UPDATE:
this is how it looks now:
Stats:
OLD POST:
Hello guys,
just want to show a bit off
i made my first build in 2012 using magic pie motor running at 5kw now... but i have always been dreaming about building something "real"
a few month ago i found soaresdacosta's ebike build (https://endless-sphere.com/forums/viewtopic.php?f=6&t=38754&start=400) using a very much unknown downhill bike "berg viper". Its pretty much the best bike to use. It has 20cm front and rear suspension and a lot of space for the battery. Dropouts are 150mm as well. Frame is thick as f**k. Perfect!
i got it for 600€ second hand, which is .... damn cheap for such a bike
i did some testing how much batteries could fit
... about 140 18650's
at 11Wh per cell thats about 1.5kwh
battery box design:
torque arm design history including a final 3d printed prototype
lasered out of aluminum by laserteileonline.de
1.5mm for battery box
10mm for torque arms
cost me 60€ .. damn cheap!
test mounting:
whole box is bolted together using thin right angle profiles
Batteries
batteries are a really difficult topic ... i want to go for 8kw peak but i want to double or triple my previous battery capacity (0.6kwh) as well.
I was thinking about using samsung 18650-30Q that would deliver 15A per cell which would be 140x 15A x 3.3V =7000W in sum. But i think this is too much, as these could deliver 7kw continuous. I need it for peak only. Also they are not very cheap.
Fortunately tumich had some "unwelded" 18650GA's rated at 10A on hand. From lots of tests on the internet it seems like those are unterrated, they can deliver 15A and peak even higher. I guess thats enough for me.
batteries arrived from tumich,
145x 18650GA ... 390€
battery fitting test
140 fit but its too tight
My controller will be a heavily modified Kuateng with 12x CSD19536KCS Fets (100V 2.7mOhm)
So i will be limited to about 100A which means i need at least 80V to reach 8kw
Best setup would be 20S 7P (84V peak) but since 140x dont fit i will probably have to go for 19S 7p = 133 Cells (79,8V peak). Other options would be 22S 6P but i think this is too close to 100V and kill the fets.
arduino battery welder using 3s 4000mah 60C Turnigy:
first test welds using 0.15 nickel x25mm :
... so faar so good
Plan is to solder thick copper cable on top to be able to handle 100A
Torque arm mounting and motor
The torque arms will be glued to the frame. As life insurance i will put 2x M5 screws as well.
First time mounting mxus v3 4T that i got "used" (new) from ebay laced into 19" moped rim.
Cost me just 320€
damn .. this looks so good
Todo:
Stats:
- Berg Viper DH Frame
- 200mm suspension front + back
- Magura MT5
- Mxus 3k Turbo 4T
- 133x NCR18650GA in 19S7P = 79,8V * 23,5 AH = ~1500 Wh
- Kelly KLS7218 sine controller
- Topspeed 70 km/h
- 60 km range
- 40 kg
- ZERO noise while driving
OLD POST:
Hello guys,
battery box design:
test mounting:
Batteries
... so faar so good
Cost me just 320€
Todo:
- Battery box mount, i will probably get some kind of perfectly fitting clamp for the downtube lasered ...
- Battery welding and configuration. Should i go 22S (=92,4V) or better stay at 19S? I dont want to kill the Fets
- Glue back on the derailleur
- Mount new Magura 5 double piston brakes (got them new for 110€ @ ebay)
- Mount controller below the downtube
- Mount KT Display
- BMS, Charger
- Cabling, Thumb throttle, Lights ...
