Noob Looking for help With locating limiter/governor
SplitPolygon   1 µW
Post by SplitPolygon » Jun 20 2018 4:21pm
Hey i recently purchased a Motorino XMb and was trying to find the wire to unplug for the limiter
/governor, i took the side panel off and finally realized i was a bit over my head.
Motor
12” MOTORINO CCT 500W 72V high-torque three-phase AC permanent-magnet brushless
Motor Controller
MOTORINO CCT Sine-Wave controller with regenerative braking and cruise control
eee291   10 kW
Re: Noob Looking for help With locating limiter/governor
Post by eee291 » Jun 20 2018 4:38pm
Seems that the controller has labeled wires, which should make things easier.
Based on my experience there are three ways that those cheap Generic Controllers limit speed.
1. Two wires that are usually the same color plugged into each other.
2. A three wire plug like on the throttle that translates to 3 speeds.
3. Using a low Volt Battery, like running a Motor that would normally run 30mph on 48V, but instead running it on only 24V.
So if it isn't the Battery, try to find a plug that says three speed or low speed.
Hillhater   100 GW
Post by Hillhater » Jun 20 2018 5:08pm
Wow !. :shock: ..seeing That makes me feel a lot better about my messy amature builds ! :lol:
SplitPolygon   1 µW
Post by SplitPolygon » Jun 20 2018 5:56pm
eee291 wrote:
Jun 20 2018 4:38pm
Thanks for the reply.
My battery is 72v so i think its safe to eliminate that option.
I couldnt find a single wire connecting to itself, i'll give it another look.
The three wire plug; do i just disconnect that or is that the wrong approach?
eee291   10 kW
Post by eee291 » Jun 20 2018 6:42pm
The three wire plug (assuming you don't confuse it with the throttle one) has a common wire, here are the modes:
1. Unplugged, 80% (or 100% if it has field weakening)
2. Middle wire shorted to one wire, (of the same plug) 50% or less
3. Middle wire shorted to the other wire, 100% (or 120% if it has field weakening)
eee291   10 kW
Post by eee291 » Jun 20 2018 6:45pm
Hillhater wrote:
Jun 20 2018 5:08pm
Needs more Anderson Connectors :lol:
markz   100 GW
Post by markz » Jun 22 2018 6:43pm
LOL
Well mines messy too, and right now I have electrical tape on twisted wire for the sensor wires.
Hey, I could upgrade to heat shrink but thats too much work to walk down stairs, find scissors and heat shrink and Bic lighter or BBQ butane lighter.
Solder, well yeah I could, but thats too much work. Have to get the iron and solder out, wire strippers.
nickatnoon61   10 mW
Post by nickatnoon61 » Jul 26 2018 6:16pm
Hi Noob, My XPh has black/white wire loop which is the limiter. It was actually hanging underneath and could be seen from the side. I just spent the day testing my XPh with the Chinese e-car tester and 99% sure my controller is toast. That's a relief for me bc my bike has been sitting for almost 4 years. So I NEED a controller if anyjuan has one?!? I am in BC. Good luck! :)
