This is the crankcase of one such two-stroke engine.
IanHill, I often find my self find myself staggered by the technical prowess of the information provided here at ES, but this is one area where I may be of help. I was a mechanic on a submarine. It used a small nuclear reactor to boil water, which was fed to a turbine. I, however...worked on the 2-stroke diesel. Why would a "blank check" cost-no-object device embrace such a cave-mannish configuration? It was the ultimate in reliability. When you wanted it to turn-on and run (because the reactor was down), it simply turned on and ran, no excuses.You have give me something to look into why do diesels have 2 stroke on some applications as 4 stroke diesel uses compression ignition so how that works out on a 2 stroke is one to be looked into
Hehe... In a sense we're all "passengers in tunnels" where a modern gas/diseasal-powered car at highway speeds and driving "straight up" would run out of breathable oxygen/atmosphere in just a few minutes. At ground/surface levels in crowded urban environments exhaust engine gases are MUCH more concentrated. Then there's that whole "noise pollution" thingee... One recent/local news report:Ianhill wrote:...in tunnels running passenger trips face palm twice and a silly slap round the head lol.
LockH wrote:Hehe... In a sense we're all "passengers in tunnels" where a modern gas/diseasal-powered car at highway speeds and driving "straight up" would run out of breathable oxygen/atmosphere in just a few minutes. At ground/surface levels in crowded urban environments exhaust engine gases are MUCH more concentrated. Then there's that whole "noise pollution" thingee... One recent/local news report:Ianhill wrote:...in tunnels running passenger trips face palm twice and a silly slap round the head lol.
http://www.metronews.ca/news/toronto/20 ... cials.html
(In print titled:"Toronto: The city that won't let us sleep")
[Sigh]
What Engine was that SM ? ... Fairbanks ?spinningmagnets wrote: ? Low-RPMs and 10-cylinders, using 20 opposed pistons that "meet in the middle"
Mechanical constant-RPM fuel injection, and air-pressure start, plus no head gasket to fail. It was very large, but it could be broken-down like Lego's and passed through a 33-inch hatch. The initial design was perfected by Junkers Moteren (JuMo 205) before WWII. A diesel-powered airplane. Aerodynamic due to its narrow cross-section, and reliable...plus a high power-per-motor-volume due to 2-stroke.
The deltic was used on diesel electric trains too in the uk stunning bit of kit wasn't it a nazi design ? I don't want to link any videos with copyright issues for the site so for anyone wanting to see the history of uk steam check out mark williams on the rails it's more engineering based than the others ive seen and being a cornish lad he was brought up around industry so tells a good story too nice lad.Hillhater wrote:What Engine was that SM ? ... Fairbanks ?spinningmagnets wrote: ? Low-RPMs and 10-cylinders, using 20 opposed pistons that "meet in the middle"
I know the Navy used the Napier Deltic 18 cly (another mechanical marvel !). in Fast patrol and Minehunter boats for a long while ("60s-80s"),.. but i have not heard much of the 10 cyl aux engines.
Think of the efficency losses of one motor × 4 so it would give an awsome ride but for a long range battery only ride then one motor with good efficency around 20-75mph and even wider range of speed if possible and sent through a diff to the front two wheel like a fwd, the mini slaughtered the opposition with this simple but effective setup obviously it need a gearbox for its ice engine but that can be binned these days.GreyVlad wrote:Four hub motors (4WD) ?
