Sevcon Self Characterisation Wizard
sanfox   10 mW
Post by sanfox » Jan 03 2018 1:57pm
I want to tune sevcon gen 4 size 4 controller to use with little induction motor.
I built experimental platform for it.
Testing platform.JPG (123.07 KiB) Viewed 891 times
So connection between dvt through ixxat cable works good.
Also I have SCWizard but this program don't want connecting to controller.
Do anybody use this program?
3250 km in hybrid mode
My car discription at http://www.evalbum.com/5316
fechter   100 GW
Re: Sevcon Self Characterisation Wizard
Post by fechter » Jan 03 2018 2:23pm
I haven't used that exact software before, but most programs are similar.
How does the controller connect to the PC? Is it a serial connection or USB? You may need to configure the serial port on the PC to work.
sanfox   10 mW
Post by sanfox » Jan 04 2018 4:10am
Controller connect to computer via IXXAT USB to CAN cable.
If I push "Connect" button without IXXAT cable the program show message:
"No suitable interfaces connected"
When IXXAT cable connect the program show message:
"Access is denied"
Exception occurred:
Message: Access is denied
Type: Ixxat.Vci3.VciException
Stack: в Ixxat.Vci3.Bal.Can.CanControl..ctor(IBalObject* pBalObj, Byte portNumber, Byte
busTypeIndex)
в Ixxat.Vci3.Bal.BalObject.OpenSocket(Byte portNumber, Type socketType)
в CAN.IXXATInterface.start_can_controller(Baudrate baudrate)
в CAN.CANDataLink.open_communications(Baudrate baud_rate)
в CANOpen.CANOpenDevice.open_physical_connection(Baudrate baudrate)
в SCWiz.SCWiz_Operator.connect_to_node(Baudrate baudrate, UInt32 node_id)
в SCWizControl.main_form.connect_button_Click(Object sender, EventArgs e)
Source: vcinet2
Help:
Data:System.Collections.ListDictionaryInternal
Site: Void .ctor(IBalObject*, Byte, Byte)
SCWizControl, ver 1.0.0.45
Running in F:\Documents and Settings\SASHA\LocalSettings\Apps\2.0\7BBB4J0K.3K4\GNBCW1WZ.N59\scwi..tion_c86b6a1ab057633a_0001.0000_879a1e1a584085d4\SCWizControl.exe
Also the program veiwed message like this:
fechter   100 GW
Post by fechter » Jan 04 2018 10:12am
You got me on that one. No idea exactly what that means.
The only thing I would try is messing with the settings for CAN bit rate and CAN open node ID.
Biff   100 W
Post by Biff » May 14 2018 5:08pm
I have been working with Sevcons for about 7 years now and have not ever come across that software. I saw in your screen-shot that the copyright notice in there is 2007 - 2010.
I bet that the software has not been used or updated by Sevcon for a very long time and is simply not compatible with the IXXAT drivers any more.
I also suspect it is not used any more for one of two reasons:
1) it didn't work very well and just caused people to think setting up a motor on a sevcon would be easy
2) it worked well enough that people would setup motors without the assistance / approval form Sevcon application engineers.
-ryan
sanfox   10 mW
Post by sanfox » Jun 01 2018 7:01am
The main EXE file of this program dated 02.09.2011.
Also the Drive Wizard program dated 24.03.2009 works excellent with the same dongle.
It's very strange!
Volkmar   1 µW
Post by Volkmar » Dec 30 2018 1:26pm
Dear electric car friends!
I want to run a stripped Zytek IDT 120-55 motor with a Sevcon controller. I have removed the complete original control unit and only want to use the short motor. As motor encoder I installed a SKF sensor bearing, which generates a square wave signal and delivers 64 pulses per revolution. Unfortunately Zytek is not very helpful with the missing motor data. For this reason it is unfortunately not possible for me to make the motor turn.
Now my question is to you:
1.) Has someone perhaps the necessary motor data for programming or
2.) Can someone provide me with SCWizard from Sevcon? In the current DVT version there is no function for Self Configuration anymore.
I would be very grateful for your help.
Best regards
Volkmar
Austria
