TheBeastie   10 MW
Re: Wind and Solar vs Coal, Gasoline, Nuclear
Post by TheBeastie » Sep 19 2020 10:18pm
Dauntless wrote:
Sep 09 2020 12:04am
Once we've burned up all the hydrogen, how do we get water back?
Hydrogen is the most abundant element in the whole universe.
And it's never destroyed, it just binds to other elements like 2 Oxygen elements to create water...
When you "burn" hydrogen its actually a reversing chemical process of combining it with other elements, when hydrogen is "burned" it gives off heat/fire as it recombines with oxygen or other free floating elements.
Because burning stuff gives an optical illusion of destroying something or making it smaller, it's really the opposite, as the "burning" material is dispersed widely out into a larger volume into the atmosphere in the form of a gas of some sort.. (co2 / water vapour etc)
With fuel-cells the electricity is created because of the electrons pull attached to Hydrogen wanting to join Oxygen to become water/H2O..
You can see here this ballon of hydrogen is already pooling water at the bottom due to the oxygen that was already in the ballon...
https://youtu.be/WtPrIH0T3b0?t=176
When the flame hits the hydrogen in the ballon it forces a fast reaction of the Hydrogen recombing to the oxygen in the atmosphere causing a splash of water and the release of a lot of heat in the chemical recombination process.
Instead of electricity being created all the potential energy is lost in the form of a heat explosion in the process recombining the hydrogen and oxygen atoms.
https://youtu.be/WtPrIH0T3b0?t=242
Air is mostly just 78% nitrogen and 21% oxygen with 0.04% being co2 and other stuff. So free floating hydrogen will attach to oxygen to become water vapour any chance it can get.
https://en.wikipedia.org/wiki/Atmospher ... omposition
Here is a rather new and nerdy video below of how they make PEM fuel cells.
PEMFCs are built out of membrane electrode assemblies (MEA) which include the electrodes, electrolyte, catalyst, and gas diffusion layers.
An ink of catalyst, carbon, and electrode are sprayed or painted onto the solid electrolyte and carbon paper is hot pressed on either side to protect the inside of the cell and also act as electrodes. https://en.wikipedia.org/wiki/Proton-ex ... _fuel_cell
https://www.youtube.com/watch?v=yrAAVOgBmcE
Speed Kills Range, 10mph = 46 miles range, 20mph = 20 miles, 30mph = 8 miles rangehttps://goo.gl/1JNL53
Over Charging Kills ur battery bit.ly/1hzWKl4
Consider PAS as your only throttle https://goo.gl/Kg1F8F
Fuel-Cell is the ultimate battery coupled with 4th-gen Nuclear
https://goo.gl/TcKtHs https://goo.gl/ZhFFot https://goo.gl/gfa215
10 Square Miles of solar panels = 0.12GW average power! https://goo.gl/Ub1S39
Dauntless   100 GW
Post by Dauntless » Sep 20 2020 10:56pm
Hellhater will have the best comment on this one, the rest of you wait for the master to weight in.
https://www.nytimes.com/2020/09/12/clim ... aring.html
Any sufficiently advanced technology is INDISTINGUISHABLE FROM MAGIC!
- Arthur C. Clarke
Hillhater   100 GW
Post by Hillhater » Sep 20 2020 11:51pm
Ahh ! I see a major flaw in that discussion..
........ leaks of natural gas, a major contributor to climate change.......
So, I didnt bother reading any further ! :wink:
Dauntless   100 GW
Post by Dauntless » Sep 21 2020 3:27pm
I don't understand, you don't think there is much? It's definitely worse than burning it. Remember they're trying to use the message against you.
- Arthur C. Clarke
Dauntless   100 GW
Post by Dauntless » Sep 22 2020 2:18pm
https://www.cnn.com/interactive/2020/09 ... money-intl
The page has some strange formatting, make sure you made it to the bottom.
- Arthur C. Clarke
Balmorhea   100 kW
Post by Balmorhea » Sep 22 2020 2:41pm
Hillhater wrote:
Sep 20 2020 11:51pm
Most hydrogen used these days is steam reformed from natural gas.
___________
Finish Reconstruction.
Hillhater   100 GW
Post by Hillhater » Sep 22 2020 3:08pm
Balmorhea wrote:
Sep 22 2020 2:41pm
Hillhater wrote:
Sep 20 2020 11:51pm
???... so what are you saying here..?
What is the connection between an article on NG leakage/flareing , and hydrogen production. ?
Balmorhea   100 kW
Post by Balmorhea » Sep 22 2020 3:14pm
Hillhater wrote:
Sep 22 2020 3:08pm
Balmorhea wrote:
Sep 22 2020 2:41pm
Hillhater wrote:
Sep 20 2020 11:51pm
I didn't read the article. But as things are now, vehicles fueled by hydrogen are in fact fueled by natural gas more often than not. So they carry all the compromises of that industry.
