Titanium Fatbike - Bafang Ultra and Phaserunner
Hi Sphere!
Here some pics and a build thread of my Fatbike with Bafang Ultra + Phaserunner.
I started the build in July, its almost complete now.
After building some BBSHD bikes it was time to get my hands on a Bafang Ultra drive.
I like the torque sensing idea and the integrated look of the G510.
Ordered a Ludicrous Ultra from Luna. (As it turned out later, it wasn't a Ludicrous)
And found a titanium frame on Alibaba.
Frames are completely custom build.
I don't know much about bike geometry so went for a quite basic frame. (Large)
If I had to do it again maybe I would go for a smaller chainstay, a Rohloff mount and I would have moved the mount for the speed sensor a bit more backwards.
Delivery should take 45 days Linda said (as it was one week before Chinese new year) but I wasn't in a rush so I ordered a frame, seat post, handlebar and a titanium headset.
Frame was ready after 50 days but that interfered with my holiday so had the shipping postponed for a couple of weeks.
The frame was very well packed and arrived without any damage or scratches.
It felt very light but you could notice that the bulk of the weight was in the motor mount bracket.
I thought some extra weight could be saved there by drilling and grinding it down a bit but that was before I discovered how tough Titanium is.
Even my best drills had a hard time of making a small hole in it.
Frame weight was 2.75kg
- Attachments
- LO7 (4).jpg (75.08 KiB) Viewed 4428 times
- LO7 (6).jpg (120.69 KiB) Viewed 4428 times
Re: Titanium Fatbike - Bafang Ultrarunner ;-)
I'm planning on building a custom battery for this bike later but I also had 4 mounting holes placed on the downtube to securely install a Jumbo Shark.
I wanted to hide the cables as much as possible.
Thats why the motor mount bracket needed some extra holes for:
2 power cables
Derailleur cable
Speed sensor cable
The gear sensor will be installed in the downtube.
2 power cables
Derailleur cable
Speed sensor cable
Parts I ordered for the bike:
Magura MT5 + MT5e (I only want a brake sensor on the rear brake)
203mm and 180mm brake discs
Also found a nice "cheap" secondhand wheelset from DT SWISS with Fatsno Pro4 hubs
150x15 197x12
Wheels came with 4.0 tyres I ordered some 4.8's
I lended the Bluto Fork and SramX9 derailleur from my scott fatbike, later will find another Bluto in a different colour.
Didn't like the black rimtape and changed it to Neon Green.
Derailleur cable runs between motor mount and the Ultra drive
Nice clean look.
150x15 197x12
Nice clean look.
Bike runs great but the power of the "Ludicrous" Ultra was dissapointing.
After checking settings, wattage and amps I could only conclude that this was a standard drive.
Display went up to a nice 1500W 30A, where the Ludicrous only should indicate 1250W and 25A (x2)
After some mails to Luna they agreed that I got a standard drive and gave me a refund.
What now?
I have a BBSHD Ludicrous bike which is a lot faster then this.
And I really wanted some extra power.
Would a phaserunner fit inside an Ultra drive?
Only one way to find out.
I ordered a CA3 and a Phaserunner and took some measurements.
First I hooked it all up and did some tests.
The Ultra runs quite well with the PR.
The Phaserunner is about 1cm to big to fit inside the Bafang drive.
With a little modification (hacksaw!) it might fit.
The PR can be shortened a bit.
And the motorcasing needed some milling.
What now?
- dirt huffer 1 W
Looks awesome!
- soaresdacosta 10 kW
Top work.
My bike build:
https://endless-sphere.com/forums/viewt ... =6&t=38754
Re: Titanium Fatbike - Bafang Ultra and Phaserunner
How I wired it:
Phase
Phase wires go to Phase wires on Phaserunner Hall
Hall Connector has 6 wires.
5V and Ground + 3 Hall sensors and a white cable that is a NTC thermistor that I connected to the CA to monitor the temperature. PAS
It took some time before I figured this one out.
