very well ! This is coming from a DS. Model is BDA53AR.. the front fork i use is the White Brother from the ZERO mx 2009. Both are very tough. Btw the white brother fork is extremely strong!! It was also capable taking 250A phase on the front12kv mxus motor i installed on when the ebike was 2wd for couple runs.
Doc
This Explain why i could not find this fork when i was looking.. it is from a zero!!!
thanks Doc
-steveo
Repair Thread
http://endless-sphere.com/forums/viewto ... =3&t=27170
Hub Monster bike ~ 24s7p A123 15.4ah/18kv Six Phase Motor/Dual Max-E Adapttos/32kw~42.91Hp/Est 140LBS
X6 Kmx Trike ~ 24s4p 20ah/X6 MHM 602/Infinion EB324 IRFB 4110/20Kw~26.82Hp/Est 120LBS ~SOLD~
Lightening rods bike ~ 18s2p 10ah/1500w Inrunner/Infinion EB312 IRFB4110/2KW~2.68hp/Est 60LBS
EV Outboard ~ 12s8p 40ah/5KW GM Inrunner/Infinion EB324 IRFB 4110/18Hp Evinrude Drive/Est 100lbs
http://www.youtube.com/user/trdfreak03
liveforphysics   100 GW
Post by liveforphysics » Oct 20 2016 6:02pm
Doc
If you think that old white brothers fork works well (I ran it on multiple death bikes), you gotta try a Fox40. It's unbelievably rigid and smooth with super low stiction.
This is the 2016 world cup downhill finals. The winner of the event is running the same fork I'm running, and it's been setup by Fox's own factory RnD crew for my application. It should be capable of plenty more than my balls permit on a bike. http://www.redbull.com/en/bike/stories/ ... nning-runs
Something neat about air-suspension is the ability to adjust effective spring rates in 30 seconds or so for free to tune in the vehicle to the type of riding you may be doing.
macribs   1 GW
1 GW
Post by macribs » Oct 20 2016 7:57pm
This I gotta follow.
brumbrum   100 kW
Post by brumbrum » Oct 21 2016 1:22pm
Ive got to agree that air suspension is smoother amd more progressive that springs, and fox 40's are the drooling roll royce of forks. I got to get some, but cant get past the price tag. I am luckily enough to live down the road from the only U.K Fox registered distributors who offer a free bespoke consultation setup to your bike and weight and ride type when you buy the fox 40's from them. But i dont know whats worse, spending the dough or be blanked and made to feel guilty and selfish by my 'trouble and strife' for several months. :roll:
My NYX and cromotor build
viewtopic.php?f=6&t=74615
My LMX 161 dirt bike build
viewtopic.php?f=6&t=94074
Ohbse   10 kW
Post by Ohbse » Jan 04 2017 11:48pm
Any updates luke? I know you've been flat out
Post by liveforphysics » Jan 05 2017 2:07am
Ohbse wrote:Any updates luke? I know you've been flat out
It's got its belt drive parts finally done, got a custom Ti spring set in the Ebike spring rate and damper cartridge. So it can be pedaled around now.
Waiting on some very special pouch cells to arrive for it, and potentially a different controller option with more than 650A phase current as well if it can be made about 10mm thinner to fit inside the frame. I'm not a big fan of having the controller external if I can avoid it, because I like to ride rocks and tree roots and I love being able to crash or bail off as needed and not have wires get ripped out.
madin88   100 MW
Post by madin88 » Jan 05 2017 6:05am
yeah, better you allow enough time for building it solid (thinking of builders who install the components with duct tape) :mrgreen:
- 10kW belt drive with Neumotor 8057: viewtopic.php?f=30&t=91144&start=50#p1377787
- Fully road legal (L1E approval) e-bike based on Votec V-FR frame
/ MXUS 3T / 17" Mitas MC11 / Adaptto Max-E / 20s12p 25R
- KTM Hardtail Pedelec / eZee V2 6T / 27,5" / Kelly KBSX @ 1,5kW / Torque PAS / CA-V3 / 13s4p Sanyo GA in Shark case
gogo   10 MW
Post by gogo » Jan 05 2017 11:51am
brumbrum wrote:Ive got to agree that air suspension is smoother amd more progressive that springs
With any sealed hydraulic fork, there is some air adjustability that comes from adding or subtracting the oil volume. My 1977 Kawasaki KE125 had neat fork cap nuts that have a screw in the middle of them. This made it easy to change the oil level without releasing the spring tension.
"A conclusion is the place where you got tired of thinking." -Steven Wright
Quokka   1 kW
Post by Quokka » Jan 15 2017 1:38am
Hey Luke, could you post some photos of the brake side of the motor if its all installed? Interested to see if you were able to squeeze the calliper in there and to see what/ if any machining was required?
Qulbix Q76R+ QS205+MaxE
Post by liveforphysics » Jan 15 2017 2:02am
Quokka wrote:Hey Luke, could you post some photos of the brake side of the motor if its all installed? Interested to see if you were able to squeeze the calliper in there and to see what/ if any machining was required?
It's not at my house right now, but hopefully Monday I can get a picture.
ninepointeight   1 W
1 W
Post by ninepointeight » Jan 17 2017 11:35pm
Looks like an awesome bike, I am sure it will be a blast (hopefully no combustion).
I am building a wheel with a QS 273, and there isn't a ton of info on here about them.
What gauge spokes are those? And are you are going to upgrade the phase wires on it? They ones that they put on there seem hardly adequate.
