if you pedal moderatly how many watts do you need for 100miles
want to build   10 W
Post by want to build » May 18 2018 9:21pm
Correct me if imm wrong
it is said that it needs about 20 watt to do 1 mile just using the motor. personnally i plan to pedal, not only run on battery
If you pedal normaly(medium effort) and use a little bit of power battery to help, how many watts do you need to do100 miles?
Matador   10 kW
Re: if you pedal moderatly how many watts do you need for 100miles
Post by Matador » May 18 2018 9:53pm
Not 20 watt (W) per mile but rather 20 watt-hour (Wh) per mile.
This number is highly dependant on many factors on of wich is speed. Past a certain speed, wind resistance (drag) becomes a significant factor, and Wh/miles consumption increases exponentially with speed.
flippy   10 kW
Post by flippy » May 20 2018 4:33am
Dont make multiple topics with the same questions please.
Lithium beats liquid dinosaurs.
