Neu 8057 6kW left hand drive hardtail with vesc and encoder
evolutiongts   10 kW
Re: Neu 8057 6kW left hand drive hardtail with vesc and encoder
Post by evolutiongts » Dec 27 2018 7:23pm
About bloody time mate, I'm glad that you receieved the ASI BAC4000 in great shape. Please post vids!
http://www.electricrt.com
Electric Race Technologies
Schwinn 405 2WD Track Bike 18KW
EDGE 1500W Hub / MXUS 3K Turbo
ASI BAC 2000 / BAC 4000 Bluetooth
viewtopic.php?f=6&t=93079
10Kw KMX death trike
MUXUS 3K Turbo
Sabvoton 72V150A
Moto Wheels all around
Front Suspension Kit
viewtopic.php?f=6&t=83423
Giant Trance 4 Full Suspension
Cyclone 3000W
74V 3000W
http://endless-sphere.com/forums/viewto ... =6&t=59005
district9prawn   100 W
Post by district9prawn » Dec 28 2018 1:43am
First proper video from the gopro I bought on boxing day. The ride itself isn't that interesting. Towards the end I climb a hill at 65kph which was fun.
Neu 8057 6kW left hand drive hardtail with 18 fet Vesc: viewtopic.php?f=6&t=96754
evolutiongts   10 kW
Post by evolutiongts » Dec 28 2018 1:34pm
Impressive, how is the throttle modulation and control? Top speed? What are you thoughts so far? Are you freewheeling or direct drive? What are you running for a display?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Post by district9prawn » Dec 28 2018 5:58pm
evolutiongts wrote:
Dec 28 2018 1:34pm
It is direct to rear wheel with no freewheel. I'm using regen. Display is CA.
At the moment it is geared really high. Top speed without fw is 90 kph.
Throttle control and smoothness is excellent. Even at extremely low duty and current the controller still seems to track the rotor very well in sensorless. So well that I'm wondering if bemf is used for rotor position at very low speeds while the motor is being driven. Maybe the current sensing is just very accurate and clean.
evolutiongts   10 kW
Post by evolutiongts » Dec 28 2018 9:00pm
Are you running sensors or purely just sensorless?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Post by district9prawn » Dec 29 2018 5:24am
evolutiongts wrote:
Dec 28 2018 9:00pm
No sensors. I've been considering emulating the halls with the encoder but I need to make it a bit more rugged and sealed against crap from the chain.
evolutiongts   10 kW
Post by evolutiongts » Dec 29 2018 12:13pm
Are you able to get smooth startup from a stop while running sensorless?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Post by district9prawn » Dec 29 2018 4:42pm
evolutiongts wrote:
Dec 29 2018 12:13pm
It starts smooth enough and reliably. Main downside is that the startup routine takes up around a third of a second during which the motor is unresponsive to brake or throttle input.
evolutiongts   10 kW
Post by evolutiongts » Jan 04 2019 10:00pm
Do you mind sharing your sensorless settings? I can never get sensorless to start up smoothly, thanks.
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Post by district9prawn » Jan 06 2019 11:10pm
Sensorless parameters are:
Starting current: 180A (I'm sure the full current is not used)
Open loop injection current ramp time: 60ms
Closed loop enable frequency: 16hz
Open loop frequency ramp time: 250ms
Open loop dc current hold time: 15ms
Current is quite high to make sure it starts reliably even on an incline or off road. Set up like this it enters closed loop quickly. On my 8 pole pair motor the back wheel rotates around one eight of a revolution in open loop, maybe less. Since the motor runs at a much higher erpm than a dd hub the controller should be able to enter closed loop at a lower speed.
Post by district9prawn » Jan 15 2019 6:53am
I'm going to start rebuilding the vesc quite soon. Have the pcbs for the new version and am ordering the parts now.
I also realised the encoder has ABI incremental outputs. Since they only need to be used for startup the quadrature signals will only be a few khz before transitioning to sensorless. Latency is still low as they are on interrupts. Much better than the 4mhz or whatever the spi was running at.
Post by district9prawn » Jan 31 2019 6:21pm
The new vesc is mostly soldered and tests good. Had a hiccup initially where the motor would just twitch with current readings all over the place. Turned out to be one current sensor which had a stuck output. All good after replacement.
evolutiongts   10 kW
Post by evolutiongts » Mar 04 2019 2:18am
How does the VESC compare to the ASI BAC4000? What is the max voltage supported by the VESC?
MUXUS 3K Turbo
Sabvoton 72V150A
Cyclone 3000W
74V 3000W
Post by district9prawn » Mar 04 2019 5:00am
evolutiongts wrote:
Mar 04 2019 2:18am
The asi controller can push much higher phase currents. Not just because it is rated for more but also because it is less affected by the change in motor parameters as the stator begins to saturate. At higher currents this can cause the vesc to lose track of the rotor in sensorless mode.
madin88   1 GW
1 GW
Post by madin88 » Mar 04 2019 5:37am
district9prawn wrote:
Mar 04 2019 5:00am
Wouldn't it be possible to program the VESC so that it always uses hall or resovler signal for tracking the rotor position?
