Bafang Ultra, Minnesota 1.2, Fatbike
Show off your Ebike creation here.
Flash-FX   10 mW
Post by Flash-FX » Mar 21 2019 9:09pm
Ok, here's the starting point. A stock inexpensive aluminum frame fatbike. I decided the ultra motor would be a bit more refined than a BBHD (torque sensing and power) for this build. One of the biggest challenges I see that people have is attaching the Ultra motor assembly to an existing frame...Without panic. How does one go about making it fit like it was designed for the frame? How do you align the chain line? Will the bottom bracket be in the same location as factory? Follow along and see how I "cheated" on some of these issues.
Flash-FX   10 mW
Re: Befang Ultra, Minnesota 1.2, Fatbike
Post by Flash-FX » Mar 21 2019 9:15pm
Flash-FX   10 mW
Post by Flash-FX » Mar 21 2019 9:39pm
Using the isis drive tube as a central starting point, a 1/2" od. piece of aluminum bar fit perfectly inside. Then I machined 2 bushings to fit inside the bottom bracket to accept the 1/2" bar (slip fit).
Flash-FX   10 mW
Post by Flash-FX » Mar 21 2019 10:15pm
Now that the hard part is figured out, time to make the support cradle that's going to hold everything aligned. I sliced some thick walled 2-1/4" exhaust tubing and hose clamped the pieces on to the frame. The 2 outboard plates were just 1/8" scrap plate with 1/2" holes. Then welded 1" x 1/8" flat stock to the "pads". This created the support structure. The 1/2" holes had just enough clearance to allow the bar to slide in or out without binding. All the weld surfaces were either ground down or wire brushed clean for the mig weld. This framework was quick and dirty.
Flash-FX   10 mW
Post by Flash-FX » Mar 21 2019 10:47pm
Next, I biased the 1/2" aluminum bar to one side, then slid the motor assembly (outboard of the fixture) with the Befang aluminum cradle attached (not shown in the pix). This allowed for cut lines to be transferred onto the bike frame (using a straight edge). I did this on both left and right sides. The only issue was with the chainstays, they ended up being wider than the factory Befang mounting plate. The chainstay tubing bent fairly easy and had to make a couple crescent moon shaped pieces to weld in (3003 soft x 1/8" thick) as fillers.
Flash-FX   10 mW
Post by Flash-FX » Mar 21 2019 11:15pm
Tack welded the tubes, removed the support fixture, and finish welded the frame. Also welded on a couple tabs for a rack...
Chainstay issue
Flash-FX   10 mW
Post by Flash-FX » Mar 21 2019 11:17pm
The "T Rex" support
Flash-FX   10 mW
Post by Flash-FX » Mar 21 2019 11:20pm
Some primer and flat black to match the original finish. Then check fit and chain line.
competitions   100 W
Post by competitions » Mar 22 2019 2:35am
Fantastic!
elias   100 mW
Post by elias » Mar 22 2019 5:54am
Flash-FX wrote:
Mar 21 2019 11:17pm
The "T Rex" support
What clever and easy solution! I built a whole jig for that (but I wanted a jig anyway, so that was OK)
Did you measure everything after welding? Is everything really straight?
elias
Flash-FX   10 mW
Post by Flash-FX » Mar 22 2019 6:20am
Ha! I saw your awesome fixture and was thinking I should follow that setup. If I didn't have a "already built" frame, that would be the best way to approach the build. As far as "measuring" goes, the chain line falls exactly where I wanted it to (on #5 cog). The Befang motor mount did distort slightly during welding, the holes were trued up with a chucking reamer.
Flash-FX   10 mW
Post by Flash-FX » Mar 22 2019 6:45am
I made a couple replacement motor mount bolts from some 10mm bar stock and 8 x 1.25 SS cap screws. The hardware and sprocket that come with the Befang kit belong on the USS Merrimack.
Flash-FX   10 mW
Post by Flash-FX » Mar 22 2019 8:12am
Need to tidy up the wiring and sort out some other details, but had to take it for a shakedown ride on the bike path (20 miles, returned with 53.7v). Added some full fenders from RadRover (going to ride this thing on the beach and want to minimize the salt and sand spray over everything). Some gear changes are needed but it ran OK for the maiden voyage. Tipping the scales @52lbs with a 52v 14ah Luna battery.
