leaning trike cargo bike front end kit
hodala   100 W
Post by hodala » Feb 21 2017 9:07pm
The kit fit for most traditional bike head tube inner diameter should be larger than 32mm
I'm now looking for some hub motor to fit rear wheel
hodala   100 W
Re: leaning trike cargo bike front end kit
Post by hodala » Feb 21 2017 10:26pm
Integrate frame low down the frame profile is convenient to get on and off the bike,frame space also larger for battery
Drunkskunk   100 GW
Post by Drunkskunk » Feb 24 2017 10:52am
Very nice! where did you find this thing?
hodala   100 W
Post by hodala » Feb 24 2017 11:29am
Drunkskunk wrote:Very nice! where did you find this thing?
Thanks! I create it with a mechanic in enemy country through remote controlled build by E mail
hodala   100 W
Post by hodala » Feb 24 2017 12:31pm
Some pictures of process;you know manufacturing quality is commonly NG in China,I have to fix the defects myself after received the kit
Chalo   100 GW
Post by Chalo » Feb 24 2017 1:00pm
It's a clever gadget. But having made some stuff along those lines before, I can say with confidence it's an expensive, heavy, complicated, inconvenient way to do what a two wheeler does cheaply, simply, conveniently, and with minimal weight.
I'm sure it works better than the one I made, which has a solid front axle and thus steers like a tilting bakfiets. Which is to say, not very well.
rborger73   10 kW
Location: Currently NW of Pittsburgh, next destination unknown..
Post by rborger73 » Feb 24 2017 2:02pm
Boy, that would actually make a pretty nice all in one system. How well would having dual hub motors work with the leaning? You could have the battery fit into the new second triangle. As well as the controller. You'd just have to run the throttle up to the steering wheel. Sell additional battery pack for the bikes original triangle. Could you even put a steering sensor that would slow down the inside wheel on a turn, and slightly speed up the outside wheel to make it turn easier? Your weight from the battery would be about as low as you could get it. Just a few thoughts. :wink:
hodala   100 W
Post by hodala » Feb 24 2017 2:13pm
What is that complicate heavy expensive linkage for?certainly not for the majority yet some people need it or it won't appears
You don't have to learn cornering stunt to go down gravel slop or wet and slippery winding roads
cornering 2.JPG (108.13 KiB) Viewed 6394 times
drift cornering 小.JPG (107.43 KiB) Viewed 6394 times
butcher dog.JPG (169.22 KiB) Viewed 5535 times
hodala   100 W
Post by hodala » Feb 24 2017 8:04pm
What kind of cargo bike should be better if you were goods or passenger for safety and comfortable sight seeing view ?
food delivery bike.JPG (69.26 KiB) Viewed 5535 times
hodala   100 W
Post by hodala » Feb 24 2017 8:45pm
rborger73 wrote:Boy, that would actually make a pretty nice all in one system. How well would having dual hub motors work with the leaning? You could have the battery fit into the new second triangle. As well as the controller. You'd just have to run the throttle up to the steering wheel. Sell additional battery pack for the bikes original triangle. Could you even put a steering sensor that would slow down the inside wheel on a turn, and slightly speed up the outside wheel to make it turn easier? Your weight from the battery would be about as low as you could get it. Just a few thoughts. :wink:
Tilting is independent to Steering system, it feels the same with a normal bike
hodala   100 W
Post by hodala » Feb 24 2017 11:44pm
If you guys were interested to have a leaning trike and are able to DIY frame work too,I'm planing to make a small package kit(not easy done components for DIYs :CNC axles with heat treatment,plate forming parts,knuckles sets- - )that only few hundred bucks one can have an easy work complete kit to transform a bike to leaning trike
specs 1.JPG (92.33 KiB) Viewed 5536 times
f frame cycle 01.JPG (82.51 KiB) Viewed 5536 times
Wheazel   10 kW
Post by Wheazel » Feb 28 2017 2:21am
Cool, this is pretty much the same system I built in my trike prototype for winter riding.
The background was added safety on icy roads. Which is accomplishes very well.
However it is always a compromise and it needs to be narrow enough to not be clumsy.
How wide is this front end?
What this system seem to lack are the steering spindle's rotation center projected to the tire contact area (or very close to it)
This means you get a lever that will affect the steering when you hit something with the wheel.
hodala   100 W
Post by hodala » Feb 28 2017 6:25am
Wheazel wrote:Cool, this is pretty much the same system I built in my trike prototype for winter riding.
Yes there are some geometry compromise to make maximum profits of all,I saw your avatar on website before,why I didn't incline the kingpin is to get more tilt angle
If you want to reduce scrub,build your own wheel rim like a car ones,the scrub 78mm of bike is actually 70mm
steer scrub.JPG (114.87 KiB) Viewed 5534 times
king pin inclination.JPG (104.4 KiB) Viewed 5534 times
鋁焊輪圈14x1 b.JPG (70.6 KiB) Viewed 5534 times
Wheazel   10 kW
Post by Wheazel » Feb 28 2017 7:33am
I am doing a version 2 of the tiltbike for the coming winter, it will however have 4wheels to keep the trackcount in the snow down to 2.
Also easier to avoid obstacles with 2 tracks compared to 3. But everything is compromises left and right.
Good luck with the product!
hodala   100 W
Post by hodala » Feb 28 2017 7:41am
Wheazel wrote:I am doing a version 2 of the tiltbike for the coming winter, it will however have 4wheels to keep the trackcount in the snow down to 2.
