72 to 52V DC DC converter - Do they exist?
skyeg3   1 W
1 W
Post by skyeg3 » Nov 04 2019 11:58pm
Hey All, So I built an electric quad using the motor and controller from a 2010 Zero motorcycle. The motor is a perm 132 and the controller is an alltrax that can take 52V. Thing is I spent $1200 on 72V batteries already because I thought I would be using a different controller. My question: Can I buy a voltage reducer? Would be sweet not to just waste them and buy new batteries. Is this advisable?
billvon   1 GW
1 GW
Re: 72 to 52V DC DC converter - Do they exist?
Post by billvon » Nov 05 2019 12:06am
skyeg3 wrote:
Nov 04 2019 11:58pm
It's doable. You will probably end up designing something yourself, and you will lose efficiency tho.
--bill von
amberwolf   100 GW
Post by amberwolf » Nov 05 2019 1:22am
Almost certainly going to be cheaper and/or more reliable / efficient to buy a controller that can operate on the voltage range your batteries produce.
john61ct   100 GW
Post by john61ct » Nov 05 2019 9:34am
At low amps cheap chinese may be affordable.
At high amps gets crazy pricey.
And IRL conversion efficiency, might get 85% at best.
fechter   100 GW
Post by fechter » Nov 05 2019 10:36am
I would look for a new controller that handles 72v. Kelly or Alltrax will have something. There are others out there. You may need to limit the throttle to keep the motor happy at the higher voltage.
skyeg3   1 W
1 W
Post by skyeg3 » Nov 06 2019 12:33am
After thinking about it more I think the 72V controller is the way to go. Thanks
