Drymer near production?
docnjoj   100 GW
Post by docnjoj » Dec 23 2010 2:15pm
I just got this e-mail but my Dutch is a little rusty :oops: I think all will be revealed on Jan 3 2011?
Maybe this should go in Electric bikes?
http://www.drymer.nl/startpagina
otherDoc
E-bike stable at our house
Steintrike Mad Max full suspension trike rear Cute 100H going on: Whoops, Cute wheel broke but I fixed it.
Sun USX delta trike EbikeKit small geared front wheel sort of front suspension for wife
Agniusm/A123 AMP 20 36 volts on the Steini has been taken off.
2x16000 Multisport from HK now gone as they died after 2 years
New Luna 10S bottle battery 13.6AH now on mine
Relatively New 10S4Px2 for wife's bike giving 20ah @ 40 volts home made Panasonic from Tumich. BMS's rule.
wheelbender6   100 W
Re: Drymer near production?
Post by wheelbender6 » Dec 26 2010 11:41am
How many euros for that? Is there an estimate on the site?
"Money can't buy you happiness, but it can buy you a yacht big enough to pull up right alongside it." - David Lee Roth
www.recumbents.com   10 kW
Post by www.recumbents.com » Dec 27 2010 1:16pm
Two versions - one is $4000 Euros, the other is $6000. Save your pennies..
wheelbender6   100 W
Post by wheelbender6 » Dec 31 2010 7:06pm
Hmmm. I could buy quite a few e-bikes with unbrella holders for that.
bigmoose   100 MW
Post by bigmoose » Jan 01 2011 10:00am
My Dutch is nonexistant, but via software translation:
Traction:Hybrid drive system: Pedal Assist (bicycle with electric staircase support to maximum. 25 km/h).
Radius of action:Approximately 70 km dependent of the degree of electric support and the maximum speed at this support.
Battery:48 volts of lithium ion, 15,4Ah, incl. x2 is optional.
Engine:250 W elektromotor incorporated in the rear wheel hub
Wheels: High-quality lichtmetalen Drymervelgen. :( haven't a clue what that means!
Dimension: Length = 2.01 m., breadth = 0.84 m.
To slow down:Hydraulic disk brakes on both voorwielen and mechanical disk brake on rear wheel.
Type:The Drymer are a bicycle with three wheels, two voorwielen and one rear wheel. The wheel framework to the front is provide with kantelmechanisme. The rear wheel has an one-armed framework. The wheel is provide with an electric traction with staircase support. The electronic system, with a file aid to 6 km, ensures that at reaching a speed of 25 km/h the elektromotorondersteuning are eliminated, so that it concerns a bicycle legally. Because of this carrying a helmet, a motorbike certificate and characterising plates is not necessary.
It clearly needs more power! :twisted: Het vergt meer macht!
Image Image Image Image Image
"Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God..." all the best, Dave
zenon   100 W
Post by zenon » Jan 03 2011 9:51pm
Pricey but nice, I wonder how will it performs at around 3 kilo watts mod., and compare to a ground scraping tadpole :)
Zenon
-Home build Tadpole trike with 9C 7turn motor peaks at 2.4 K watt, 54v 18AH Makita lithium packs 63V full charge
Charger - 48V 9A cc/cv power supply upgraded to supply 36v to 63v,
GM controller 36v 32A upgrade to 75V 45A
Top speed 60km/h
michaelplogue   10 kW
Post by michaelplogue » Jan 04 2011 7:19am
I think this is a great design, and very well suited to city commuting. It's upright configuration gives it much more visibility to drivers. However, it could definately use a significant power upgrade......
Gordo   100 kW
Post by Gordo » Jan 04 2011 11:57am
bigmoose wrote:My Dutch is nonexistant, but via software translation:
Wheels: High-quality lichtmetalen Drymervelgen. :( haven't a clue what that means! lichtmetalen=alloy
To slow down:Hydraulic disk brakes on both voor (front) wielen (wheels) and mechanical disk brake on rear wheel.
Type:The Drymer are a bicycle with three wheels, two voorwielen and one rear wheel. The wheel framework to the front is provide with kantelmechanisme (pedals). The rear wheel has an one-armed framework. The wheel is provide with an electric traction with staircase (pedal) support. The electronic system, with a file aid to 6 km, ensures that at reaching a speed of 25 km/h the elektromotorondersteuning are eliminated, so that it concerns a bicycle legally. Because of this carrying a helmet, a motorbike certificate and characterising (registration) plates is not necessary.
