Vector Light Commuter Build
Show off your Ebike creation here.
DriftTrike   1 mW
Re: Vector Light Commuter Build
Post by DriftTrike » Feb 06 2018 5:10pm
It's definitely not enough. Unfortunately I can't go much larger. I have the new fat bike rear end for the Vector light frames. Artur uses a 38T max with these rear ends. I was trying to figure out how to extend the bottom bracket spindle so I could run a larger toothed front crank but its not an easy task. The bottom bracket measures 100mm and the spindle is 164mm. Finding a spindle that will fit has been incredibly difficult. I've also considered replacing the entire bottom bracket but I haven't found any options that give a large enough spindle width in a 100mm bottom bracket shell size.
For the time being, my plan is to get the bike running with the 36T and figure out how to upgrade it later.
skeetab5780   10 MW
Post by skeetab5780 » Feb 07 2018 10:19am
DriftTrike wrote:
Feb 06 2018 5:10pm
Drift check this website out, it has a lot of funky bottom brackets for franken bikes :)
http://sickbikeparts.com/bottom-bracket ... dge-206mm/
I've bought one in the past for a odd mid drive build before with a gen 1 farfle swingarm that needed a longer shaft
skeetab5780   10 MW
Post by skeetab5780 » Feb 21 2018 1:09pm
70 degrees in the middle of winter! Yes I will take the bike for a ride!
I really like the auto regen on throttle let off on a slow 36v bike. I tend to basically max the throttle and let it off to stop its really easy and I don't have to listen to my disc rotors squealing from the wet snow melt
But the bike is too slow now that the weather is warming up I need to go to 52v minimum now maybe more :)
skeetab5780   10 MW
Post by skeetab5780 » Feb 23 2018 1:45pm
Met my first Ebiker in MA in the last few years...yes that is how scarce we are out here!
I had to pull him over and chat him up, he had a nice gray Sondors fat tire bike, he seemed to be bored with 36v. I gave him my card and told him we can easily increase your system to 48 or 52v!
Snapped a picture of his ride
shorza   1 kW
Post by shorza » Apr 09 2018 9:45am
Is there an update on this build?
Vector's website claim the seatpost is 30.6mm, but you have a 31.6mm. Did you have trouble fitting it?
devo1223   100 W
Post by devo1223 » Apr 09 2018 11:04am
Vector lite stuffed with 30Qs
Mxus 3k turbo 3t in 17in moto rim
viewtopic.php?f=3&t=92531&p=1353484&hil ... e#p1353484
shorza   1 kW
Post by shorza » Apr 09 2018 6:28pm
devo1223 wrote:
Apr 09 2018 11:04am
seatpost is 31.6
Here's mine
Thanks for the info. Any update on your build?
devo1223   100 W
Post by devo1223 » Apr 12 2018 12:02am
My day job will slow down after April 17th (taxes), more updates then. Sorry to hijack your thread Skeet
jordison   10 mW
Post by jordison » Apr 12 2018 11:04am
hi.
what bottom bracket would you use if you wanted to use 53t chainring?
needs to be larger than the usual or it will hit the frame.
skeetab5780   10 MW
Post by skeetab5780 » Apr 12 2018 12:22pm
devo1223 wrote:
Apr 12 2018 12:02am
No worries, I've been busy with other stuff myself so this bike just gets ridden to the corner store here and there...still performs great I have yet to even deplete or charge the battery pack yet since I went to 10s 42v
skeetab5780   10 MW
Post by skeetab5780 » Apr 12 2018 12:24pm
jordison wrote:
Apr 12 2018 11:04am
hi.
This one is affordable and will likely give you plenty of clearance
http://sickbikeparts.com/bottom-bracket ... -complete/
jordison   10 mW
Post by jordison » Apr 12 2018 1:19pm
it's longer on the left side, the right side isn't much longer , i'm not sure if it's enough.
efMX Trials Electric Freeride   1 MW
Post by efMX Trials Electric Freeride » Apr 12 2018 1:31pm
jordison wrote:
Apr 12 2018 1:19pm
the fixed cup with the flange is usually on the right / drive side, so it may just be sitting on the table backwards.. also the fixed cup is glued on to the center core so apply a little heat and tap it off with a mallet then switch the cups if needed.. they also have a longer one available.. just keep in mind the longer the bb the worse your chain line will be..
some ride & sk8 videos:
metacafe.com/channels/NATAS666DAMIEN
http://www.youtube.com/natas666damien
i have nothing for sale.. :)
skeetab5780   10 MW
Post by skeetab5780 » Apr 13 2018 7:01am
Im planning to put a 52t on the front of mine i will see what i need for clearance soon!
