New lighting setup for BBSHD Fat
doctorbrody   100 µW
100 µW
Post by doctorbrody » Dec 31 2016 10:57am
Here's an electric fat bike I built this fall using a Framed Alaskan Bluto from craigslist and a BBSHD motor kit from Luna Cycle. I sometimes run the 52V 6ah Mighty Mini 30Q but more often I run a 52V 17.5ah GA triangle pack. I Mad Maxed it out with some LED truck lights running directly from the main battery.
The lights are TTX Lighting 10-60V floods, $14 shipped on Amazon. I tried wiring them in parallel so I could take one off if I wanted, but the capacitors blew at 56V. Got a refund, ordered a new set and wired them in series, thus cutting the voltage in half. It's really bright - plenty of light for a 35mph bike in pitch darkness. These lights aren't for weight weenies, but neither are fat bikes.
http://a.co/bg7eRjq
I spent about $2k on this build and it's pretty amazing. Yes, I know you can buy a decent motorcycle or car for $2k. I have a motorcycle and a car already. This does things they can't do.
litespeed   100 kW
Re: New lighting setup for BBSHD Fat
Post by litespeed » Dec 31 2016 11:18am
Looks really good to me! Do you have a picture of the light they put off? As in a picture standing over the bike looking forward on the street or with woods way out there?
Since I have a big bike I wouldn't mind a bigger set of lights on mine....I always like the Baja Designs twin light for motorcycles. Always looked like the little kid with big glasses.
Tom
Wolfeman   100 W
Post by Wolfeman » Dec 31 2016 2:16pm
Your bike is very high on the scientifically respected ISB (incredibly super bitchin) scale. Nice build and love the lights. I'd also love to see a pic of the lights and the view from the cockpit. Thanks for posting.
Edit - After looking at this for another day or so, I bought two of the lights and am looking forward to setting them up.
Trek 4300 w/ H3580 Crystalyte at 3600W
viewtopic.php?f=3&t=82738
Worksman Mover M2020-3CB w/DD 750W front hub
viewtopic.php?f=3&t=96873
Dyno Moto 7 BMX Cruiser w/BBS02
viewtopic.php?f=6&p=1467001#p1467001
GT Palomar Vintage hardtail w/BBS02
viewtopic.php?f=6&t=104255
doctorbrody   100 µW
100 µW
Post by doctorbrody » Jan 02 2017 9:27pm
Here are some photos of the lights in pitch darkness. Pretty bright, yeah?
litespeed   100 kW
Post by litespeed » Jan 02 2017 9:30pm
Yeah that looks excellent!
Tom
PRW   10 kW
Post by PRW » Jan 02 2017 10:05pm
looks great - what brackets do you use/ how do you mount them?
doctorbrody   100 µW
100 µW
Post by doctorbrody » Jan 03 2017 3:52pm
I just used these House Tuning brackets from Amazon - not lightweight but very sturdy. http://a.co/3CebG0E
PRW   10 kW
Post by PRW » Jan 03 2017 4:39pm
doctorbrody wrote:I just used these House Tuning brackets from Amazon - not lightweight but very sturdy. http://a.co/3CebG0E
great, thanks doctorbrody....
Wolfeman   100 W
Post by Wolfeman » Jan 07 2017 10:17pm
I saw this post and immediately bought two of these lights to mount on my Trek. I received them tonight and mocked up a temporary bracket. Running in series off my 52V pack, they are AMAZING! I mounted them baja style on my riser bars and am researching bar mounted switch options. After leaving them on for about 5 minutes they were still cool to the touch. For the price I'd be shocked if there was a better option for ebike lights.
WoodlandHills   10 kW
Post by WoodlandHills » Jan 08 2017 11:46am
I have a set on order too!
doctorbrody   100 µW
100 µW
Post by doctorbrody » Jan 08 2017 11:52am
I'm interested to see pictures of your bikes with the lights installed -
WoodlandHills   10 kW
Post by WoodlandHills » Jan 08 2017 1:31pm
Question: where are you pulling power? From the charging xt60 or the power xt90? I have run a palm size air pump from the charge plug without problem........
