C Cab Hot Rod Power Advice
ZeroEm   10 MW
Re: C Cab Hot Rod Power Advice
Post by ZeroEm » Nov 05 2021 11:11am
Think that thing is looking good! Just keeps getting better.
2019 Performer E-Trike
2013 Nissan Leaf S 7 bars 331.5w/KM
Just_Ed   1 kW
Post by Just_Ed » Nov 10 2021 9:01pm
OK, SlowCo, how about this?
I didn't think I would like them mounted to the headlight buckets. But I do.
It helps break up the bulky look of the headlights.
They look a lot better than the 2D photos.
You are never to old,
----------- to set another goal,
--------------- or have a new dream.
SlowCo   1 MW
Post by SlowCo » Nov 11 2021 5:29am
Yes, they look great on top of the headlights :thumb:
ZeroEm   10 MW
Post by ZeroEm » Nov 11 2021 8:30am
Them lights are bulky, more than imagined. They look good don't they. Gives your rod that attention grabber.
Just_Ed   1 kW
Post by Just_Ed » Nov 11 2021 9:55am
ZeroEm wrote:
Nov 11 2021 8:30am
The photos make them look bulkier than in reality. Viewing them with the rest of the car, they are OK.
Just_Ed   1 kW
Post by Just_Ed » Nov 13 2021 7:51pm
Removed the threaded insert to make way for welding on the light brackets.
Enlarged the hole where the wires will go on their way up the frame rail to the battery/converter.
The inner guide tube for the outer cover, that serves as the base for the headlights.
Outer 'pvc' cover installed. Also repositioned the support rods for the windshield.
Both covers on, sans headlights.
This went like clockwork, except for the toe in/toe out, changed. And by a large amount too.
I have no idea what caused it. I did remove the radius rods ( one side at a time, then replaced) to gain access to the insert, but they went back just as they came off.
Can be adjusted, but I sure would like to know how it became misaligned.
Just_Ed   1 kW
Post by Just_Ed » Nov 14 2021 10:16pm
Discovered why the toe-in/toe-out was so out of whack.
The right side steering arm became loose. It was moving in the retaining slot/keyway.
This photo shows what it looked like before repair. I didn't do a good enough welding job the first time, so there wasn't enough material in the slot to hold very well.
I added additional weld material in the highlighted area below before any weld material was added. Then I spent a good portion of the morning filing until it, fit snug and tight.
Also completed a long-standing project of lengthening the connecting rod, and cutting the radius rod bolts down to size.
ZeroEm   10 MW
Post by ZeroEm » Nov 15 2021 7:00am
Glad you found it now, sitting still.
Just_Ed   1 kW
Post by Just_Ed » Nov 15 2021 11:06pm
No sooner did I receive my 100' of 14 gauge wire (10 colors @ $36.33) and I run across this
https://www.ebay.com/itm/192903024630?_ ... %3A2563228
On the surface, this seems to be the smarter choice. And for less money - $33.55 out the door.
Comes with instructions as well. Although I don't really need all those circuits.
Shipping for return is free on the wires I got today.
Does anyone want to offer up an opinion as to changing to the new wiring kit?
ZeroEm   10 MW
Post by ZeroEm » Nov 16 2021 4:03pm
Just an option. Don't construe this as expert advise. Unless that muscle car wiring kit fit a body style or type do see how it would be better unless it comes with a connector kit.
This kit has circuits for A/C, Ignition/Battery, Gauges, Brake switch, Flasher, Headlight, Wiper, Ignition, Battery/Hazard, Ignition On, ACC 1, Heater and, ACC 2, Fusible Link and, Butt Connectors.
The connectors are worth something. You will get a few that you don't need but maybe enought that you do. Depend if you have the connectors or not?
Just_Ed   1 kW
Post by Just_Ed » Nov 18 2021 10:18am
I have decided to go with this kit. Seems the better option, with all the fuses, semi-prewired, etc.
https://www.ebay.com/ipp/265409020053?t ... 675.l48352
I have found multiple listings for the same or similar and finally put in an offer for this one.
