Dewalt Hyperfat electric bike DEWALT POWER STATION BATTERY BANK
Snowplowcar   1 µW
Post by Snowplowcar » Apr 07 2019 2:21pm
Image[/img]2018 DEWALT POWER STATION Powered HYPERFAT 67.2ah
52V
12ah X 4 = 48 +
19.2ah stock
=67.2ah
Cycle satior charges battery while riding (4amps)
200+ mile range in eco mode.
https://youtu.be/RgKtZrp0FxE
Reason: Add Yt tag
Snowplowcar   1 µW
200 mile range dewalt power station
Post by Snowplowcar » Apr 07 2019 5:53pm
67.2 amp hours
52V
200 mile range in eco
35mph
4 12 amp hour dewalt batteries plus 19.2 amp hour stock battery.
bakaneko   100 W
Re: Dewalt Hyperfat electric bike DEWALT POWER STATION BATTERY BANK
Post by bakaneko » Apr 27 2019 7:14am
nice range. how much did the dewalt batteries cost for each one and setup in total (Dewalt part)?
E-HP   100 kW
Post by E-HP » Apr 27 2019 9:41am
I think the 12 ah rating on those Dewalt flex voltage batteries is marketing, and the rating is at 20 volts. If you look at the battery specs, it can provide 240 watt hours (12 x 20), that's the equivalent of 4.6 ah each, at 52 volts. Still a lot of capacity, when you add it all up. You need to look at watt hours when comparing batteries of different voltages.
https://www.dewalt.com/products/accesso ... ery/dcb612
spinningmagnets   100 GW
Post by spinningmagnets » Apr 27 2019 11:06am
Be aware that the flexvolt system uses 15-cell battery packs which can be automatically configured to 5S / 3P, or....15S / 1P...depending on which tool it is inserted into.
3.6V Nominal___4.2V max charge per cell
5S______18V___21V
15S_____54V___63V
I do NOT recommend using 15S on BBSHD/BBS02/TSDZ2, Which have 63V max capacitors in their controllers. But this poster is using a hubmotor, so he should be OK.
bakaneko   100 W
Post by bakaneko » Apr 28 2019 7:17am
yeah, i am always on the hunt for a bargain or a new use for batteries from a different sector. it all depends on cost though and scalability. It looks like scalability is pretty decent from the video but what is the cost?
