Making the motor run backwards is easy, just switch 2 of the 3 phase wires around then figure out the corresponding hall sensor wiring by a bit of trial and error.
The problem comes if you want to be able to pedal it, as the freewheel mount threads will be the wrong way. There are probably solutions to this. There are ways to mount sprockets to the disc mount, but I don't know about the other way around.
