Death Machine '17 cyclone3000 build
eddiecycle   1 µW
Post by eddiecycle » Mar 11 2018 5:45pm
This is my Death Machine '17, my first EV build in well over a decade. Motor is a cyclone 3000 kit, battery is 72v 17.5ah. Frame, fork, and wheels are from one of my old MTB builds and are tough, heave stuff. New parts are the 29x2.5 touring tires for stability at speed, Soma Gator handlebars for an aero dropped position, 11-speed drivetrain, and Zee downhill brakes with 203/180 rotors because I value stopping ability. I plan to install a dropper post so I can pop the seat up and pedal if I want/need to. I've had it up to just shy of 50 but haven't tested the range yet. We have a lot of short, steep hills in the area and this bike can handle pretty much anything at 40+. I'm just now getting more confident with the handling and laying it over a little more in the curves.
e-beach   100 MW
Location: Any Los Angeles area beach I am at. Or Santa Monica or possibly the south bay beaches.
Re: Death Machine '17 cyclone3000 build
Post by e-beach » Mar 11 2018 5:53pm
Sweet!
Any top speed numbers yet!
Also, you are wearing a full face helmet and body armor......Right?
:D
Favorite Quote: "This is L.A., sugar. There is no 'over the top." --- Chris Erskine
Current build: Liahona w/ cheap front suspension and suspension seat post. Yescomusa 36v 800w generic front hub motor. 15ah Headway triangle mounted pack. Tronsung 30 amp,
Previous Build:1992 Trek Antelope 800 - Bone Crusher (no suspension) - Yescomusa 800 watt 36 volt front wheel kit. Don't do it! Get suspension!!!
eddiecycle   1 µW
Post by eddiecycle » Mar 11 2018 5:57pm
Body armor yes but my motorcycle full-face doesn't work very well with this low of a position so I'm using a bike helmet. A better option is on the list. Highest speed I've gotten to so far was 48.5. I feel confident that I can hit 50+ on a smooth flat road with tight aero clothes, but the more realistic top speed is upper 40s
Mongo1   10 mW
Post by Mongo1 » Mar 20 2018 12:16pm
Eddie,
I have a similar crank chain ring. Does yours wobble (the freewheel)? Yours is silver which means you may have replaced it? My freewheel is black and does wobble a bit which is a bit disconcerting :(
Sean9002   1 kW
Post by Sean9002 » Mar 22 2018 5:30pm
eddiecycle wrote:
Mar 11 2018 5:57pm
Have you looked at Bell super 2r helmets? the one with the removable jaw section? They have quite a low profile and sure the lower may give way in a big impact but its dissepation of energy that would otherwise occur on your face =)
OSET 20+ - Custom frame and swingarm, Motorims - 66V
Ruff Cycles Porucho - MXUS 3000w - whitewalls - Gloss black/Pearl blue/copper leaf - custom tanks - bobber saddle
Giant Glory 00 - Clyte X5404 - Hubsinks - 18FET Sinewave
Fuji Nevada S - MXUS 35mm- Hubsinks - 12FET Sinewave
39inch longboard Dual 50mm, 12s lipo
eddiecycle   1 µW
Post by eddiecycle » Apr 23 2018 1:54pm
Mongo1 wrote:
Mar 20 2018 12:16pm
Eddie,
I havne't noticed any significant wobble. I'll take a close look next time I have it in the stand. Is it the freehub on the motor or the one on the crank that is wobbling with yours?
