agni95r trike build Help!
frex   1 µW
Post by frex » Feb 21 2018 2:12am
I need help to figure out my setup to not buy shit. by the way budget is not a problem (i want the best choice) thx to help me
Trike: KMX Kolt Adults Sports max weight: 400lbs (my weight 160lbs)
motor: Agni 95 Reinforced 24lbs
controller: ?? Alltrax SR-72400 Series Motor Controller ? what you recommend me for a better one
throttle:?? need a good throttle
battery: ?? what are the best batteries on the market for this setup
amberwolf   100 GW
Re: agni95r trike build Help!
Post by amberwolf » Feb 21 2018 3:44am
What exactly do you want it to do, and under what condiions?
Go here
https://endless-sphere.com/forums/viewt ... =3&t=66302
and copy the questions from the first post to your thread here, then type in your answers.
That will help us help you find hte stuff to do what you want.
frex   1 µW
How to get the proper advice, read before asking
Post by frex » Feb 21 2018 6:17pm
What are your goals? use the best material too have the maximum range with the agni95r motor
mark5   100 kW
Re: How to get the proper advice, read before asking
Post by mark5 » Feb 21 2018 7:50pm
frex wrote:
Feb 21 2018 6:17pm
frex: amberwolf told you to copy these questions from the other topic and answer them here, not repost your question in the other topic.
wesnewell wrote:
Jan 21 2015 12:31pm
To get solid advice on parts to buy, you must provide the following info.
Desired max speed on level ground. mph or kph
Desired max range at what cruising speed. mph or kph
Preferred bike wheel size, or wheel size of bike you want to convert. Most common kits are for 26" wheels.
Brake type of motor wheel. Disc or not.
Rider weight.
Terrain. Exp: mostly flat, some short hills under 20% grade, I want to climb mountains, etc., etc.
Budget.
