SilentEnduro   100 mW
Re: Votol EM-100 & EM-150 controllers
Post by SilentEnduro » Nov 19 2019 1:18pm
larsb wrote:
Nov 19 2019 1:17pm
Impossible to say without an oscilloscope. Why bother? Motor runs well with this setting.
Controller overheating on sand or hard hills :)
larsb   100 kW
Post by larsb » Nov 19 2019 1:20pm
Never had it get warm even with repeated drag races on 200A. There’s no reason to change anything.
Ride on!
SilentEnduro   100 mW
Post by SilentEnduro » Nov 19 2019 2:22pm
larsb wrote:
Nov 19 2019 1:20pm
However I want to try it without flux weakening :)
But don't know how)))
Here is my config and rpm https://vimeo.com/374241692
larsb   100 kW
Post by larsb » Nov 19 2019 3:44pm
How do you mean you don’t have field weakening?
Ride on!
SilentEnduro   100 mW
Post by SilentEnduro » Nov 20 2019 1:22am
Thought this is applicable only when "sport mode" activated.
Thanks, will check.
UPD: yep, this is it, thanks a lot
wjr   10 W
Post by wjr » Nov 21 2019 8:34am
Nice that thread shifts to flux wekaning again.
I'd really like to gain some more understanding of those values
  • Flux-Weakening compensation
  • Flux-Weakening Value (in 6 different positions)
  • The %-Figures in the Three-speed box
  • Phase current
larsb wrote:
Nov 19 2019 1:02pm
I think the phase angle shift setting at 60 degrees is already slightly advanced from neutral. This creates field weakening.
Ah, :!: :?:
When I look to this figures, labelled "without flux weakening" by QS
in my eyes they resemble typical characteristics of flux weakening, anyway:
  • constant torque only up to ~ 1500 rpm
  • hyperbolic falling torque and ~ constant power between 1800 and 4000 rpm
Just looking at the chart, I might have said that flux weakening were active above 1500 rpm.
Might the advanced phase angle shift be the cause of this behaviour?
But anyway, what does the 100%-value in the speed settings refer to?
no-load rpm? which is 4350 in this case?
wjr   10 W
Post by wjr » Nov 23 2019 4:59am
Come on, guys, let's knit some clothes for the naked emperor :lol:
larsb wrote:
Nov 19 2019 1:17pm
I have a small DS203.
OK, it's more a toy than a professional grade osci, but I could even attach it to the bike wihle driving.
Might this help to gain more insight to all those opaque figures we keep on questioning here?
Its got 2 analog channels and another two digital ones.
So I cannot measure eg hall, phase voltage and phase current the same time.
But I think I could try to use hall voltage to trigger one of digital inputs so I might get phase angle relations that way for all three values in consideration.
I think I'll provide a shunt in one of the phase wires. Well, the wire itself may do the job.
I have some hall based current sensors and current transformers as well, but I'm not sure how they affect presicison of timing.
hm ... the phase terminals will jump from 0 to V-batt, maybe plus some spikes.
Shunt voltage is in the mV, and halls are said not to like overvoltage.
So still some thinking required, regarding signal conditioning....
SilentEnduro   100 mW
Post by SilentEnduro » Nov 24 2019 12:05pm
a bit offtop, thank you all for the advice!
Votol is running as hard as it can \m/
https://youtu.be/eDP8pV54EdY
3-speed set:
1. 50% (give someone a bike)
2. 100% (hours of fun in mud)
3. 100% + flux weakening (for max speed)
SilverLine   100 W
Post by SilverLine » Nov 24 2019 12:57pm
SilentEnduro wrote:
Nov 24 2019 12:05pm
3-speed set:
Such a nice build.... nice
between speed 2 and 3, have you noticed any difference in torque ??
SilentEnduro   100 mW
Post by SilentEnduro » Nov 24 2019 1:03pm
SilverLine wrote:
Nov 24 2019 12:57pm
not yet, there was only one ride for now)))
however in theory, 3rd gear should have more rpm and same torque
wjr   10 W
Post by wjr » Nov 24 2019 1:33pm
SilentEnduro wrote:
Nov 24 2019 12:05pm
a bit offtop,
:bigthumb: :bigthumb:
not off topic at all imho
That's the spec, that' where it starts and where the settings are supposed to go to.
As people said, it all goes together, holystick or so, they called it :lol:
You run the QS 138 on the Votol 150?
