120V receptacle Ground UP or DOWN ?? seem not very clear !
Punx0r   100 GW
Re: 120V receptacle Ground UP or DOWN ?? seem not very clear
Post by Punx0r » Apr 06 2015 7:45pm
I can't look at a photo of an Australian mains socket without seeing a sad face ;)
Hillhater   100 GW
Post by Hillhater » Apr 06 2015 9:04pm
Very apt !
Compared to the UK system, the Aussie plugs are pathetic with flimsy thin pins and no fuse facility.
Very few appliances seem to use an earth pin at all these days....certainly nothing on my kitchen worktop or shop workbench ! :shock:
Stevil_Knevil   10 kW
Post by Stevil_Knevil » Apr 06 2015 9:17pm
____________________________________
We don't care. We're riding Ducatis in our dreams.
teslanv   100 MW
Post by teslanv » Apr 07 2015 1:05am
Hillhater wrote:Very apt !
If an appliance or power tool is "Double insulated" it does not require a grounding pin.
Double-Insulated (DI) – A form of electrical protection featuring two separate insulation systems to help protect against electrical shock from internal malfunctions. DI tools have no provision for grounding (no third grounding prong), and are equipped with a polarized two-prong plug (See “Polarized Plug”). Double-insulated tools will be marked with a “double square”, or the words “Double-Insulated” on the tool’s rating plate.
DD Hubs, Batteries, Controllers & Custom Ebikes.
http://westcoastelectrics.com
West Coast Electric Cycles
Bellevue, WA
USA
dmwahl   10 kW
Post by dmwahl » May 07 2015 9:58am
Alan B wrote:Grounds up on receptacles are required in hospitals. Not sure how widespread this requirement is.
Are you talking about in California? Certainly not the case everywhere. I design anesthesia and life support equipment for a living, and I can tell you that it's not a requirement. I've been in plenty of hospitals where the ground pin is down.
The fingers   100 GW
Post by The fingers » May 07 2015 11:11am
At the one where I work, some are up and some are down. I guess you could say we are Bi-Polar. :lol:
Black Schwinn High Sierra
Blue Schwinn Cruiser 5
Blue Schwinn High Plains
Black Fiore Cruzer 5: Amped Warp Drive 26" Front DD/SLA kit
http://ghostbikes.org/
http://www.rideofsilence.org/main.php
Hebrews 9:27
marty   10 MW
Post by marty » May 10 2015 9:26am
Here is Marty's kitchen. Bottom plug goes to the refrigerator. Top plug goes to the microwave. My vote is ground down. Reason is so to looks like a little face. Ground is the mouth. 2 prongs are the eyes.
Note the vertical position of the plate screw slot. This is so it don't collect dust.
MARTY
Volt Electric Vehicles
http://www.voltev.com
markz   100 GW
Post by markz » May 22 2015 9:55pm
All I know on this subject is the electrical code for Canada states you can have it sideways. Its unusual, more of a architectural design.
But I think I remember the teacher saying you can have it anyway you like, even upside down, because there is a rule stating you can have a outlet on the ceiling, with support.
Drunkskunk   100 GW
Post by Drunkskunk » May 24 2015 11:46am
I just had a chance to talk to the city electrical inspector and a local electrical contractor while they were getting my 70 year old main beaker box recertified and up to code.
According to both of them. Ground down is for 15 amp and lower circuits. ground up signifies you have a 20 amp or higher breaker on the line. But they also said you really can do it any way you want, there is no code for it, just a convention.
Hillhater   100 GW
Post by Hillhater » May 24 2015 5:27pm
...And some religious folks have them facing East ! :roll:
.?? What happens with those floor mounted outlets ?
markz   100 GW
Post by markz » May 25 2015 4:04am
Its somewhere in the code. I got last years book, theres a newer one out now.
I've seen them in houses, but for code.....got no clue.
voicecoils   10 MW
Post by voicecoils » May 25 2015 9:29am
Hillhater wrote:
Punx0r wrote:Always interesting to see how standards for common things vary around the world.
s.
yes, if my memory serve me well,..UK plugs/sockets are earth upwards.
Oddly, considering how much of our history and technology is copied from the UK, but Aussie plugs are all earth pin downwards ? :?:
Funny then that China has the same socket as Oz except earth pin up:
amberwolf   100 GW
Post by amberwolf » May 25 2015 3:22pm
voicecoils wrote:yes, if my memory serve me well,..UK plugs/sockets are earth upwards.
Oh, they're rightside up too, just that y'all are all standing upside down. :P
Drunkskunk wrote:According to both of them. Ground down is for 15 amp and lower circuits. ground up signifies you have a 20 amp or higher breaker on the line. But they also said you really can do it any way you want, there is no code for it, just a convention.
I guess it depends on what area you're in, cuz around here down means unswitched outlet, and up means the closest (usually) wall switch controls that outlet (or pair). Doesn't matter what current rating the breakers are (though usually they're 15A).