X-treme 3KW Scooter...OFF ROAD ONLY....Giant 1KW 48V 24" Hubmotor....E-Apex 1KW 48V 26" Hubmotor, built 2012-05-26
Thanks Justin, for saving ES. May Grin Tech grow and prosper.
oldpiper   1 kW
Post by oldpiper » Jan 04 2011 12:08pm
Gordo wrote:
bigmoose wrote: Type:The Drymer are a bicycle with three wheels, two voorwielen and one rear wheel. The wheel framework to the front is provide with kantelmechanisme (pedals). The rear wheel has an one-armed framework. The wheel is provide with an electric traction with staircase (pedal) support. The electronic system, with a file aid to 6 km, ensures that at reaching a speed of 25 km/h the elektromotorondersteuning are eliminated, so that it concerns a bicycle legally.
Darn, I thought it would maybe be a setup so that I could arrive at work automatically on the third floor, or it would pop out feet to get up and down the steps. At least the 6K Euro model. :(
Cameron
Schwinn StingRay OCC XL, front AmpedBikes DD hubmotor, 37V, 10 Ah Lipo
"If it jams-force it. If it breaks, it needed replacing anyway."
"Just because you're paranoid doesn't mean they aren't out to get you."
Hillhater   100 GW
Post by Hillhater » Jan 04 2011 7:43pm
another cleaver design that misses the point somewhat.
I didnt see any weight quoted, which probably means its north of 50kg !
All that neat suspension and weather proofing doesnt come cheap or light !
You would need all those 250watts to help pedal into the wind or that up the first hill ... but then again the Dutch dont have too many hills i guess ! :cry:
docnjoj   100 GW
Post by docnjoj » Jan 05 2011 8:26am
zenon wrote:Pricey but nice, I wonder how will it performs at around 3 kilo watts mod., and compare to a ground scraping tadpole :)
Zenon
That tilt technology should make the cornering pretty good and they have to comply with the 250 watt European limits. Maybe they have one of those "limiter wires" on the controller that one could cut for more power?
otherDoc
bluesrocks   10 W
Post by bluesrocks » Jun 28 2012 11:46am
Cool design, especially like tilt's-like-a-bike. I would also like to see a larger standard motor.
SamTexas   100 MW
Post by SamTexas » Jun 28 2012 12:21pm
Looks like a winner to me. Price is high, but then so is everything in Denmark. Just wait a year and there will be plenty of Taiwanese and Chinese clones at half the price.
Hillhater   100 GW
Post by Hillhater » Jun 28 2012 8:06pm
SamTexas wrote:... Just wait a year and there will be plenty of Taiwanese and Chinese clones at half the price.
I dont see them yet ?? .....this thread was started 18 months ago ! :roll:
LockH   100 GW
Post by LockH » Feb 19 2018 10:57am
[bump]
Looks like they're still a "going concern"...
Image seen on their Facebook site:
https://www.facebook.com/Drymer
https://drymer.nl/
viewtopic.php?f=3&t=57408
viewtopic.php?f=15&t=60564
Hillhater   100 GW
Post by Hillhater » Feb 19 2018 5:02pm
Certainly still making/selling velos, but i dont see the tadpole leaner anywhere on their shop site ?
Toorbough ULL-Zeveigh   10 MW
Post by Toorbough ULL-Zeveigh » Feb 20 2018 10:52am
and what duz THAT tell u?
3wheelz alwayz finnish lazt.
i no they're dutch
Kick down the barricades Listen what the kids say.
From time to time people change their minds But the Frock is here to stay.
I've seen it all from the bottom to the top Everywhere I go the kids wanna Frock.
Around the world or around the block Everywhere I go the kids wanna Frock.
LockH   100 GW
Post by LockH » Feb 20 2018 2:46pm
Hillhater wrote:
Feb 19 2018 5:02pm
https://www.drymer.nl/occasions/ :wink:
Hillhater   100 GW
Post by Hillhater » Feb 20 2018 6:45pm
Ahh !..... Thanks, that will teach me to look in the "shop" section for items to buy !!
Nice, and even an electric version,...but sure is a spendy little critter . :shock:
LockH   100 GW
Post by LockH » Feb 20 2018 8:23pm
Hehe... Funny Dutch... gotta a different word for EVerything (URL filed as "occasions"...) :roll:
ps... :lol:
Can ya imagine some thief trying to "sneak away" riding that?