May I ask you for your transmission rate and your battery data?
SilverLine   100 W
Post by SilverLine » Nov 24 2019 2:44pm
SilentEnduro wrote:
Nov 24 2019 1:03pm
SilverLine wrote:
Nov 24 2019 12:57pm
Others in this thread , refuse to share screen shots. So do you mind sharing page 1, 2 and 3 ?
SilentEnduro   100 mW
Post by SilentEnduro » Nov 25 2019 2:10am
wjr wrote:
Nov 24 2019 1:33pm
Reduction drive is made to decrease rpm 1:2, then sprockets 15:50, so in the end 6.7 reduction ratio.
(may be later we will replace rear sprocket to 52)
Battery 22s, 55Ah (prismatic)
let's continue to discuss bike at following thread:
viewtopic.php?f=10&t=102858
SilentEnduro   100 mW
Post by SilentEnduro » Nov 25 2019 2:11am
SilverLine wrote:
Nov 24 2019 2:44pm
Here is a config file
22s_Config.ini
(288 Bytes) Downloaded 70 times
Screenshots a bit later =)
SilverLine   100 W
Post by SilverLine » Nov 25 2019 4:20am
SilentEnduro wrote:
Nov 25 2019 2:11am
SilverLine wrote:
Nov 24 2019 2:44pm
Here is a config file 22s_Config.ini
Thanks my Friend. So you are using 22s on votol em150 ?
UPDATE : LOL... when I try to import your parameters in the votol software, it gives me some crazy numbers.... very buggy software
ZERONEST   1 W
Post by ZERONEST » Nov 26 2019 4:23am
@larsb Which manual are you reading from?
I've been using the 2000w motor with em100 controller a little bit now but cannot seem to make the throttle response sharper in controller settings, is this just the nature of a low kv motor without reduction drive? I have switched off soft start which helped a bit and have also tried softstart enabled set at 16 which seems the same to me.
when riding it doesn't feel like deadband in the throttle but like a lagged build up of power which feels quite unexpected and hard to get used to, has anyone experienced similar?
larsb   100 kW
Post by larsb » Nov 26 2019 4:55am
I have an older program than most and the trottle setting does not work.
Check if it works for you by setting some big changes - does it have effect?
Ride on!
SilentEnduro   100 mW
Post by SilentEnduro » Nov 26 2019 6:24am
SilverLine wrote:
Nov 25 2019 4:20am
The thing is that there are a lot of software versions for Votol:
VOTOL-EM-V3 Software Debugging(CAN)-6
votol 1.jpg (56.27 KiB) Viewed 1608 times
VOTOL-EM-V3 Software Debugging(IO19)
votol 2.jpg (55.05 KiB) Viewed 1608 times
votol 3.jpg (48.26 KiB) Viewed 1608 times
Here is config for "VOTOL-EM-V3 Software Debugging" from latest KTM build
SilverLine   100 W
Post by SilverLine » Nov 26 2019 11:32am
Thanks ? Didn't you run 22s og your build ? Because your voltage settings says otherwise ?
larsb   100 kW
Post by larsb » Nov 26 2019 12:59pm
No, it doesn’t
89.5/20 is not a normal lipo overvoltage but it fits 21s or 22s
Ride on!
wjr   10 W
Post by wjr » Nov 26 2019 3:01pm
:bigthumb: :bigthumb: :bigthumb: to @SilentEnduro
SilverLine   100 W
Post by SilverLine » Nov 26 2019 3:05pm
larsb wrote:
Nov 26 2019 12:59pm
No, it doesn’t
Arh yes, you are right :-)
SilentEnduro   100 mW
Post by SilentEnduro » Nov 29 2019 2:47am
btw folks, do we have a separate thread for Votol EM-200?
or can we discuss it here?
larsb   100 kW
Post by larsb » Nov 29 2019 3:25am
I think it should be separate thread, this is already long enough.
Ride on!
SilverLine   100 W
Post by SilverLine » Dec 07 2019 12:22pm
Finally...
First power up, of the Em150 - qs mid drive 3000w combo......
I could change the throttle endpoints, without any problems.... So nor my settings are "start throttle" 0.5v and Full speed is 5.02v, and it seems to work perfect.
As of now, i´m hitting arround 6000 rpms, in "sport" mode, what do other have ??
https://youtu.be/1Kuu7Z1KLNU