The Ultra's PAS needs 5V, you can steal 5V and ground from the CA or from the Phaserunner. (There is 5V and ground at the PR throttle connector.)
The CA didn't pick up the PAS signal from my Ultra. I had to add a 20K pull-down resistor between Pas signal and ground to make this work.
The Green Dir cable is not used
The Purple Pas Phaseshift is connected to the dir tab on the CA
Brown Torque goes to the Trq on the CA.
My Ultra had a Higo6 connector for the PAS with the right colours, which made it a bit easier. This is a diagram I made:
I used the standard Bafang Speed sensor.
Gearsensor and 1X Magura MT5e rear brake.
Phase
- Attachments
- Ultrarunner.jpg (173.82 KiB) Viewed 4426 times
- Ultrarunner1.jpg (116.71 KiB) Viewed 4426 times
- Ultrarunner2.jpg (149.92 KiB) Viewed 4426 times
- Ultrarunner4.jpg (58.06 KiB) Viewed 4426 times
Outstanding write up, thanks for sharing this information. Much milling did the case? Looks like a .5mm on the large section. Please let us know if/ when you hit thermal protection on the phaserunner. Cheers
hi, my son and i followed your thread with a big big smile on our faces!
Gorgeous build!
Can you tell me where you got the frame (and wheels and motor?)?
i'd like to build something similar.
Looking forward to hear, thanks ahead.
Great build!
Gorgeous build!
Great build!
That's a really nice looking frame.
The controller in the Ultra has been a problem for quite a few people. With a decent external controller it should be very good. The rotor is substantially larger than the one in a BBSHD.
Some Ultra motors have the white connectors for PAS/Torque.
How to determine which wire is which?
Thanks "Ivanovitch_k" for the pic!
+5V and GND is easy.
You can see it on the backside of the controller board.
I still have a picture of my plug that will make it easier. orange | purple | white
black | brown | green
These colors correspond with :
+5V | Pasphase | PAS
Gnd | Torque | Speed/Dir
You can check with a multimeter
Between Gnd and PAS : gives you a pulse signal when rotating the crank FWD and REV 0V | 5V | 0V | 5V etc...
Between Gnd and PASphase : gives you a pulse signal when rotating the crank FWD and REV 0V | 5V | 0V | 5V etc...
Between Gnd and Speed/Dir : gives you a pulse signal (0V or 5V) when rotating the crank FWD and 5V constant when pedaling backwards
Between Gnd and Torque : gives around 1V and a bit more when you put torque on the pedals.
This is a video I made from PAS and Speed/Dir signal on a scope.
(Top signal is PAS, bottom is Speed/Dir)
The frame supplier I already mentioned above:dutchlincoln wrote: ↑Sep 10 2018 2:18pmhi, my son and i followed your thread with a big big smile on our faces!
Gorgeous build!
Great build!
https://bjcsti.en.alibaba.com/product/6 ... G510.html
I bought one Bafang Ultra from Lunacycle
https://lunacycle.com/bafang-ultra-magn ... mid-drive/
And another one from CNEbikes. They were quite cheap.
660USD incl shipping to Europe and all taxes paid.
https://www.cnebikes.com/product_catego ... -1000.html
With the wheelset I was quite lucky. Found them secondhand on ebay for 300€
- DT-Swiss BR710 (changed the rimtape from black to Neon Green)
- Hope Pro 4 Fatsno 150x15 -197x12 (I don't like them. Terrible clicking sound and too much backlash)
- Jumbo Jim 4.0 (I replaced them with 4.8's)
Phaserunner from:
https://fasterbikes.eu/en/controller/31 ... oller.html
Higo connectors:
https://www.e-bike-technologies.de/inde ... ctors/higo
Great info, thanks!!Daxxie wrote: ↑Sep 11 2018 1:40amThe frame supplier I already mentioned above:dutchlincoln wrote: ↑Sep 10 2018 2:18pmhi, my son and i followed your thread with a big big smile on our faces!
Gorgeous build!
Great build!