Wolfeman   100 W
Post by Wolfeman » Jan 08 2017 1:50pm
WoodlandHills wrote:Question: where are you pulling power? From the charging xt60 or the power xt90? I have run a palm size air pump from the charge plug without problem........
I just tapped into the 5.5 x 2.1 mm male DC plug coming off the CA. Waiting for a new female end from Amazon so I can wire it properly.
doctorbrody   100 µW
100 µW
Post by doctorbrody » Jan 08 2017 7:27pm
I made a harness that splits the power XT90 into an XT90 for the motor and a XT60 for the lights. The positive line to the lights has a 5amp fuse and the negative line has a waterproof toggle switch that I can reach while riding. Luna advised me not to pull power from the charging port - said it might damage the BMS.
Wolfeman   100 W
Post by Wolfeman » Jan 12 2017 7:15pm
So here's what I came up with. Leftover aluminum bar stock, two rubber coated 3/4" clamps, and some nuts and bolts. Gonna take it for a test ride tonight.
vk4bxi   1 W
1 W
Post by vk4bxi » Jan 12 2017 7:26pm
Has anyone measured the current draw please.
Bob
PRW   10 kW
Post by PRW » Jan 14 2017 6:07pm
wired up in series with an on/off switch, using the 5.5 x 2.1mm CA output jack. Brackets mentioned earlier in this thread were used, attached to top of forks. Photos to follow...
WoodlandHills   10 kW
Post by WoodlandHills » Jan 14 2017 7:38pm
My lights arrived a few days ago and the brackets were just dropped off by USPS. Here is a first try at an installation on my newest project bike.
I think I'll rotate the arms on the brackets to lower the lights by 1/2". I could also rotate the bracket at an angle until the lights were at a good height and then raise the lamp.
I like the Jones H-bars because the pulled back angle put less stress on my forearms and elbows.
This is the original loop version of the H-bar with the China brackets for the lights.
PRW   10 kW
Post by PRW » Jan 15 2017 12:24am
just finished wiring and installing - great lights! Still want to relocate CA to centre, and neaten brake cables
IMG_1436 (1).JPG (108.54 KiB) Viewed 3677 times
doctorbrody   100 µW
100 µW
Post by doctorbrody » Jan 15 2017 12:36am
Those look awesome - nicely done! I want to get some H bars for my bike.
PRW   10 kW
Post by PRW » Jan 15 2017 12:42am
doctorbrody wrote:Those look awesome - nicely done! I want to get some H bars for my bike.
thanks. I am going to relocate my CA and any non-essential switches etc onto one of these, to free up the clutter on the bars.
http://www.avt.bike/WebStore/merchant.m ... Mount-Wide
WoodlandHills   10 kW
Post by WoodlandHills » Jan 15 2017 2:12pm
OK, second try at mounting the headlights:
Off topic:
Sturmey Archer 3-speed 195mm hub
PRW   10 kW
Post by PRW » Jan 15 2017 3:09pm
WoodlandHills wrote:OK, second try at mounting the headlights:
Off topic:
The lights look much better that that - looking good!
WoodlandHills   10 kW
Post by WoodlandHills » Jan 17 2017 2:46pm
Third and final try at light mounting, this time with decent brackets:
PRW   10 kW
Post by PRW » Jan 17 2017 4:36pm
very neat, WoodlandHills...
I switched my lights on while charging last night (not sure if "while charging" makes a difference). Voltage was at 92v (lights in series).
One light went "pop". I took them off, and tested - one dead, the other worked - but testing at 55v, the other then went "pop"! So, I have ordered some more - and informed the seller. I may put three lights in series, two above and one below. A bit excessive, but if it makes them work...
