Laprise Board track racer
amberwolf   100 GW
Re: Laprise Board track racer
Post by amberwolf » Dec 03 2017 3:26pm
FWIW, if you want the silver engine/piston areas to be really metallic in appearance, Testors makes the Metal Masters "buffing metallizer" paints, which can be buffed after application to shine like the various metals they are labelled for. I used to use these to build sci fi models and props, and they look very much more like metal than any other paint, once buffed up.
You do have to start with a very smooth surface, the more polished the better, so you'd need to resurface the parts before painting with it.
This should be their source page, but I can't see the page because of all the scripting it uses.
https://www.testors.com/product-catalog ... del-master
A google shopping page
https://www.google.com/search?q=testors ... 19&bih=917
A google image page
1HP   100 mW
Post by 1HP » May 15 2018 7:12am
8)
Build the Ride / Ride the build
SlowCo   10 kW
Post by SlowCo » May 15 2018 12:21pm
Thanks for posting these pornographic pictures 8)
Any updates or changes done to the bike? Or is it just going strong?
1HP   100 mW
Post by 1HP » May 15 2018 9:15pm
still running strong , no issues to report except excessive disc brake pad wear , but pretty sure its just cause they are the cheapest i could find :P
SlowCo   10 kW
Post by SlowCo » May 16 2018 11:59am
Maybe implement regenerative braking?
1HP   100 mW
Post by 1HP » May 17 2018 7:07am
Thats for certain if/when i do a other one , but this one is all done and work fine so i leave it as is
