Anti Wheelie / Controlled Wheelie + On and Off Road BlackBox
mwkeefer   10 MW
Post by mwkeefer » Jan 13 2015 12:58am
Hello All,
I have over and over again seen people requesting a simple method of adding a "legal" mode in their jurisdictions while still having offroad mode.
While this can be done with the CA (I believe) some people just don't want a CA.
Additionally I've noted posts here and on other vehicle forums about automatic wheelie control and am looking into providing that not just for showing off but for really fast bikes, if the loop is fast enough launch times should be improved due to lack of lift and wheel spin.
In short I have had all but the wheelie feature for a long time, adhering to US laws but I'm going to refine my spaghetti wireing on perfboard and offer it to the ES crowd first as PCBs (self populate) and allready assembled units.
These will work with Hall or PPM (RC) style input and output (so they convert it too) and if your not a direct rear drive situation with a regen controller, a solenoid will be required to apply mechanical friction to the rear brake assembly for wheelie mode.
Yes the wheelie mode was inspired by the new Audi but as soon as I saw it, I thought of all the open source projects for building a self balancing scooter or unicycle and began researching.
I have to design a clean PCB, touch up some atmega code (c is needed for fast enough response time to prevent whoops) and then I'll get the BOM and Quotes together...
I'm posting now to get suggestions for additional features I may have overlooked.
Regards,
Mike
Regards,
Mike
{My Rides]
2010 Dahon Jack - GNG v1 - LYEN 6FET - 20/40A - 18S2P10AH - Nom:66.6v,1332w
2004 Hard Rock Pro Disc - Recumpence ms eDrive v4 - Astro 3220 4T - 12S2P16AH - HV110 - Left Side Drive - Gearing: 38mph
Nominal Peak Power @ 60 seconds: 5328 watts - Maximum Power: 49.8v, 120A, 5872w
2010 Downtube 8FH - Stock GNG v1 Stock Controller - EB809XC - 12-16S
2012 Downtube Nova 7spd - Stock GNG v2 - 12S2P10AH - EB809 - 12S-16S - 20A/30A,Nom VCC: 44.4, 888w
parajared   10 kW
Re: Anti Wheelie / Controlled Wheelie + On and Off Road Blac
Post by parajared » Jan 13 2015 7:14pm
I bet an Arduino board would link right up to some gyros and your controller and program fairly easy.
How does the bike tell if its doing a wheelie or just climbing a really steep incline?
zombiess   100 MW
Post by zombiess » Jan 13 2015 7:48pm
Are you going to use brute force or control theory and a closed loop PI(D) controller?
macribs   1.21 GW
1.21 GW
Post by macribs » Mar 03 2015 6:00am
Thank you mwkeefer. I'll take one for sure.
This has been a "wet dream" of mine for a couple of years now ever since I first saw that Audi e-bike. :D
If you are going to make a "black box" may I suggest lane change warning, that detect your blind spot to avoid swirling over in the next lane right in front a fast moving vehicle. I've seen a concept on kickstarter for lane change warning. They had made buzzer that vibrated your handlebar if it was not safe to change lane.
Would it be possible to somehow take advantage of peoples smartphones - for GPS or whatever? Or to take advantage of the wifi?
Like the cobi.bike? They added wireless rear light that double as a brake light and turnsignals. Look it up it is clever.
Are you planning this as a open source project firmware? Where people can work together to keep improving, adding features etc.
That could be a real nice community spirited drive for ensuring evolution over time. And have you given can bus any thoughts?
I mean once a black is there - what is the limit?
Think of all the cool things we can do with a smartphones these days. They relay heavily on various action sensors. E-bikes need more sensors, gyros and ability to keep on evolving.
izeman   100 GW
Post by izeman » Mar 03 2015 6:25am
parajared wrote:I bet an Arduino board would link right up to some gyros and your controller and program fairly easy.
i guess this can only work with a second speed sensor on the front wheel that compares the speed of front and rear wheel.
nieles   10 kW
Post by nieles » Mar 03 2015 6:46am
if you use a gyro and accelerometer, the difference will be easy to tell.
with a wheelie, the accelerating vector and gyro angle are different
with a incline, the plane of accelerating vector and gyro angle are the same
very crude sketch:
mwkeefer   10 MW
Post by mwkeefer » Mar 07 2015 4:09am
Apparently my last post was in poor taste, I was only trying to offer some beta versions at cost to those in the thread.
If you are interested in helping, PM me for details on how - if you want demo units to test, same deal - PM me.
Once the design is fully fleshed out, and ready for deployment it will be released here on ES as a DIY under GPL but I will still hold companies accountable when possible, free for all the ES crowd.
Apologies again!
Regards,
Mike
Regards,
Mike
{My Rides]
