Bus Bar Question for Electric Go Kart Battery Pack
garolittle   100 W
Post by garolittle » Mar 19 2018 7:59pm
All,
I have a question about bus bars. I am new to the forum and I have enjoyed reading many of the threads.
BACKGROUND: I previously modified a kid-sized Razor Ground Force Drifter go kart using the following:
48V/1,000 watt Motor and Charge controller
14S9P battery bank (52V nominal) using brand new INR18650-25R 2500 mAh 18650 battery cells (each cell is rated at 20 amp maximum continuous discharge)
Batteries were spot welded using .15mm x .70mm pure nickel strips (rated at 7 amps max)
Here are a few pictures of the project:
It all worked well and my son loved the extra power and speed. Over the next year, I would like to build a faster go kart which can be driven by adults. This project would utilize a “Sprint Kart” frame with a center mounted seat and would only be used on asphalt surfaces such as parking lots. I would only use it for recreation (i.e. not competitive racing).
I am considering the following:
72v Motor.... something like this .... http://www.electricmotorsport.com/pmac- ... hp-pk.html
72v Charge Controller:
72v battery pack using same cells referenced above
QUESTION:
Up until now, I have only used pure nickel strips for my series and parallel connections. I could "stack" the nickel strips to obtain a higher "amp" capacity but I believe using bus bars for the 72V battery pack would be advisable. I still have much research to conduct but I would appreciate any feedback from the forum. Thanks.
markz   100 GW
Re: Bus Bar Question for Electric Go Kart Battery Pack
Post by markz » Mar 21 2018 10:50pm
You mention nickel strips, so you have a tab welder.
The easiest would be 10awg wire (for series) soldered onto strips, parallel would be 12awg wire, and another option is copper rod or braid - https://www.amazon.com/Small-Parts-Tinn ... B003R501JU
Can use this as a rough guide. As series connection take more amps then the parallel.
https://www.powerstream.com/Wire_Size.htm
garolittle   100 W
Post by garolittle » Mar 22 2018 7:39pm
marks, Thanks for the response. I do have a spot welder so I appreciate your idea. One follow up question: Would the nickel strips increase the resistance since it is not as conducive as copper? Another idea I was considering was to spot weld small fuse wire onto a copper bus bar like this.....
https://youtu.be/H_b3OJuQpEE
Any thoughts? Thanks again!
