Schwinn FS Dual Hub / ASI Controllers AWD from 10Kw to 17.6Kw 73.6mph
Frame:
Schwinn 405
Batteries:
18650 72V 26AH LG 2200Mah MF1 cells
Motors:
Front: 750W Front Hub
Rear: MXUS 3K Turbo 3T
Controllers:
Front: Grin Phase Runner FOC
Rear: Sabvoton 72100A
Tires:
Front: 16" x 2.75
Rear: 16" x 2.75
Schwinn 405
Batteries:
Motors:
Controllers:
Tires:
Front: 16" x 2.75
Rear: 16" x 2.75
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Re: 2WD Corner Carving Racer
That looks like it will go fast.
Does have a chain? I don't see the chain ring in the pics.
Re: 2WD 16" Moped Tires 3000W/8000W Corner Carving Racer
Haven't got a chance to hook up a chain yet.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
- tahitiboob 1 W
hello
i can't see the picture
- amberwolf 100 GW
- Location: Phoenix, AZ, USA, Earth, Sol, Local Bubble, Orion Arm, Milky Way, Local Group
- Contact:
Neither can I; it's on some third-party site rather than attached to the post where anyone that can see the post could see the images.
I recommend always using the Attachments tab to upload images directly to the ES post itself, so everyone can see them and they don't disappear when the other site goes away or changes how they work.
If you found this advice helpful, supporting contributions are accepted here.
"if it ain't broke, improve it till it is"----Dog-Hauler Cargo eTrike SB Cruiser----Tiny's Wheelchair Project----Cargo eBike CrazyBike2----House Fire Updates & General Blog
Its fixed.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
- amberwolf 100 GW
- Contact:
It looks a lot bigger than it actually is.
Lots of power--what is the acceleration time?
The battery pack reminds me of a packed parachute.
Are you planning on torque arms on the front for later? Looks like torque plates or blocks on the rear already; cant' quite see that area very well.
Bike has been down for about a week, redid the battery pack now it is 72V 30Ah.
-Grin TA both sides of the fork
-Redid my rear torque arm / plates
-Will be running dual regenerative brakes
-Have to install dual projector lamps
-Tune the Phase Runner / Front Motor
-Have a 135mm steel fork that I will have to mount
-Will possibly be upgrading to a 1500W Front Hub
-Upgraded my wiring to 10awg / 8awg / 6awg
-MXUS 3K Turbo phase wires are upgraded to 8AWG
-Controller to Battery is 6AWG
-Front hub upgraded to 10AWG Phase Wires.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Dual Regen brakes wired up, using proportional / variable regen with a single right hand throttle.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Wired up LED lights running off a AC adapter, 12V 6A output.
Running 2 CA's that track each system front and rear motor.
Both Systems can regen at the same time.
LED lights have Halo mode.
High beam, low beam, and strobe.
They each have a on and off switch.
Consumption is 4-6W for the Halo Lens, 20W for Halo and High Beam lights.
- Attachments
- IMG_3763.JPG (40.68 KiB) Viewed 2798 times
- IMG_3769.JPG (90.54 KiB) Viewed 2798 times
- IMG_3776.JPG (101.92 KiB) Viewed 2798 times
- IMG_3802.JPG (134.07 KiB) Viewed 2798 times
- IMG_3794.jpg (92.6 KiB) Viewed 2798 times
- IMG_3790.JPG (61.72 KiB) Viewed 2798 times
- IMG_3795.JPG (46.01 KiB) Viewed 2798 times
- IMG_3796.JPG (61.37 KiB) Viewed 2798 times
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
How's it handle on loose stuff? I've talked about building a 2wd for years with 2 benefits in mind:
1. First of course, is having the extra power with double the cooling.
2. Handling, I've always thought that having a powered front wheel would be a benefit if traction is lost on the front wheel, because even in the slickest of situations the front while under power would provide at least some force trying to keep you upright. I remember 8 years ago my front wheel drive first hubbie had a positive effect when I encountered loose gravel or sand on the street instead of just sliding out from under me with unpowered fronts since. Anything that reduces the chance of eating any more asphalt is a plus in my book, and before anyone goes there, each and every occasion was while going slow and at low power.
