Gotta love these guys - almost 100 MPH with a 48V Etek:
http://www.evalbum.com/2142
48V, 93 MPH
Re: 48V, 93 MPH
Eat your heart out, Deafscooter.
ಠ_à²
Packcycle 2.0 - Scwhinn S-Go
Do you wumbo?
My mind is an enigma. So much so that, sometimes, even I don't know what I was thinking.
Do you wumbo?
Re: 48V, 93 MPH
So 60 #'s of batteries? Why not use some Prius or lithium batteries?
This would seem to be your ultracapacitor application.
Re: 48V, 93 MPH
Thats EZ $$$$$$$$etard wrote:So 60 #'s of batteries? Why not use some Prius or lithium batteries?
Re: 48V, 93 MPH
Yep, lead is cheap. That's why I still use it.
In a speed run like that, the extra weight is not that much of a disadvantage since you have plenty of time to accelerate. And it's flat...
Re: 48V, 93 MPH
The extra weight is an advantage, maybe, in the sense that you do anything you can do to keep the thing going in a straight line with all of its wheels on the ground....In a speed run like that, the extra weight is not that much of a disadvantage since you have plenty of time to accelerate. And it's flat...
Re: 48V, 93 MPH
This is proof that with good aerodynamics you can produce some serious speed. I wonder how much power they are developing? I would guess that they are up into the 12 hp range because that's how the Etek is rated at that voltage if you can pull the amps. The Etek is capable of up to 300 amps.
The Human Powered record is 80 mph, so they should be able to eventually get up to 120 mph if they keep improving things.
