ichiban
After standard installation of BBSHD to my bike 2018.06 or so (from Youtube method) and running it about 300km+ during the past few months, the BBSHD came loose and dropped down to its lowest position most know about. There must be a way to solve that ... then I remove the two lock nuts at the BB, to find ...
Pic1 damaged soft aluminum BB
My soft aluminum BB (68-mm) was eaten up quite a bit into pieces by the notches of the triangle bracket aimed to hold BBSHD motor in place by friction ...
Pic2 : triangle bracket with notches
Now, I don't think a normal friction tightening, even with thread locker solution, will do the job. Since the motor is quite powerful and the way it operates, keep breaking the mount loose all the time even I didn't ride that hard. So after searching internet for a while, I was inspired by some of the correction method to fix this - don't remember which one but similar to what I decided to do...
Pic 3 : torque arm + dwg + installation
Here is how I do my work, unless it is unavoidable, this torque arm is aimed to be an add-on retrofitting mount to BBSHD installation without modifying any part of the BBSHD itself. If do not like it later, it can be removed without any effect to the original system.
After drafting a solidwork 3d file, I had the model printed on paper and cut to size to try fitting with the BBSHD, adjusted here and there, until looked OK. Then I had some leftover SUS304 laser cut to size, thinkness=5mm, a bit too thick but only that was available at that time. They charged me $10.- each to cut including material - not bad. I then bent it with shop vise and hammer manually to fit the shape of the chainstay. See picture, notice the curve of this arm that nicely fit with the frame. That's how one should do it. Sanded sharp laser-cut edges out, 'cos we will live with it for a long time. Then, with the help of 2 SUS hose clamps + some scrap inner tube to prevent scratches, installation was completed fairly easy. Though not so pretty like factory built but purpose served, rather permanently.
Pic 4 torque arm in place with BBSHD
Been running it for another 500+km without any issue so far. It is pretty sturdy. The BBSHD becomes the same rigid part of the bike, even when I stand on the motor.
The particular shape and dimensions of this torque arm fits my bike, MTB Bianchi Kuma 27.1 and it's 27.5 hardtail. Should anyone wanna try this, some modifications might be needed to fit ones bikes. I think 3-mm thick SUS should be OK for BBSHD because of the rigid geometry of the arm. This piece will last the lifetime of the bike and BBSHD, whichever come first, later or even combined. :lol:
Pic 5 : final assy
I hold no responsibility for anyone who wanna try this. Use at your own risks. Just another idea I think useful to the similar interests. Hope this might help some new installers encountering the same problem.
I still am learning to use this forum, any error happens please excuse my fault.
************************ 2022.08 ****************************
A user in this forum pmd me asking for CAD file. Here it is....(should be old SW2012 format)
Still using it until today (23,xxx km). Super strong.
You can use it at your own risk. I only provide info here for academic purposes.
Pic 5 : final assy