Hmm, i have asked Neumotor about maximum torque of the 8057 (or maximum current before it saturates), but i never got an answer.
Post by district9prawn » Mar 04 2019 5:25pm
madin88 wrote:
Mar 04 2019 5:37am
Yes using sensors at higher rpm fixes it. I don't want to use the encoder over the entire rpm range as sensorless is a bit more efficient at high speed. And at high speeds the currents are not high enough to saturate.
The vesc actually has a setting to compensate for stator saturation but it is quite crude as is just scales the compensation factor linearly based on the phase current. Apparently Vedder is working on getting the initial parameter detection to properly map the saturation curve.
I can sort of tell where saturation starts to kick in by changing the current used for L/R measurement. At high currents the returned inductance is significantly lower. I don't feel that some saturation is a problem for short bursts of acceleration. As long as it does not cause problems for the controller
Also I forgot to mention in my previous post. The voltage is limited by the current sensors which are only good to 80v. I used 100v fets and caps though.
Post by district9prawn » Mar 21 2019 12:50am
New controller is pretty much done. I've also just finished soldering a much more compact version of the a200s which uses 18 directfets.
Footprint of the directfet version is barely larger than a regular 6 fet controller.
The bus bars and larger fets of the bigger controller should allow for higher peak currents but the compact layout of the directfet controller should allow it to drive all sorts of silly motors reliably.
Post by district9prawn » Mar 24 2019 9:05pm
A few more pics of the completed boards for those that cant get enough controller pics.
madin88   1 GW
1 GW
Post by madin88 » Apr 03 2019 6:36am
Nice!
Have you seen the VESC app with speedometer and dashboard?
By now the lack of a display function has kept me from using VESC on e-bikes, and given that there are already plenty of different and affordable VESC6 controllers availbe these days this is quite a highlight.
https://play.google.com/store/apps/deta ... r.vesctool
litespeed   100 kW
Post by litespeed » Apr 03 2019 8:12am
What a great dashboard that would be.
Tom
madin88   1 GW
1 GW
Post by madin88 » Apr 03 2019 8:29am
The display of duty cycle is a nice thing
Post by district9prawn » Apr 03 2019 8:22pm
I've used vesc-tool with BLE on android and linux a fair bit but only for testing on the bench. Don't really like phone on handlebars even if it is a cheap one just used as a display.
The main problem with using it for display is that the watt-hours and battery current may not be that accurate since it is calculated from motor current and duty cycle. And the accuracy can vary depending on motor configuration and how you ride as well.
I wish I knew how to build the app to show other values such as field weakening current.
Post by district9prawn » Apr 10 2019 9:44pm
The v1.3 a200s board with the hsof-8 fets has been running well. Played around with the observer gains and rc filters on the current sense output. Now I can be as rough on the throttle as I want at 300A phase in sensorless. Everything is smooth with no faults.
Been trying to find a better way to handle low speed braking. Currently what the vesc does is modulate shorting windings when braking at very low speeds. At a crawl this works well but go a bit faster and the motor will cog. In regular current control mode the motor will also begin to cog as the low speed causes the controller to lose sync. So there is a erpm range where neither duty cycle mode or current control mode can brake smoothly.
On the bench I tried using position control mode to provide active braking at low speed with an encoder. Hopefully this translates well to actual riding.
madin88   1 GW
1 GW
Post by madin88 » Apr 11 2019 7:15am
Apr 10 2019 9:44pm
Does the controller need a given motor RPM or does it supply the 300A from a dead stop without loosing sync?
Down to which speed does regen braking work?
I am happy if regen does slow me down to around 5kmh and so i never did use active braking on my adaptto controllers (only for tests) due to the fact that it does take energy from the battery (to produce reverse torque).
At high settings this active braking was as strong as the hydraulic and i could lock the wheel.
The thing with the shorted motors phases sounds interesting, but wouldn't this heat it up alot?
Post by district9prawn » Apr 11 2019 10:18am
madin88 wrote:
Apr 11 2019 7:15am
It starts smoothly but the very first bit of acceleration won't be as strong as a sensored setup. Maybe from 0-2 km/h. After that its the same. It's still an improvement over the ASI sensorless start as the open loop routine is always the same. So however you configure it there will always be situations where it doesn't feel right.
madin88 wrote:
Apr 11 2019 7:15am
Down to walking speed so perhaps 3-4 kph? The shorting phases don't result in much heat as it is just from like 3kph to stop.
It would be cool to get active braking working well. I really liked how the ASI controllers could do active braking to zero in sensorless without overshooting and causing reverse rotation.