You are a legend!
Post by liveforphysics » Jan 17 2017 11:59pm
ninepointeight wrote:Looks like an awesome bike, I am sure it will be a blast (hopefully no combustion).
You are a legend!
I had some special requests when I ordered my motor, including that the phase leads be as large as they could possibly fit through, because I've upgraded the phase leads of every other hubmotor vehicle I've ever had and it's quite a few hours of work an I would happily just pay extra to have them do it on initial assembly.
I also got a very high 16.8kV winding, so this setup really only works well with big phase current, but should be very efficient with a powerband that has silly top-end speed.
With respect to lacing the wheel, it would be so much stronger if QX motor would spread the spoke flanges out to the far outsides of the magnet/rotor ring assembly. They are only about an inch apart, and this means reduced spoke angularity possible in lacing to get the wheel robust to side loading.
I left the spokes and sizing in the hands of a friend who did world-cup downhill bike rims and motocross racing wheel lacing as well for many years. His name is Jamie, hugely talented on a bicycle and motorcycle, and he is one of my favorite folks on the planet to ride with, and he is the guy who assembled the longest lasting of the deathbike wheels. Next time I visit the bike I will take a measurement and photo of the spokes and layout.
Thank you for the kind words. Enjoy life!
fechter   100 GW
Post by fechter » Jan 18 2017 12:38am
That's going to be really nice when you get it done. Like a pretty version of Deathbike.
What's your predicted top speed?
Post by liveforphysics » Jan 18 2017 1:37am
fechter wrote:That's going to be really nice when you get it done. Like a pretty version of Deathbike.
I'm going to push a lot of timing advance and should easily have >100mph.
VoKuS   100 W
Post by VoKuS » Jan 18 2017 8:29pm
Awesome looking bike!
I have a few questions.
1. Where do you get a motor like this?
2. How much power can this motor take continuously with out over heating in California heat of about 80F / 26C ?
3. What is the recommended voltage to run this motor at?
4. What is the recommended controller to run this motor with?
'The Hyena Industries GoPro A Team' ! :)
Baron   100 W
Post by Baron » Jan 18 2017 9:20pm
Looks like a QS motor,
http://www.cnqsmotor.com/en/article_lis ... or/90.html
They have spec sheets on each individual motor page. Also comes in a cast scocter rim, pretty cool
http://www.cnqsmotor.com/en/article_lis ... /89_3.html
Post by liveforphysics » Jan 19 2017 12:13am
QS motor made the hub.
For the rest of your questions, let me get her on the dyno and I will let you know. :-)
VoKuS wrote:Awesome looking bike!
Im_Getting_Better   1 mW
Post by Im_Getting_Better » Jan 23 2017 4:13pm
That Motor looks insane in the wheel! Sub'd.
Post by liveforphysics » Jan 28 2017 6:13pm
No rear brake mounted yet, Jamie is still working on that. No battery or motor controller installed yet either, but that's the last things needed to rip!
Rube   100 W
Post by Rube » Jan 28 2017 6:56pm
Great photos, why did you choose the belt drive? Less maintenance and cleaner?
Talk about building suspense before the controller and cell reveal :) I'm really looking forward to hearing the details.
Cheers
litespeed   100 kW
Post by litespeed » Jan 28 2017 9:32pm
That looks just awesome!
Tom
Post by liveforphysics » Jan 29 2017 3:18am
After +20years of riding chain bicycles/ebikes/dirtbikes/motorcycles daily, I finally tried a direct belt-drive system and was instantly in love with no back-lash and silence and have never been impressed or pleased with a chain-drive vehicle since (I'm a notorious destroyer of roadbike pedal chains on my pedal only cyclocross bike running all dura-ace and ultegra parts). That freewheel is the only pricey part in that setup, white industries charges 4-5x what I think is fair to pay for that freewheel, but I understand they likely only sell a few a year and it's gotta be a PITA to fixture up to machine for something so low volume. It's way cheaper for bikes with cassettes to convert to belt.
The bottom bracket Schlumpf drive is the option you can order from Nyx, and it lets you pedal at a ratio where it's like your front sprocket is 80-100t around or something close, while keeping the overall sprocket diameter smaller for clearance on rocks and obstacles and things. It adds loss to the human pedal input, but its better to have lossy human pedal input than not be capable of pedaling at all at 35-40mph, as you're mostly pedaling for exercise and the joy and fun of pushing pedals anyways.
Post by liveforphysics » Jan 29 2017 3:42am
Rube wrote:Great photos, why did you choose the belt drive? Less maintenance and cleaner?
Cheers
You and me both are in suspense!
If I can hold *~64v under load, the motor base speed with no timing advance/field weakening yields 80mph vehicle speed. I know it's no trouble to get another 30->35% RPM through field weakening (at the cost of efficiency/motor heating), so it would seem likely the bike should be capable of over 100mph even towards the low end of the pack's SOC.
100mph is like the new 60mph for hotrod ebike builds today anyways.
People a decade in the future with 10x better mosfets/ganfets/sicfets and 10x better solid state batteries and possible room temp superconductor windings and grain-oriented magnetic materials for motor cores will be laughing about the size and weight and hassles of making a 100mph hubmotor ebike in 2017.
Ypedal   100 GW
Post by Ypedal » Jan 29 2017 7:38am
that is one sweet looking rig !!.. jealous. 8)
ES site status page:
