magudaman
I have a Kollmorgan 24 Volt brushless motor laying around and really wanted to use an external controller to really push this little motor (burned up the internal one). I was thinking something like 33v but 75-100a sensorless. I recall when I was running this motor on 24v it was able to do 50 amps but with the high voltage I would imagine it could do more. Of course I plan on doing force air cooling.
I have heard around the board of motor saturation under high voltage, high current applications, what is this? Will I run into this with this motor? Also do I risk instant failure by popping a internal winding or will it heat up before that?