Here is a shot of the new handlebars and stem, bit wider and nicer and shorter stem since other was too long
skeetab5780   10 MW
Post by skeetab5780 » May 29 2018 8:31am
So I put a good 50 miles on the bike this weekend and there are a few things I need to address that are bothering me
-chain keeps falling off over big bumps causing me to pull over 2-3 times a ride and get the hands greasy
-cannot pedal fast enough even with only 10s battery, can only assist on big hills then i'm pedaling too fast
-I'm having pedal strike issues with shock compressing too far down on corners this is very scary/dangerous and the reason why I need to move shock one position to higher the BB
-front brake cable needs to be shortened(easy)
-auto regen is very tough to commute with since you need to keep throttle held wide open the entire time causing fatigue of hand even on downhills
I have to move my rear shock to the top hole of the swimarm but I have to modify or crush the round tubing from the swingarm top tube to get the shock to fit in place since the mount is designed a bit wanky, that or I can grind down the shock butt
quick 5 min file job, it was that easy...and shock is now fixed, will test ride later but I think this will be happy spot
Here you can see what I filed away, its a bit tight hopefully nothing rubs, only took what I absolutely had to take out out
skeetab5780   10 MW
Post by skeetab5780 » May 29 2018 6:46pm
Rear shock felt pretty good on the way home, the front fork angle isnt as steep now. It still seems a bit steep though. The bike is really tall when i stop and sit at lights but when i sit on it with my 220lb butt the shock sinks down a bit far. I thought to put the seat down a tad but i cannot since i have long legs and like to pedal for exercise. My cranks are 170mm i believe so i can only buy 5mm longer if i had to. I think my rear shock is 650lbs i may need to get the 750lb like my kuberg has
skeetab5780   10 MW
Post by skeetab5780 » May 30 2018 11:17am
Well it looks like my week of awesome weather commuting is put on hold after 3 short days... Came to work today and everything has been going perfect, plug my bike in to charge while it sits at the side of my garage door bay...One of my "special" workers is taking a pallet in on the fork truck and completely runs over my HV satiator charger that costs $325 UGGGGGG
so shitty, I should have known better than to leave it there charging...The best part is when I pick the thing up in pieces and unplug it he says " do you think it still works".......ROFLMAO WTF
skeetab5780   10 MW
Post by skeetab5780 » Jun 13 2018 10:53am
Another 100 miles on the bike now. The only thing I feel that needs to be addressed is the chain falling off all the time. It comes off atleast two to five time on my 13 mile commute each way. It is starting to get annoying im going to look into it today since it looks like it going to downpour tonight so I will not be riding home likely
shorza   1 kW
Post by shorza » Jun 13 2018 7:26pm
A front chain guide will probably make your commute a lot more enjoyable.
This is mine.
16s 10ah lipo
MXUS v3 with ferrofluid and hubsinks
15f Powervelocity controller
skeetab5780   10 MW
Post by skeetab5780 » Jun 14 2018 9:48am
How many teeth is that it looks too small
problem is I cannot even assist past 20mph and my pedal cadence is too fast on only 10s 42v battery
I have a 52t chain ring but I don't have a spider with the correct BCD to try it. The guard will be a must. Im going to try taking a few links out of the chain first
FYI nice ride! looking much farther along than last I saw it :)
skeetab5780   10 MW
Post by skeetab5780 » Jun 14 2018 10:07am
actually just laid the bike down and put the 52t near it and there is no way its going to happen... Maybe if you get a really wide BB but then chainline will be off and it will look a bit odd sprocket so close to frame
This is a eyeball I think its a bit closer to the frame in pics
shorza   1 kW
Post by shorza » Jun 18 2018 11:50pm
Yep, I ran into the same problem. I've gone with a 40t chain ring and I would say it is probably the largest that will fit in the frame.
Combine that with a (14-17-20T) 3 Speed Freewheel and it's ok to pedal up to 40kph.
http://r.ebay.com/JMO7Q8
skeetab5780   10 MW
Post by skeetab5780 » Jun 19 2018 7:13am
I have a 42 on now and I think a 48 will fit
that's what im planning on using
calfeetwenty   10 W
Post by calfeetwenty » Jun 19 2018 11:16am
Does that 3spd freewheel have the right threads for a hub motor?
Electra 7D/BBSHD, 24 spd hybrid drive 52 volt....mods coming
Electra 7D Fat/Mxus 3000 Turbo, 72 volt.
Paratrooper Pro/BBS02/Alfine 8, 52 volt...back to regular bike
KMX Trike 1500 Edge 72 volt
Luna Cargo/ possible 2wd...on the back burner again
Vector Typhoon QS 205/50 6T half done
Easy Racer LWB recumbent, Bafang G310 stealth...soon
Hp Velotechnik scorpion fs 26 Mxus 30mm cassette motor...soon
skeetab5780   10 MW
Post by skeetab5780 » Jun 21 2018 9:21am
calfeetwenty wrote:
Jun 19 2018 11:16am
I'm not sure Shorza may, seems like a nice option but id prefer a 12t