Grantmac   10 kW
Re: Bafang Ultra, Minnesota 1.2, Fatbike
Post by Grantmac » Mar 22 2019 11:23am
Any heat treatment after welding?
elias   100 mW
Post by elias » Mar 22 2019 2:35pm
Flash-FX wrote:
Mar 22 2019 6:20am
Same with my mount. About 0,5mm the worst. The file is your friend...
elias   100 mW
Post by elias » Mar 22 2019 2:39pm
Flash-FX wrote:
Mar 22 2019 8:12am
Do you run the Bafang with stock controller on 52V? Mine blew up the second I plugged it in the 52v battery for the first time. THEN I went for the phaserunner...
Flash-FX   10 mW
Post by Flash-FX » Mar 22 2019 4:39pm
elias wrote:
Mar 22 2019 2:39pm
Flash-FX wrote:
Mar 22 2019 8:12am
Well that sux.... I bought the motor, battery and charger from Luna Cycle. It is advertised to run on 48v to 52v. Hopefully the way it comes from them it will continue to run without issues. I really don't want to start modifying the controller and all of that. In 4th gear (44T x 25T) it got up to 31mph (indicated) without pedaling, and seemed to have a bit to go. That is pretty sketchy on this chubby hardtail. I think if I wanted to go for speed, I'd definitely choose a different frame.
elias   100 mW
Post by elias » Mar 22 2019 4:52pm
Flash-FX wrote:
Mar 22 2019 4:39pm
Indeed! :wink:
But it must be fun on the beach!
Flash-FX   10 mW
Post by Flash-FX » Mar 22 2019 11:26pm
Grantmac wrote:
Mar 22 2019 11:23am
Grantmac, no post heat treating. All of the factory powder coat would have to be stripped off before it would go into a oven. This is a inexpensive bike but looks to have been built with good quality tubing. I checked out the tubing on the inside, from the removed bottom bracket area and It's hard to tell if the factory even heat treated it. If it breaks, I'll just fix it.
Flash-FX   10 mW
Post by Flash-FX » Mar 24 2019 7:31pm
For you Ultra guys... $9.99 from Jensen Cycle. Just deep enough to get over the isis shaft.
Foundation 29BB tool.jpg (73.58 KiB) Viewed 5336 times
Flash-FX   10 mW
Post by Flash-FX » Mar 27 2019 6:43pm
Ok, time for some fine tuning...in the sprocket department. The 44T Bafang supplied chainring was just a tad too big for this bike. I need smaller. I've seen early ultra motors with the 104bcd 4 arm spiders but can not find any. So, here we go....I just so happened to have the parts lying around to make one.
3" bar and 1/4" plate, both 6061
Flash-FX   10 mW
Post by Flash-FX » Mar 27 2019 6:51pm
The output drive spline on the Ultra motor has 34T. That was fun to make....
Roughed out part. Measuring the minor diameter of the spline.
Spline cut and test fit
The back side
Flash-FX   10 mW
Post by Flash-FX » Mar 27 2019 7:11pm
Before welding, I had attached the disc to the "tube" for test fit. The crank arms have a short offset and hit the sprocket support in the center ID. The tube was trimmed down just enough for final clearance. I was hoping for no chain ring spacers in the end but, it didn't work out like that. After things cooled down, I drilled and tapped the 4 holes. Then trimmed off the excess.
Cut a nice "V" groove for the weld bead.
The "weld"
Flash-FX   10 mW
Post by Flash-FX » Mar 27 2019 7:27pm
I wonder how long it will be before you can just go out and buy one??
Anodized black would be killer.
6x1.0 jamb nuts...just in case
And the BIG question...How much does it weigh?? a whopping 232gr. And it could actually be designed to weigh less.
So far a improvement for off road. And it still can go 30mph
Tpesl   1 mW
Post by Tpesl » Apr 08 2019 6:36pm
Thanks for the instructions very informative , i’ll be doing the same thing shortly , my question is do you find that it’s absolutely crucial to have the Bottom bracket at exactly the same position as it was before I can’t see that it would make such a big difference if it was slightly forward or backwards or higher or lower as long as it’s lined up.
Also do you think that if you didn’t do all that support around it before cutting it you would never be able to line it up again? I don’t have an access to a welder so I will have to figure something else.
Thank you
