Pack build: Sewer Pipe Dynamite Roll
fourbanger   100 W
Post by fourbanger » Dec 08 2018 3:12pm
Well, for my first pack build I thought I'd make things as difficult as possible for myself so I decided to go with a cylindrical pack using a 4" PVC pipe as a container. Wow. Ok, here goes...
These stupid little cell cases actually came in handy.
After scratching the terminals with some medium grit, applying the insulation ring around the positive terminal and pre-soldering both ends of each cell, the next step is to start gluing them into the shape I need.
Ok. So once I've gotten 3 groups of six together like this I now need to arrange them all in a happy little circle. BUT, I'm already kind of pissing in the wind not using cell spacers of any kind, so the least I could do is make some attempt at keeping the parallel groups from rubbing up against each other too friendly like.
Really two would have been fine, but the lack of symmetry was killing me.
I did say this was the least I could do, didn't I?
Righteo, now for some insulative material. Packing foam engage!
Packing tape sucks. If only there were a better way...
Don't these just look good enough to eat?
So now for the really gruesome part. I've got a few lengths of 10 gauge marine grade wire that I poached from the marina where I was working at the time. In my infinite wisdom, I thought it would be a good idea to have these act as both parallel and series connectors. All I have to do is cut them to size, strip an appropriate amount of insulation off each end, divide the strands into six "tendrils" of equal number at each end and solder them in series. What could be easier??
This photo is deceptive; there are in fact many, MANY tiny strands to this wire.
Are we having fun yet?
Apart from the obvious high level of craftsmanship, please also note the little speaker wire running off the left hand side. Moron that later...
According to my camera roll, this is around the point where I start getting too pissed off/lazy/ashamed to keep taking pictures, so I'll try to give you the play by play and you can use your imagination to follow along. Basically, the next piece of sush is butted up adjacent to the one pictured above, the series connection is soldered and the one is folded over top of the other with a circle of corrugated plastic (a realtor sign, I believe) placed in betwixt. The whole thing is taped up in a cylinder because I don't have any PVC heat shrink and then we sit back any admire our *ahem* handiwork.
Yea, I forgot the soy sauce. Sue me.
Once the guts are ready, I need to do a bit of light fabridoodling to the end cap of the pipe it's self. Again I slacked on the photos, but drills and little hand files were involved. I'm pretty sure you get the idea..
The DB15 connector is for the sense wires (hopefully obvious). Also there's a 40A fuse stuffed in there.
After not having any fun at all and ruining one DB15 trying to solder in the speaker wire, a trip down to the electronics store revealed that these connectors can be had for ribbon wire. All you need to do is clamp the connector to the ribbon and the little teeth cut through the insulation and make the connection. If I'd known I wouldn't have bothered screwing around with speaker wire... Oh well.
You guys probably already knew this but these types of connectors can be had in pretty much any pinout under the sun. Neat.
Pretty much done but for the crying at this point. Gently cram the whole works into the pipe and silicone the ends on in such a way that keeps water out but you can still get in with a sharp knife. But yea, it looks a little something like this.
Buddha is pleased.
Bananas for scale.
Well I wouldn't try getting on a plane with this thing, but there it is. TADA!
Things I'd do different if I were to do it again: Pretty much everything, really. For starters, trimming that 10awg wire to size and separating the little strands one at a time (and counting them to make sure they are all equal) was just WAY too tedious. I could have achieved the same thing by using six lengths of smaller gauge wire and pigtailing the ends, then stuffing said pigtail down that handy little hole in the center of the, uh, roll. Might even be a good place to use bullet connectors if I need to service a particular P group. On that note, I probably would have been better off segregating each group of cells individually (using PVC heat shrink rather than packing tape) instead of fastening three groups together like I did. Also, it would have made more sense to cut a long strip of packing foam and slide it into the pipe instead of wrapping the groups individually. Real insulation paper of some kind rather than a plastic sign board would have been a boon (in addition to heat shrink) and would have maybe saved me enough space in length to fit a little BMS in there. Maybe. Also also cell spacers of some kind. Even though each cell has a *little bit* of breathing room, if I could find a way to keep them apart even a little bit more while still providing some cushioning from potential impacts, that would be better still.
When it's all said and done I'm actually fairly happy with the end result. This pack attached to the top tube of a "traditional" shaped diamond frame bike will give me the gas tank look I'm after.
So there you have it. I'm sure this has already been done before, but I haven't actually seen any really good examples of it so I thought I'd provide a bad one for you to avoid if you think you'd like to emulate this sort of thing.
As for me, I do believe I'll build myself a spot welder and the next pack I put together will be shaped like a RECTANGLE!
larsb   1 MW
Re: Pack build: Sewer Pipe Dynamite Roll
Post by larsb » Dec 09 2018 7:48am
:thumb:
Good effort! Liked it a lot. Next time you'll cut the work in half :D
I've been thinking about doing a 7P 18650 pack in the future, the round batteries form a completely filled circle and fits the smallest possible space so it was interesting to see your approach.
Ride on!
fourbanger   100 W
Post by fourbanger » Dec 10 2018 12:40am
Check this out. I originally tried for a different, more friendly six pack configuration, but this is the shape the cells wanted to go for.
flower-consciousness copy 19 circles.jpg (156.81 KiB) Viewed 487 times
And this poor bastard has it all figured out...
http://hydra.nat.uni-magdeburg.de/packi ... cci19.html