Phaserunner from:
Higo connectors:
About the motor: I thought you ordered a 2500 watt but got a lighter one instead? The one in the link is the 1500W model, correct? Is the Phaserunner still needed then?
Just saying once more: Great build, i love it!
You sir, are a madman! Great work!!
What was the conclusion of installing the phaserunner? Does it help smoothness upon signal or
increase power? Just curious. BTW, beautiful build and great ideas!
I had a Bafang Ultra with a faulty controller.
Spare parts are hard to find.
Installing a Phaserunner seemed the only option.
Power increase? Yes, depends on the battery. Currently it's only 52V 40A translating in ± 2000W
I'm planning a bigger 72V 50A battery for some more power.
Smoothness? The original Ultra is very smooth.
The Phaserunner / CA combo ... not so much.
I'm still struggling dialing it in. The Cycle analyst has so many settings.
At the moment there is a big judder/backlash in the drivetrain when taking off.
It's also quite hard to keep it at a constant speed.
I found your comment about the big judder when taking off very interesting. I built a TDCM Phaserunner KMX trike and I get just a hint of a noise/judder on take off. I have direct drive and you are geared. I wonder if the gearing is increasing the judder. I am seeing the same amp draw as you with my 52 volt system.Daxxie wrote: ↑Sep 17 2018 2:49amSmoothness? The original Ultra is very smooth.
Electra 7D/BBSHD, 24 spd hybrid drive 52 volt....mods coming
Electra 7D Fat/Mxus 3000 Turbo, 72 volt.
Paratrooper Pro/BBS02/Alfine 8, 52 volt...back to regular bike
KMX Trike 1500 Edge 72 volt
Luna Cargo/ possible 2wd...on the back burner again
Vector Typhoon QS 205/50 6T half done
Easy Racer LWB recumbent, Bafang G310 stealth...soon
Hp Velotechnik scorpion fs 26 Mxus 30mm cassette motor...soon
I'm sure the slack in the drivetrain will increase the judder.calfeetwenty wrote: ↑Sep 26 2018 7:45amI found your comment about the big judder when taking off very interesting. I built a TDCM Phaserunner KMX trike and I get just a hint of a noise/judder on take off. I have direct drive and you are geared. I wonder if the gearing is increasing the judder. I am seeing the same amp draw as you with my 52 volt system.
I didn't know that some Direct drives also suffer from this issue...
Must be the way the Phaserunner starts up the motor.
Hopefully they can smooth it out one day.
The judder problem has been keeping me busy for a while.
I read a thread of someone with a BBSHD/Phaserunner describing exactly the same problem.
Here is a video I made of the problem. (It also shows you how flexible a Titanium frame is
titusmc wrote: ↑Oct 17 2017 6:54amMy only remaining issue is that I experience a motor judder whenever I coast on no throttle and reapply throttle, such as coming out of rolling through a corner or coasting down a hill. I've read that this is not exactly easy to fix.
Can anyone point me in the direction of useful material for fixing/reducing this judder issue?
If I solve this, the bike will be basically perfect.
what pedals are those?
Fantastic build, that will take you anywhere.
Love the attention to detail.
My ‘Fatitty’ is identical with the exception of a 16S battery and nothing with a Luna badge
thanks for the quick reply.
i have two bbs02's in the garage...looking to upgrade...love your build.
do you like the ultra now? what speeds you getting? range?
total price?
total price?
Great job ,
I’ve just completed my first build and I’m planning my second build now. You’ve given me a few things to think about.
I wonder why this hasn't gotten more replies as this is such a great and clean looking build! Thanks for sharing as this is pretty much what I am aiming for except I need a frame with a narrower q-factor.
May I ask a few questions about the frame?
Thanks in advance!
- How long are those chain stays?
- If you don't mind could you repost the first image (bike geometry) in your opening post again in higher resolution?
- Is there anything you would change about the frame if you could start from scratch, would you for example stiffen up any part of the frame given the high torque motor?
- What is the total weight of the bike with the battery and motor (48V 14Ah?), around 23 Kg?
Thanks in advance!
