JesseW
Hi all,
I have a 1990 Honda CRX HF I'm hoping to put a Nissan Leaf Motor into, along the lines of Arlin Sansome's, but with the stock Leaf inverter (at least for now).
My local junk yard has access to parts from several Leafs so motors are cheap. Leaf batteries seem reasonably priced so I'll probably go with a gen 1 Leaf battery to start with. I'm in western WA so hopefully heat degradation isn't an issue. I'll probably take the pack apart and see how I can redistribute the modules around the CRX without being ridiculously sketchy.
First question is: does anyone know if a stock onboard leaf charger, hopefully a 6.6 kwh one, can be set up to charge a leaf battery transplanted when transplanted into a new vehicle? I should be able to get a leaf VCU to keep the charger happy if that's necessary. Considering the charging typically happens with the car off hopefully it would be pretty simple to get everything hooked to trick the VCU and Charger into working in another vehicle.
Also has anyone transplanted the whole leaf electrical system into a new vehicle? My guess is that it's easier to use the thunderstruck unit but how hard is it to do and get the Leaf VCU to work with in a new vehicle a Nissan gauge cluster etc.
Can anyone point me to forum threads on here or other sites where other people have done similar motor/battery swaps? I'm just looking for info on how to get through all the little challenges of putting everything together.
Thanks!
Thanks!
