reverse switch
speedmd   100 MW
reverse switch
Post by speedmd » May 19 2017 10:31am
Have a customer with a trike axle running in reverse direction with no switch attached. Controller has a 3 wire lead for a reverse switch, but no switch is handy and no one wants to risk bricking the controller. Any help is welcome.
Hwy89   1 kW
Re: reverse switch
Post by Hwy89 » May 19 2017 6:44pm
If the controller has a self learn function you can connect the two wires and turn on the controller while spinning the wheel in the forward direction. If the wheel is stopped when you turn it on the self learn function has a 50/50 chance of selecting the right hall sequence but for the wrong direction. The self learn wires on the last two controllers I've done were white with matching male and female connectors.
speedmd   100 MW
Re: reverse switch
Post by speedmd » May 19 2017 7:22pm
Thanks for that. I saw that the self learn worked for AW in another older thread also. Will give that a try to get it running the right direction at least. Imagine the three wire connector would be something like connect center to side wire for one direction, and center to other side for opposite. Don't have a spare controller on hand if it goes south. Wish this was all spelled out somewhere.
fechter   100 GW
Re: reverse switch
Post by fechter » May 19 2017 10:15pm
You could try a jumper between any two wires on the reverse connector and slowly apply throttle to see what happens. If you want to be extra safe, use a 1k resistor instead of a jumper, but those connections are made to be grounded. One wire should be ground. You could also try measuring the voltage on the 3 wires with the controller turned on. Measure vs. battery negative.
Some controllers will be speed limited in reverse more than forward.
speedmd   100 MW
Re: reverse switch
Post by speedmd » May 20 2017 7:43pm
Thanks fechter. The 1k risistor is a great idea for this type of trial and error. Will measure and post what works out.
speedmd   100 MW
Re: reverse switch
Post by speedmd » May 25 2017 2:12pm
The self learn did work to find forward again. On the three wire reverse connector, the blue wire to ground will reverse rotation. Worked as should, showing slightly less speed in reverse. Thank to all for the help.