I'm supposed to get the kit by Tuesday, but the seller is only 65 miles from me, so I might receive it by Saturday.
Thinking ahead to the future, I'm wanting to build an electrical component box that stays even with the body off. Or can be easily disconnected to facilitate its removal.
Remember now, if I live long enough, this chassis will be used for other body types.
The wiring, including the converter, will all go in this cavity back/under the seat.
The box needs to fit between the two motors. Probably not more than 3-4 inches deep.
Access gained from a removable or drop-down door.
Just_Ed   1 kW
Post by Just_Ed » Nov 25 2021 12:52am
Update - After some monkey business with the seller, I finally got the correct (I hope) harness on order.
And at the agreed-upon previous reduced price.
Should be here next Wed/Thu.
I have changed the location for installing the converter and fuse box.
Just ahead of the pillow block and behind the existing controllers.
I fab'd a box that fits in that area to hold each component.
Photos later.
I have started working on the schematic.
Seems simple enough at this point.
It has a relay installed, but I'm not sure what I should be using it for. Wiring it too.
This is just a rough idea of what circuits I may need.
12 VOLT SCHEMATIC.png (27.3 KiB) Viewed 128 times
The instructions, that will be coming with the kit.
I won't be needing all that is in the instructions, but it helps to get started.
https://www.jegs.com/InstallationInstructions/700/746/746-pce368.1011.pdf
fechter   100 GW
Post by fechter » Nov 25 2021 11:24am
The relay would be useful for any loads that are too big for a switch. You may not need it.
Just_Ed   1 kW
Post by Just_Ed » Nov 25 2021 12:06pm
fechter wrote:
Nov 25 2021 11:24am
Thanks, fechter
I'm eager to put together this wiring spaghetti, but really can't until I get the harness in front of these tired eyes.
Seeing is believing and makes it come clearer quicker.
I hope to lay out the wiring on a board, giving me a better sense of what goes where. Then hook it up and try it before installing it in the car.
May you and yours have a Happy Thanksgiving.
Just_Ed   1 kW
Post by Just_Ed » Nov 26 2021 1:12pm
I'm working on where and what type (if any) switches I will need.
One thought is about the circuit breaker being used as the on-off switch.
This breaker will be concealed under the battery cover when completed.
I want to turn the battery on-off outside of the battery box, via repositioning the breaker or an external switch.
Some of my research on (you know the youtube academy of higher learning) tells me these types of batteries (specifically the type I have) are potential fire hazards. https://www.youtube.com/watch?v=rbkE4jxk3u8
Q1 - While in the learning phase of this type of power source, is it safe to leave the battery on, and use an external on-off for the system? I'm thinking this isn't a good idea.
Q2 - Will leaving the battery in the on position, on this type power source/battery - say out for the day at an event of some sort, have any adverse effects or on its longevity (depleting power), etc?
amberwolf   100 GW
Post by amberwolf » Nov 26 2021 8:13pm
Just_Ed wrote:
Nov 26 2021 1:12pm
All batteries are potential fire hazards. ;)
Is the existing battery switch something that completely disconnects the internal electronics (BMS, meter, etc) from the cells? If not, then it doesn't really matter whether the switch is inside the battery or outside it.
But you do want any fuses or circuit breakers as close to the battery output as possible in the wiring harness, so that they will disconnect it from the system in the case of a wiring short to prevent a wiring fire.
Longevity? Unlikely.
Power usage over the day? Depends on how much power draw there is from any internal electronics in it that are normally shut off by it's internal power switch. That's probably pretty minimal, if there is any at all. Most of the time any internal electronics (BMS) are powered all the time by the cells, though some BMSs have a shutdown mode that draws very little current (microamps) vs their active current (milliamps).
If there is a voltmeter on the battery itself that is shut off by the internal switch, then it may draw a few dozen to a couple hundred milliamps, depending on design.
If it has a button you have to push on the meter to activate it, it probably doesn't draw hardly anything at all unless the button is pushed.
If you found this advice helpful, supporting contributions are accepted here. Presently on unpaid medical leave of indeterminate length.
