airvibrations
10 µW
- Joined
- Nov 21, 2018
- Messages
- 5
Hi all,
New here but wanted to share along my conversion project.
Donor bike: https://www.specialized.com/us/en/awol-elite/p/65539
This has been my primary commuter bike for just shy of four years. The ride into work is about 12 miles, over the Golden Gate Bridge into downtown SF -- but I'm moving just a bit further north and want to keep riding.
For motor I wanted some thing as stealthy as possible, so I went with the Bafang G310 Grin Kit from the guys at ebikes.ca.
For the battery I went for the Luna Wolf pack - 52v 13.5 ah. The mounting system seems to be much more well conceived than other packs out there and the thing looks like you could throw it off the back of a truck and still use it after.
One problem that I have yet to fully solve is the difficulty of the drop-bar conversion. But I have a few workarounds that I think will work:
Bar extenders: https://www.amazon.com/gp/product/B07FD5DLG9/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
These things are pretty cheap on Amazon but should give me the ability to run 22.2mm clamps for the throttle, pas adjustment, etc.
Brake Sensor: I'm planning to find some way to rig a Tripwire https://www.ebikes.ca/product-info/tripwire.html up to the front brake pull, running it under the bar wraps alongside the brake cable.
A few questions I have at this point:
Programming the Cycle Analyst... Do I need to do set a power limit or has it already been set to this motor?
Reliability of the brake cutoff?
How do I keep this motor from overheating without a temp sensor?
A big shout-out already to the Grin team at ebikes.ca they turned around my order less than 24 hours. Also, I contacted Luna to ask specifically for the Panasonic cells in the Wolf motor and they did oblige, despite those not being an option currently on their website. So far both companies have been pretty rad.
