He y guys, im having a bit of a problem getting the golden motor to work with my kelly controller. Using the golden 5000 watt motor with a kelly KBS controller (I actually will be using a KEB 350 AMP controller, but it had a defect issue and im waiting for a replacement so I have the little KBS on there for now, its a KBS72121L)
First off, there is very very low power. I mean, seems like less than a 250 watt hub motor. Bike cant get over 8mph.
Second if i turn the controller up to full, even with the chain off the motor, it causes an error on the kelly "Frequent Reset" (Ignore when i say "3 and then one" in the video, i looked closer and its just 3, then pause, then 3, then pause...etc). Its three blinks of the diag LED. This is at 72V. Ive tried every possible hall combination, and found the 2 that run smoothly, one in forward and one in reverse, so i dont think thats it. I put a voltmeter on the halls and slowly rotated the motor, and i see each one get a few volts as i turn it, so i would think the halls are ok.
I put up a video on youtube so you can see what i mean: http://www.youtube.com/watch?feature=player_detailpage&v=5CRS19PCl28
[youtube]http://www.youtube.com/watch?feature=player_detailpage&v=5CRS19PCl28[/youtube]
I'm stumped. Ive spent about 250 hours building this bike, machining parts and so forth, so you can imagine how tough it is not to be able to ride it! I would appreciate any help guys....thanks.
--John
--John
