marty
I got a 1994 Ford E-250 Van. Big full size van. I got lots of used Makita power tool battery packs. If I did a electric vehicle conversion. About how many of these 18650 Li-Ion cells would it take to move this van 50 miles? I would be happy with a top speed of about 50 miles per hour. City driving only. If it helps figure this out? Van got about 10 miles per gallon of gasoline, highway and city driving. This truck has the aerodynamics of a refrigerator and weighs 5000 pounds empty.
I realize that this might be a stupid candidate for a electric vehicle conversion and I would be better off using a small car. But me and this van have had a very close relationship for the last 19 years. I bought her new. Van is no longer on the road. It starts and runs great. Needs a brake line and leaks a way lot of oil.
Here are some details of these battery cells:
Copy from:
Konion Makita LiMn battery care and feeding by Doctorbass
Post by Doctorbass » Fri May 06, 2011 2:06 am
http://www.endless-sphere.com/forums/vi ... 14&t=27707
Copy from:
Here are their specs:
18650V: ( the most popular for ebikes)
( same as the Sanyo’s UR18650W)
-Voltage range: 3.0 to 4.2V
-Nominal voltage 3.7V
-Capacity: 1500mAh(10C) to 1600mAh(1C)
-Max Discharge C rate: 10C ( 15-16A)
-Max Charge C-rate: 1.5 to 2C depending on the cooling
-Cycle life: 700 cycles to 75% initial capacity ( from BMZ manufacture)
-Cycle life claimed by Makita: 1200 cycles
-Internal resistance 30miliohm per cells
-Released in 2005... still existing in 2011
