bbs02 stops working when cold
travisraw   1 µW
Post by travisraw » Feb 17 2020 11:00am
I am a new to ebike world. Built my first using a bbs02b with 48v hailong 13ah battery. 850c display on an old ccm 29er frame.
everything was perfect for first 100k. Now as soon as bike is cold. -7 c or so the throttle and the pas stop. as soon as i walk my bike home and it warms up it works perfect again? Please can some one offer me guidance?
travisraw   1 µW
cold temp problem bbs02
Post by travisraw » Feb 17 2020 11:08am
DogDipstick   1 kW
Re: bbs02 stops working when cold
Post by DogDipstick » Feb 17 2020 12:10pm
Does the BMS control a LOWTEMP shutoff? Many will stop power on very low temps.
Allota Watts @ 83.1v of raw QS power takes me everywhere on my Ironhorse DW link XC... :) Powered by Chevy. :D Broke 10 horses the other day. ( BTW; ...don't get hurt... :? )... (Currently building a battery datalogger.). :roll: Playin with (24) IRFB4115s now. :wink:
john61ct   1.21 GW
1.21 GW
Post by john61ct » Feb 18 2020 6:13am
Feature not a bug
AngryBob   100 W
Post by AngryBob » Mar 14 2020 5:41pm
RTFM?
miro13car   1 MW
Post by miro13car » Mar 25 2020 12:23pm
are you kidding me?
whatever ebike drive cut off at minus7C outside?
my ebike drive EPLUS works normally in minus 17C winter with no problems.
battery made of Nissan Leaf cells 11S do not suffer any damage at minus7C for sure.
hailong cells suffer at minus 7C ???!!!
Eplus, Bionx
john61ct   1.21 GW
1.21 GW
Post by john61ct » Mar 25 2020 2:14pm
Discharge is different
Fast charging that cold can murder the pack
markz   100 GW
Post by markz » Mar 25 2020 2:56pm
Engineered failure for higher profits
miro13car wrote:
Mar 25 2020 12:23pm
docw009   100 kW
Post by docw009 » Mar 25 2020 3:13pm
-7C is about 20F. Could be some batteries that shut off below 32F. Mine don't.
AngryBob   100 W
Post by AngryBob » Mar 25 2020 7:03pm
Since this is not likely to be a hardware fault, you could spend a few hours researching the BMS and controller you purchased, or go very carefully through all user-available settings for each and look for a temp cutoff you can modify.
Also you could look carefully for a temp sensor, they are pretty standard and easy to identify. Then, you can find out what happens if you simply disable it, if that fails then either rig a small heat source or a way to spoof it. Possibly as simple as replacing with a differently-calibrated sensor.
john61ct   1.21 GW
1.21 GW
Post by john61ct » Mar 25 2020 8:31pm
Many BMS don't know from temperatures at. all.
AngryBob   100 W
Post by AngryBob » Mar 26 2020 6:35am
Some component on his system apparently does.
serious_sam   100 W
Post by serious_sam » Mar 29 2020 12:47am
Could be significant battery IR increase due to cold. Battery voltage drops under load. Either BMS or controller cuts out due to LVC. No problems with IR when battery temperature increases.
