Scott gambler highway speed
boisrondevens   100 W
Post by boisrondevens » Dec 16 2017 8:49pm
this is my new built for a family member
just started
frame was salvage and rebuild
not sure about motor and controller yet
Epyon   1 W
1 W
Re: Scott gambler highway speed
Post by Epyon » Dec 16 2017 10:12pm
An O.G. Gambler! Cool frames. Lots of adjustabilty. Keep an eye on the head tube's upper pinch bolt area. They like to crack there if not properly torqued. Since you're going for high speed you can run the head tube in its slack orientation (63 degrees IIRC). Or better yet, short shock it to drop the BB height and slacken at the same time.
What's your plan for batteries? Backpack or under the downtube?
boisrondevens   100 W
Post by boisrondevens » Feb 28 2018 6:44pm
new pics
IMG_Feb282018at63932PM (1).jpg (87.41 KiB) Viewed 1455 times
tahitiboob   1 W
1 W
Post by tahitiboob » Mar 01 2018 3:30am
beautiful frame, i like the colour mix
what is your controller?fets?
where do you put your battery?
boisrondevens   100 W
Post by boisrondevens » Mar 01 2018 1:59pm
hi
I will be using an custom 18 fets crystalyte controller. The motor is a TC 80 crown crystalyte.
I'm a distributor for Crystalyte so averything in stock :D
You can check my web site: kobois.com
back pack for the battery with Sony VTC4 cells From Doctorbass ( a good friend)
takis8vas   1 mW
Post by takis8vas » Apr 13 2018 10:53am
Damn i exchanged my for an old Ram DHX Frame so i could fit the bafang bb motor on it .
Awesome build mate , whats the top speed and how many watts ?
tolkaNo   10 W
Post by tolkaNo » Apr 14 2018 1:52am
Was it hard to make those custom dropouts?
Hebel   1 µW
Post by Hebel » May 02 2018 1:35am
Wery nice bike build!
I use the gambler as well and it handles great
How did you manage to make those sweet dropouts?
ridethelightning   1 MW
Post by ridethelightning » May 02 2018 2:59am
very nice. like the title of the thread , has a certain ring to it :D
skeetab5780   10 MW
Post by skeetab5780 » May 02 2018 6:30am
boisrondevens wrote:
Mar 01 2018 1:59pm
hi
Ofcourse the tc80 crown was in stock who want one of those relics!
Jk jk sub’d these build are always fun until you add 40lbs of batts to the equation
Post by ridethelightning » May 02 2018 7:54am
sounds like a good back pack full of lipo is best bet. pack size optimised for short trips at high amps...and oh, dont forget the asbestos firewall in the backpack :D
skeetab5780   10 MW
Post by skeetab5780 » May 02 2018 8:26am
ridethelightning wrote:
May 02 2018 7:54am
Once you get over 18s 12ah on a battery backpack especially on a bike with lots of power it becomes fairly unsafe quickly depending on what you are doing. It gets heavy and makes flipping off backward a real danger