See here for Details: Beginning of a New Life
fechter   100 GW
Post by fechter » Nov 26 2021 11:46pm
I'd just leave the main breaker off for storage. Don't forget to turn it on next time you want to run the car! (There's a story behind the advice).
Just_Ed   1 kW
Post by Just_Ed » Nov 28 2021 1:31am
I got the wiring harness this morning - earlier than expected.
All the components were there, BUT! there's always a BUT!.
The diagram they sent with the harness isn't much good. It definitely isn't accurate, in black and white, and some connections will need to be changed as I am not running those components.
Haven't figured out what PAPKLT/RADIO MEM stands for. Or what BPUPE power is?
And what is the difference between (IGN SWITCH RUN) and (IGN RUN/START)?
Also the diagram they sent shows #14 and # 28 connected, ????????
What has been a benefit is the wires are marked as to what they are intended for. Not that they will be used in that manner but it gives me a starting point.
Here I am trying to make sense of where each wire is attached, what color they are, and how they labeled them. Have all the fuse sizes annotated and colored coded.
Next is to diagram out how the battery and converter hook up to this and then on to the switches/terminal blocks or components.
This isn't completed yet. Some terminals will be used for other components.
I still need to see how the fuse block is put together and how each connection works with other connections.
FUSE BOX WIRING-2.png (53.7 KiB) Viewed 54 times
ZeroEm   10 MW
Post by ZeroEm » Nov 28 2021 9:38am
In the age of electronics, most things like radios with presets or memory they need some power when everything is off to keep the settings. This is the ghost draw we see on electronics. Clocks, alarms, keyless entry and ignition. If you don't plan on any of these things then don't worry.
fechter   100 GW
Post by fechter » Nov 28 2021 12:21pm
I guess it doesn't come with an ignition key switch. With a car, the key has ACC, OFF, ON, START. The start position is spring loaded and returns to ON. You don't need the start line.
As ZeroEm states, the radio MEM line is always on regardless of key position.
No clue what BPUBE is.
I assume the relay was intended for a horn. I'm not sure if your dc-dc has enough power to drive a regular car horn. Possibly a small one.
I'd recommend tracing out the fuse block to see which terminals are internally connected. You can figure things out from there. Your layout needs to be a little different than a hot rod since your 12v is coming off the dc-dc. There are a lot of things there you probably don't need to use or worry about.
Just_Ed   1 kW
Post by Just_Ed » Nov 28 2021 1:05pm
I guess it doesn't come with an ignition key switch. With a car, the key has ACC, OFF, ON, START. The start position is spring-loaded and returns to ON. You don't need the start line.
I have a key switch that came with the controllers. It is basically an on/off switch.
I'm using this https://www.harborfreight.com/search?q=ooga%20horn
https://www.harborfreight.com/110-db-ol ... 96291.html
I was thinking it would be a direct hookup through a momentary button.
I made this diagram last night. The instructions aren't color-coded or match the fuse box, so I had to make my own. It's a work in progress and shows where the wires are connected and what their color code and intended use are.
FUSE BOX WIRING-2.png (53.7 KiB) Viewed 36 times
I know this fuse box is overkill. It just seems like I should due to the type of battery and its cost to replace. If it proves to be more difficult than necessary I am prepared to change or do away with it. It's a challenge. I'm OK with basic 120-volt wiring (I wired my shop) but this type of electronics kicks my butt. It's a lesson that is for sure.
I have looked [down into] the connectors in the fuse box trying to see how they come out. If I can do that without ruining them I may be able to rewire to just what I need.
Just_Ed   1 kW
Post by Just_Ed » Nov 28 2021 1:13pm
A 2nd opinion on this option, that has been suggested.
eds-layout2 (1).jpg (116.53 KiB) Viewed 35 times
fechter   100 GW
Post by fechter » Nov 29 2021 1:20am
I don't see the point of the relay there. You can turn off everything with the dc-dc.
I suggest only using the parts of it you really need and not use the rest. You can trim off wires you don't need or stuff them behind it.
