Rix wrote:my question was, you can insert just about any value, doesn't mean it will work though. Otherwise I would put 200% thinking the bigger the number the better
heh yeah within reason. It think 120% is actually as high as you can go, though that's on infineon style controllers and the newer sine ones seem to allow the equivalent of higher % ratios. I guess they channel the dark arts better than their predecessors.
I do find some utility in having lower speed settings and with the CA taking an aux pot for smooth, variable power limits I've been meaning to put a dial on the top of my frame and having a custom sticker made up to go around the outside. Naturally it will go up to 11
And yeah, the atomic MkII is looking pretty sweet! I actually had more custom atomic theme livery for it but the new owner has decided not to fit it and stuck with the largely standard sticker pack for now and maybe fit it later. Once the stickers are on the either have to stay there or peel back off so you can't really change your mind much. I really must get and finish this bike off!
Here's the battery for it, an exact shape 21S12P pack that just shoe horns in there . Best of all it takes up exactly half the width of the frame, allowing the sabvoton to lay vertical along side it, with the BMS and shunt and anything else I need to put in there. I'm thinking I might actually make up a ply wood board to mount it there, so it doesnt move around. Foam would largely achieve the same but I'd have to totally surround it and jam it in tight and the floating board mount would allow greater convective air cooling.
Technically with an external controller I could fit 2 of these packs in here for 21S24P.
No, that's not a typo. With 3.5ah cells that's a rediculous 84ah and 6.5kwhr
- yellow-raptor.jpg (192.23 KiB) Viewed 4747 times
Oh yeah, and for those who aren't subscribed to my youtube channel here's my latest vid. 2 10kw raptors tearing it up