Hey John, I haven't really tested 2WD on the dirt, I built this bike to be a capable street machine and eventually track weapon.John in CR wrote: ↑Mar 17 2018 10:18pmHow's it handle on loose stuff? I've talked about building a 2wd for years with 2 benefits in mind:
1. Cooling / Power is one of the reasons I am developing 2WD. A MXUS 3K Turbo mounted in the rear is getting very warm / hot when ridden spiritedly. It is a light motor, 20lbs. I am trying to see pairing it to a front hub will make the motor run cooler and more effectively. Having a 20lbs hub compared to a 30lbs hub like the QS motor makes the hub handle much better. I am still tuning the setup closer to 50/50 power split. Right now its 1/5, so its rear bias.
2. The front hub acts as a stablizer so that straight line acceleration is very smooth because you now have forward propulsion, also moving some of that weight from rear to the front by using a lighter rear hub results in a better balanced, better handling machine. I barely got to ride the bike today, it is still undergoing tuning or other developments. Using 2 Cycle Analyst to monitor both systems independently.
- Attachments
- IMG_3805.JPG (106.19 KiB) Viewed 2729 times
- IMG_3827.JPG (139.71 KiB) Viewed 2729 times
- IMG_3833.JPG (192.49 KiB) Viewed 2729 times
- IMG_3834.JPG (192.66 KiB) Viewed 2729 times
- IMG_3825.JPG (152.98 KiB) Viewed 2729 times
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Re: 2WD 10Kw Schwinn 405
Power split is now closer to 40/50 at low speeds and steadily becomes rear bias.
Front motor tops out at 38A, Rear Hub doing 77A. The sprint to 54mph is incredible, with acceleration coming from front and rear hub. Handling is excellent as well, although I have to increase the throttle mid corner / corner exit just like RWD just it is still rear bias. Consumption increased a bit, due to inefficiencies from running dual hubs. Dual regen braking is awesome (variable / proportional)
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
I ck'ed out some of your Kart track race vids, very impressive, especially mixing it up w/ the 50cc mini's (motorcycles, not bicycles). I raced the first non YSR bike w/ the defunct CMRRA back in the early '90's and I know how fast the mini roadracers are.
These days, I would think gas is easy compared to doing it electric.
Can you get racing compound tires? modified Honda NS 50
Motomech
'03 Rocky Mountain Edge 2WD 260 Q100H frt and Ezee V1 rear 2 Elifebike 20A & 25A 9-FET controllers 12S/10Ah Multistar Lipo rear 4Ah Turnigy frt Luna Cyclops Extra lite Alex 24DM rims, Crazy Bobs run ghetto tubeless. 25 mph. Mean Well HLG-320H-54A
https://endless-sphere.com/forums/viewt ... =3&t=83430
'07 GT Idive 4 4.0, Q100C 201 14S LiPoly elifebike 9-FET 20A controller. 23 MPH.
https://endless-sphere.com/forums/viewt ... 4#p1378484
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Added Rear LED lights
Redid the battery enclosure
Moving to a 135mm steel fork and a 135mm hub up front in the future.
Going with grippier tires and a extended swingarm on the way.
3KW Front / 7KW Rear
Still trying to find the optimal power split ratio / ramping.
Was most efficient when 2WD was rear bias 20/80
Its about 30 / 70 right now. Handling is better but consumption has gone up.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Not at the moment.
Here are the 2 motor / systems that I am running. Front and rear respectively. Bare in mind both controllers are sinewave and FOC. Field weakening boosts unloaded RPM to about 1050RPM.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
2WD Rocks
Top speed so far is 58mph.
2WD takes off from a stop very quick, almost unreal.
2WD still has very impressive handling, I don't really notice the addition weight up front.
Dual Variable / Proportional Regen is awesome. I rarely use the disc brakes.
Acceleration is quite mind numbing.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
How about posting a video of the acceleration? I like the lights.
Sorry still no videos yet, my old GoPro Hero 3+ black edition has seen better days.
Pulls harder than a QS 205 and probably equivalent to a QS 273 in terms of torque and acceleration.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Finally some footage,
Power has climbed from 10Kw to 17.6Kw
Front Hub still at 3Kw output from the phase runner
Rear Hub has increased from 100A to 183A
Top speed has increased from 58mph to 73.6mph
- Attachments
- amps.jpg (56.32 KiB) Viewed 1777 times
- CA top speed.jpg (19.84 KiB) Viewed 1777 times
- Schwinn 405.jpg (96.55 KiB) Viewed 1775 times
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Re: Schwinn FS Dual Hub AWD from 10Kw to 17.6Kw 73.6mph
Thanks for posting the video. Looks fast. And you weren't even pedaling