My hybrid leaning quad
Hybrid Quad bike.JPG (89.32 KiB) Viewed 5534 times
Quad4 snow2.JPG (78.75 KiB) Viewed 5534 times
spinningmagnets   100 GW
Post by spinningmagnets » Feb 28 2017 1:11pm
You sound like you are new to electric hubmotors. Until you gain some experience, I suggest a direct drive hubmotor in the rear wheel with a sensorless controller, that would be the simplest and most reliable system for a beginner. Since this tricycle attachment appears to be for street use (instead of off-road mountain paths) You will be fine if you want to choose a smaller wheel, like a 20-inch. A 20-inch wheel will run cooler and more efficiently than a larger wheel, like a 26/29-inch.
If you like higher speeds, I think you would be happier with a higher voltage battery, like 48V, but...if you are just starting out and don't need very high speeds, a 36V battery will be much more affordable. I suggest buying the largest battery that you can afford. Doing this will allow each cell to run cooler and last many more months than if you put a strain on them.
hodala   100 W
Post by hodala » Feb 28 2017 8:35pm
Thanks!people can see me do mechanism work,not an E guy,prefer a versatile fat e bike that can cruise along beach also do daily shopping job
Wheazel   10 kW
Post by Wheazel » Mar 02 2017 10:18am
Someone needs to fix some mudguards! :D
That quad has basically the same tilt setup I am planning for the winter quad build.
The main different thing I have done with the front compared to my trike, is separating the tilt and steering movements to different joints.
This gives me more tilt angle while still having an angled kingpin.
Your front end kit seem to use ball joints to give good tilt movement but less steering angle? Or do I misinterpret the pictures?
hodala   100 W
Post by hodala » Mar 02 2017 11:19am
Not just ball joint,wondering if you ever saw the tricks before- oversized ball joint with spacers beside so you get enough angle to steer and tilt
knuckle 講解.JPG (120.11 KiB) Viewed 5530 times
hodala   100 W
Post by hodala » Mar 04 2017 10:21pm
Since some people do cared about king pin inclination,I do the simulation pictures to make sure what is a better choice compromise,I'd seen video of danish products,no more than 30 degree lean angle I guess
king pin inclination 5.JPG (109.21 KiB) Viewed 5530 times
veleon and Mk1.JPG (97.51 KiB) Viewed 6389 times
ScooterMan101   1 MW
Post by ScooterMan101 » Mar 05 2017 1:49am
A whole kit to make any bike into a leaning trike for a few hundred bucks , Yes , Yes !
How much would it cost in shipping from Taiwan to the U.S. ( California ) ?
How much does it weigh ?
Keep in mind that many of us have bikes that have front forks that are tapered, 1 1/8 inches top to 1. 5 inch bottom .
So
You would need to make kits for both kind of bikes, 1) for bikes with head tubes that are straight 1 1/8 inches
and 2 ) for bikes that have head tubes that are 1 1/8 top and 1.5 inch bottom
And/Or
An Adaptor that will allow the use of a straight 1 1/8 tube on your tilting front end, that will fit into a 1.5 inch bottom of head tube on a modern bicycle .
http://www.jensonusa.com/!t52ldrKaaKvm4 ... wAod974Cxg
hodala wrote:If you guys were interested to have a leaning trike and are able to DIY frame work too,I'm planing to make a small package kit(not easy done components for DIYs :CNC axles with heat treatment,plate forming parts,knuckles sets- - )that only few hundred bucks one can have an easy work complete kit to transform a bike to leaning trike
My first conversion ... Sold
viewtopic.php?f=3&t=71378&p=1077497&hil ... 1#p1077497
It's 2018 already, ( now 2019 ) lets get some real , improved e-bike / e-velomobile / e-motorcycle designs .
drewjet   10 kW
Post by drewjet » Mar 05 2017 7:06am
Count me interested too
hodala   100 W
Post by hodala » Mar 05 2017 7:54pm
ScooterMan101 wrote:A whole kit to make any bike into a leaning trike for a few hundred bucks , Yes , Yes !
So
And/Or
Don't know the freight cost yet
The 26" blue trike is 23.5kg now,the kit modified from motorbike kit still too heavy,fit for 5kw E bike is still ok;I'll lose it's weight later
The kit won't fit all bikes especially fiber frame
macribs   1.21 GW
1.21 GW
Post by macribs » Mar 24 2017 6:30pm
Chalo wrote:It's a clever gadget. But having made some stuff along those lines before, I can say with confidence it's an expensive, heavy, complicated, inconvenient way to do what a two wheeler does cheaply, simply, conveniently, and with minimal weight.
A gadget yes, but also nice for a cargo trike. Non leaning trikes are horrible when cornering. Sure there are great two wheeled cargo bikes, but the length of those cargo bikes makes them a bit slow and cumbersome to handle in urban settings, and in tight spaces or if you live in an apartment and use elevator to get up to the flat. Impossible to get a 3m cargo bike into an elevator. A short wheelbase trike is something else, the trike will fit inside elevator. Nice and easy to ride, easy to handle especially in tight places and the width will still let you ride between lanes when traffic is jammed. And on top of that you can carry cargo, pick up parcels or haul enough beer to last a party. Oh and leaning trikes are also insanely fun to ride. It feels like you are ignoring the laws of physics when the trike leans over.
hodala   100 W
Post by hodala » Dec 16 2017 11:01am
pictures- -;gonna modify the 20" fat bike to a e trike for beach cruser