Sort of like how in a lot of places, an electric vehicle is a coal-burning vehicle.
___________
Dauntless   100 GW
Post by Dauntless » Sep 22 2020 3:30pm
Hydrogen has been on ongoing topic just now, so as he says we get hydrogen from gas that's being wasted.
- Arthur C. Clarke
Hillhater   100 GW
Post by Hillhater » Sep 22 2020 3:53pm
Dauntless wrote:
Sep 22 2020 3:30pm
Nice theory.....but not on a industrial scale,..... huge volumes of commercial gas are required
“Cheap , Clean “ hydrogen is produced by burning gas to make steam, which is then used to reform more gas into hydrogen that costs $10+ per kg to produce. ...
.....with 10 kg of CO2 as a byproduct. !! :roll:
Yea..cheap ...clean... NOT !
ZeroEm   100 kW
Post by ZeroEm » Sep 22 2020 5:53pm
Let's just split water!
abundans cautela non nocet
2019 Performer E-Trike 9w/km
2013 Nissan Leaf S 7 bars 331.5w/KM
Hillhater   100 GW
Post by Hillhater » Sep 22 2020 6:41pm
ZeroEm wrote:
Sep 22 2020 5:53pm
With what ??.....an axe ?
..but i guess you are thinking Electrolysis ...?
You may want to consider the practical costs of that approach too ! :wink:
Dauntless   100 GW
Post by Dauntless » Sep 28 2020 2:17am
- Arthur C. Clarke
Dauntless   100 GW
Post by Dauntless » Sep 29 2020 3:51pm
- Arthur C. Clarke
Hillhater   100 GW
Post by Hillhater » Sep 30 2020 8:02pm
It would appear that some “early adopters” of RE generation are realising that there is more to it than a simple switch away from fossil fuels, and the true costs are hidden along with the consequences.
kdog   10 kW
Post by kdog » Oct 01 2020 7:25am
China just brought onlinethe world's biggest PV power station, source- PV magazine:
World’s largest solar plant goes online in China
Huanghe Hydropower Development has connected a 2.2 GW solar plant to the grid in the desert in China’s remote Qinghai province. The project is backed by 202.8 MW/MWh of storage.
2.2gig....thats huge! Even the skeptics got to admit thats one badass array :shock:
Dauntless   100 GW
Post by Dauntless » Oct 04 2020 10:25pm
- Arthur C. Clarke
JackFlorey   10 kW
Post by JackFlorey » Oct 04 2020 10:28pm
kdog wrote:
Oct 01 2020 7:25am
Yep. And as prices drop, they are only going to get bigger.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Oct 04 2020 11:26pm
Australia's main electricity grid - the NEM, enjoyed five days in a row of >50% renewable electricity for a few hours each time.
https://opennem.org.au/energy/nem
The grid was just fine.
Hillhater   100 GW
Post by Hillhater » Oct 05 2020 3:09am
kdog wrote:
Oct 01 2020 7:25am
By solar installations ,..yes...
Bur remember,..in a good year, that plant will only produce as much power (4 - 5 TWh), as a small (500MW) gas or coal fueled plant.. ( if the weather is co-operating !)
..And in the 11 months it took to build that plant, China opened 20+ new Coal plants, each one with more capacity than the solar plant.
And that 208 MWh of “storage”...is only there because it is essential for the safe operation of the unpredictable solar output. It will never serve any practical purpose as a supply resource.
Hillhater   100 GW
Post by Hillhater » Oct 05 2020 4:42am
jonescg wrote:
Oct 04 2020 11:26pm
You might like to think that, but it is not true, as the largest RE contribution to that data is Rooftop Solar, which is neither a part of the grid supply, and is mostly unmeasured.
The RT data shown is only an estimate of what is thought to have been generated.
.......you may like to see how often S Australia, ( the RE “Poster boy” of Australia), has been “ curtailing” (IE, limiting) their wind generators to prevent problems with the grid supply !
ZeroEm   100 kW
Post by ZeroEm » Oct 05 2020 7:36am
Sounds like it would be cheaper to pull a trailer with a propane fueled generator to power your EV than a FuelCell.
jonescg   1.21 GW
1.21 GW
Post by jonescg » Oct 05 2020 7:55am
Then they really ought to build the NSW SA interconnector so the state which needs it (NSW) can take it from the state that has too much (SA).
ZeroEm   100 kW
Post by ZeroEm » Oct 05 2020 8:22am
Think about what they say about transferring power around from who has more. Just not with in a country/area, makes my head spin.
Dauntless   100 GW
Post by Dauntless » Oct 05 2020 2:19pm
ZeroEm wrote:
Oct 05 2020 7:36am
I don't know if they had a propane version of the Chevy Volt, but it was supposed to be transitional. As you say, the final version might not work out.
- Arthur C. Clarke
